Engine Swap? Kawasaki?
Discussion in 'Motorbike Technical Discussion' started by FM, Nov 1, 2006.
  1. FM
    FM Guest
    I have a chassis .. 84 Ninja but no engine ... but can I fit a 750
    engine from the same year without tooo much trouble? BTW I thought the
    900 was water cooled with a rad. but the 750 is air/oil cooled .. not
    sure
    thanks
    Frz
    FM, Nov 1, 2006
  2. FM
    B-12 Guest
    The original 900 Ninja was water cooled. You may be thinking of a
    GPZ-750 or KZ-750
    engine of it's air cooled.
    An engine swap will be a nightmare. I wouldn't recommend trying it
    unless you are ready to make up custom engine mount brackets and
    cables, etc.
    The location of the countershaft sprocket is where you'd have to start,
    you can't just stick the wrong engine in and think what matters is
    whether the holes in the crankcases match some holes in the motor
    mounts.
    The countershaft sprocket has to be in the correct horizontal location
    so it aligns with the rear sprocket, and it also has to be in the right
    location vertically so the chain tension
    doesn't get too loose as the swing arm moves up and down.
    And, the 900 Ninja may need to bolt the cylinder block or the cylinder
    head to the frame, while the GPZ750 or KZ750 wouldn't be designed that
    way.
    B-12, Nov 1, 2006
  3. Kawasaki made a 750cc version of the 900 Ninja. Just a sleeved down
    lump. This will fit in the 1984 chassis with absolutely no problems.
    The air-cooled engines will be more hassle than it's worth, yes.
    The Older Gentleman, Nov 1, 2006
