engine oil - what type to use
Discussion in 'Australian Motorcycles' started by Peter Cremasco, Jun 14, 2005.
  1. Just extracted this from the FJR service manual, in regards to what
    types of oil to use on the wet clutch.
    • Engine oil also lubricates the clutch and
    the wrong oil types or additives could
    cause clutch slippage. Therefore, do not
    add any chemical additives or use engine
    oils with a grade of CD or higher and
    do not use oils labeled “ENERGY CON-
    SERVING II” d or higher.
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s (gone on to better and brighter things - I hope)
    '87 BMW K100RT (write-off)
    '81 Yamaha Virago (XV) 750H (work in progress)
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
  2. Peter Cremasco
    G-S Guest
    Nothing new there Peter... friction modifiers have also been a nono on
    wet clutch motors. Doesn't make any difference on dry clutch bikes...
    G-S
    G-S, Jun 14, 2005
  3. I knew the bit about friction modifiers, and also new that it was
    irrelevant as far as dry clutches go. But there has always been some
    debate as to how 'good' a conventional oil has to get before it is no
    longer suitable for wet clutches. FJR manual states no greater than CD
    grade, and Castrol has advised no greater than SG grade.
    Cheers
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    # 37181
  4. Peter Cremasco
    G-S Guest
    It was my understanding that CD grade requires friction modifiers (or
    equivilent).
    G-S
    G-S, Jun 15, 2005
  5. Ahh. I didn't realise that, but that would explain why it's recommended
    not to use it in wet clutches.
    Cheers
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    # 37181
    Peter Cremasco, Jun 16, 2005
