engine swap?
Discussion in 'Motorbike Technical Discussion' started by bdon666, Apr 1, 2009.
  1. bdon666
    bdon666 Guest
    looking for an easy answer-
    will the engine of a '81 yamaha xs400 go into a '78 xs400 with no
    unforeseen issues?
  2. bdon666
    tylernt Guest
    Probably. There were a number of changes made wrt early and late
    models, but the Haynes book I have seems to say that '77 and up (in
    the US, anyway) are considered "late" so it looks like you're swapping
    a late engine into a late frame. Two things to check, though, are:
    engine mountings -- early engines were bolted directly to the frame,
    later engines had rubber buffers; and ignition -- early had points,
    later had solid state CDI. If your '78 has these "late" model
    improvements then I suspect it will be plug 'n' play.
    tylernt, Apr 2, 2009
  3. bdon666
    bdon666 Guest
    thanks for the good news.
    this is encouraging and much appreciated.
    bdon666, Apr 2, 2009
  4. Yes. Same lump. I *think* the later XS400s had electronic ignition,
    which might complicate things.
    Unless you're talking about the monoshock XS400, which is a totally
    different bike, but I think that first appeared in 1982.
    The Older Gentleman, Apr 2, 2009
