Engine Tech stuff
Discussion in 'Australian Motorcycles' started by mero, Aug 11, 2003.
  1. mero
    mero Guest
    can someone explain the firing sequence of triples and v5's?
    thanks in advance
    mero
    mero, Aug 11, 2003
  2. mero
    smack Guest
    yes
    but I've never met him
    smack, Aug 11, 2003
  3. Spark, spark, spark.
    Or
    Spark, spark, spark, spark,spark.
    Happy to help.
    Aaron
    ZX6R
    Aaron & Kylie, Aug 11, 2003
  4. Ahhh, that makes sense - the triples run even firing orders, but
    the v-fives run that last cylinder a little closer than the
    rest... Thats must be why they sound that way...
    Actually, I seem to remember reading an article where Jeremy
    Burgess (?) - Rossis crew chief explaining that even _he_ doesn't
    know stuff that detailed about the motor - Honda fly a bunch of
    them out to each race meeting, and they just bolt them in and go
    win races - no opening up needed (or indeed allowed).
    big
    Iain Chalmers, Aug 11, 2003
  5. mero
    My old points model mach111 triple used to go spark, spark, umm, spark, ummmm, spk, sp, sp, ****!!
    (It may not have made that last noise but I'm sure I heard it!)
    Knobdoodle, Aug 11, 2003
  6. mero
    mero Guest
    perhaps i should clarify ...
    how do they cylinders fire when you have a 4 stroke cycle? do they have a
    blank firing cycle (similar to a twin)?
    a twin goes: spark, nothing, spark, nothing
    an inline 4 goes: spark, spark, spark spark
    does that mean a triple goes: spark, spark, spark, nothing?
    and a five goes: spark/spark, spark, spark, spark?
    mero, Aug 11, 2003
  7. mero
    Nev.. Guest
    I don't know how the triples and V5 engines work, but your underlying
    assumption that when 1 cyl is at TDC all of the other cylinders will be either
    at TDC or TBC may be flawed for bikes which have an odd number of cylinders
    (and even for 4 cyl 2 stroke GP bikes... the Honda (and Yamaha?) "Big Bang"
    engines had a rather unusual firing sequence.. something like nothing nothing
    nothing nothing nothing nothing nothing spark spark spark spark).
    Nev..
    '02 CBR1100XX #2
    Nev.., Aug 11, 2003
  8. mero
    alx Guest
    Nah, that's the timing advancer kicking in on the fifth spark.
    alx, Aug 12, 2003
  9. mero
    glitch1 Guest
    You bastards !!
    That thread cost me another keyboard, the other 2 are still drying out,
    upside down over the heating-vents.
    ....and coffee is NOT on special this week!
    Thanks guys
    pete (still trying to fire in ANY order)
    glitch1, Aug 12, 2003
  10. mero
    Theo Bekkers Guest
    "Nev.." wrote
    They had the firing sequence of two twins running synchronously. Two
    cylinders fire together, then the other two 180º later, then 540º
    later, the first two again.
    Theo
    Theo Bekkers, Aug 12, 2003
  11. mero
    atec77>> Guest
    put the boards in the dish washer on gentle cycle cool.
    atec77>>, Aug 12, 2003
  12. mero
    Theo Bekkers Guest
    "Intact Kneeslider" wrote
    Duh! Bloody two-smokes 180º later.
    Theo
  13. mero
    Doug Cox Guest
    No it doesn't. It only gives you an even firing order. The 955 Triumph has a
    balance shaft.
    And a balance shaft.
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Aug 12, 2003
  14. Depending on how you cut the cams and trigger the ignition, as the rest of
    my example demonstrates. :)
    To smooth out the secondary vibration ahead of almost anything else. An even
    phase crank gets the sum of the momenta due to the primary motion of the
    pistons near to zero. The balance shaft compensates for the secondary motion
    (jargon used to hide my not having put equation to paper to convince myself
    of how the whole show works and just how big the correction ends up needing
    to be)
    All 5 of my inline fours have had balance shafts, too, even the little one
    that revved to 19 grand. :)
    I remember hearing a story about someone pulling the balance shaft out of
    their Triumph just to see what would happen... it'd be useful if I
    remembered what the results were, too...
    Isn't that actually one of the big things with top-flight race motors; they
    pull the balance shafts out of them and the engine builder compensates as
    best he can with what's left and the rider gets told to put up with the
    rest. I distinctly remember reading about Andrew Hallam or one of the other
    Melbourne tuners commenting on how they race-prep a GSX-R1000 and they
    specifically stated that they ditch the balance shaft, not so much to get
    back the couple of hp it takes to spin, but because they don't want to risk
    having it fly apart; as they put it, it's a couple of kg of unbalanced metal
    whizzing around at anything up to 25,000rpm thanks to the raised redlines of
    racebikes.
    Intact Kneeslider, Aug 12, 2003
  15. mero
    John Littler Guest
    Does it really ? And which twins and inline 4s have these characteristics
    JL
    (hint, do you know the difference between a 2 stroke and a 4 stroke ?)
    John Littler, Aug 12, 2003
  16. Please do... it'll be appreciated...
  17. mero
    Mike.S Guest
    To dull it down, a 4 cyl motor would be running with the cylenders offset 90' from each other,
    The order of the offset is a matter we dont need to enter into here. but but but
    oh hell i see where your coming from, i'll shut the hell up and read other replies.
    Mike.S
    Mike.S, Aug 12, 2003
  18. mero
    John Littler Guest
    'Ere we go
    http://www.mecc.unipd.it/~cos/DINAMOTO/indexmoto.html
    Got some great stuff here. And given you speak wog you can make more sense out
    of some of them than my scratchy italian allowed me to.
    JL
  19. mero
    Frosty Guest
    In a four stroke motor any given cylinder will fire every second revolution.
    In most circumstances this means that all cylinders will fire in every two
    revolutions of the motor or a multiple there of. The rest just involves
    offsets in the crank to even everything out....
    Frosty, Aug 15, 2003
  20. mero
    RM Guest
    yes ebberytin fire in 2 revolutions mon...crank pins are offset to 3/360 or
    5/360 etc, cam rotates at 1/2 crank speed and bumps are arranged according
    to required valve timing and cylinder offset
    RM, Aug 15, 2003
