Engine removal - NTV 650
Discussion in 'UK Motorcycles' started by Klaatu, Dec 2, 2003.
  1. Klaatu
    I had to take my jumper off in my, unheated, workshop about 9pm last
    night.
    sweller, Dec 4, 2003
  2. Klaatu
    Klaatu Guest
    For a "jog" ?
    Klaatu, Dec 4, 2003
  3. Klaatu
    Ginge Guest
    No. I don't do jogging.
    I went out to post something.
    Ginge, Dec 4, 2003
  4. Klaatu
    Klaatu Guest
    This turned out to be prophetic.
    Fucking thing.
    Klaatu, Dec 18, 2003
  5. Klaatu
    flashgorman Guest
    Anglegrinder YKIMS.
    flashgorman, Dec 18, 2003
  6. Klaatu
    Klaatu Guest
    This is looking like "a good idea"
    The bolt in question is the one that holds the crankases together.
    It goes through the frame and is seized solidly: Placing
    a hydraulic engine jack at the rear of the engine and pushing the
    engine up, turns the bolt 16th inch then lifts the whole bike up !
    If the blowtorch doesn't do it then it gets cut out
    and then some precision drilling will be performed.
    All this and it isn't even my bike FFS !
    Ever regretted agreeing to do someone a favour ?
  7. Klaatu
    Klaatu was seen penning the following ode to ... whatever:
    Turn the blowtorch up as if you wanted to melt the engine case...
    Often enough.
    Timo Geusch, Dec 18, 2003
  8. Klaatu
    tallbloke Guest
    Klaatu <> spouted the following in
    Split the nut. With a *sharp* chisel.
    tallbloke, Dec 18, 2003
  9. Klaatu
    Klaatu Guest
    Can't : It's recessed inside the Aluminium frame.
    Klaatu, Dec 22, 2003
  10. Klaatu
    Drill the head off the fucker then drift it out.
    It's time to get technical on it.
    Pip, Dec 22, 2003
  11. Klaatu
    Klaatu Guest
    THHHHHHHHHHHHHHWWWWWWWWWWWWAAAAAAAAAAAAACK !
    As the
    engine is fucked, (1)cos the dozy twat (2)ran it dry,
    It doesn't matter, as long as the
    frame is not damaged.
    1. Big ends shot to pieces
    2. A Courier.
  12. Klaatu
    tallbloke Guest
    I hope thats the noise of you hitting the courier.
    tallbloke, Dec 22, 2003
  13. Klaatu
    Klaatu Guest
    No, he had to leave the country.
    Klaatu, Jan 2, 2004
  14. Klaatu
    tallbloke Guest
    Long delivery job?
    tallbloke, Jan 2, 2004
