Engineering advice required
Discussion in 'UK Motorcycles' started by Lozzo, Feb 12, 2006.
  1. Lozzo
    I have AP Racing calipers on the Gixer, on which the pads are retained
    by two long R-Clips hich have corroded to shit. I've had a problem
    sourcing new ones from AP because they don't make that caliper any more,
    the replacement is 5mm narrower. I've managed to lay my hands on the
    last 4 clips AP had, but I know they'll corrode as badly as the
    originals I have.
    Is there a form of metal treatment that will last in our weather and
    still the keep required attributes of the original metal? Either black
    or silver treatments will do, as long as the finish lasts better than
    what these have to start with.
    Lozzo, Feb 12, 2006
  2. Lozzo
    SteveH Guest
    Hmmmm, I would suggest a thin layer of Hammerite smooth, but that would
    probably make them too thick to use.
    This is a bit expensive for a one-off job, but I'm sure you'd suddenly
    find a need to use it on everything you lay your hands on:
    http://www.frost.co.uk/item_Detail.asp?productID=8260
    SteveH, Feb 12, 2006
  3. Lozzo
    SteveH said...
    I don't want to Hammerite anything on this bike. it's a bit too nice for
    shit like that. I've never found Hammerite to be any better than any
    other paint either. I'm looking for a plating solution, one I can have
    someone else do.
    Lozzo, Feb 12, 2006
  4. Lozzo
    Do the clips replace the normal pad securing pins you'd get on Jap
    calipers or do they just hold the pins in place as on Jap stuff? If
    it's the former I'd modify the set up to take a normal pin because
    it's not as if you want to do rapid pad changes as you might if you
    were using them for racing.
    Andy Bonwick, Feb 12, 2006
  5. Lozzo
    Ovenpaa Guest
    What are they made of? - A cathodic (electrophoretic) black finish would do
    the job with an increase in diameter of maybe 30 microns max and will give
    960 hrs plus salt spray resistance.
    Gosh, I wonder where that could be done?
    Ovenpaa, Feb 12, 2006
  6. Lozzo
    Lozzo scribbled on the back of a napkin:
    Chrome plating may be possible depending on the material but it may
    make the pins too brittle.
    Can you get someone to copy them in stainless steel instead?
    Timo Geusch, Feb 12, 2006
  7. Lozzo
    Andy Bonwick said...
    Good point. They are quick release type. I can handle not having that
    benefit as I don't have to change pads all the time. It wouldn't be out
    of order to have simple pins each with two smaller R-clips holding them
    in place, but again I wouldn't want those corroding so would be looking
    at something more permanent like stainless steel. These ones I have are
    quite exposed and very noticeable when they are corroded.
    Lozzo, Feb 12, 2006
  8. Lozzo
    Ovenpaa said...
    They look like they already have that type of coating on already, and
    it's crap.
    Lozzo, Feb 12, 2006
  9. Lozzo
    snip>
    Titanium is what you want. I haven't got any lying around but how much
    would a pair of Ti bolts cost and once you've got them to ask Mr Eaton
    to modify them into pins.
  10. Lozzo
    If Mr Eaton is prepared to waste a lathe tool machining 4 bolts down to
    3mmish dia and then cutting them off. I suppose I could buy him a top
    quality tool to do this job and others he made need it for in future.
    Lozzo, Feb 12, 2006
  11. Lozzo
    R obbo Guest
    You might ask these people nicely if they would do some for you
    http://www.alloywire.com/
    R obbo, Feb 12, 2006
  12. Lozzo
    R obbo Guest
    Nowt a carbide tip tool won't fix I would expect.
  13. Lozzo
    Muck, Feb 12, 2006
  14. Lozzo
    I don't think it'd be a case of needing a new tool, more a case of me
    bringing him one over for the weekend. You can buy sets of 12mm shank
    throwaway tipped tools for about £30 and once I knew the tool post
    size of his lathe I'd sort him out what was needed.
    If they're 3mm then have a look see if you can get some titanium
    socket cap head screws long enough then just modify the head and drill
    for a split pin. Titanium isn't difficult to machine by any stretch of
    the imagination, it's no tougher than stainless steel.
  15. The message <>
    Have you still got the old ones?
    I could molish copies out of stainless steel if I can find the right
    thickness bar.
    Rusty Hinge 2, Feb 12, 2006
  16. Lozzo
    Rusty Hinge 2 said...
    I've got two full sets, one of which are new, the others are horribly
    fucking corroded. The only things on my Suzuki that have corroded are
    British made, now I know why I never bought a Triumph.
    Lozzo, Feb 12, 2006
  17. Lozzo
    Buzby Guest
    I'm prolly completely wrong & got the wrong end of the stick but would a
    very light coating of copperslip not keep corrosion in check?
    Buzby, Feb 12, 2006
  18. Lozzo
    raden Guest
    I could chuck them in with my plating for nowt
    raden, Feb 12, 2006
  19. The message <>
    Well, d'you want me to see what I can find to copy them in? (I used to
    be a motorcycle mechanic, later, a metalwork [amongst other things]
    teacher...)
  20. In uk.rec.motorcycles, Lozzo belched forth and ejected the following:
    Coat hanger with a hole drilled in it.
    Whinging Courier, Feb 12, 2006
