Engine oil, Car Vs. Bike
Discussion in 'Australian Motorcycles' started by Alex Kelly, Aug 29, 2004.
  1. Alex Kelly
    Alex Kelly Guest
    Read the article about the oils being somewhat interchangeable
    (http://groups.google.com/groups?selm=.
    au)
    but dont know what to do in my specific case. I have some Castrol GTX3 SAE
    15W40 SL/CF class leftover from when I changed my car oil. The motorbike is
    asking for SE or SF class (apparently inferior according to the conclusion
    in the above linked article??) SAE 10W40, 10W50, 20W40 or 20W50.
    So the weight seems right, but is SL/CF class able to be used where the
    apparently inferior SE/SF class is asked for?
    Google wasnt of alot of us.
    Thanks, Alex Kelly.
  2. In aus.motorcycles on Sun, 29 Aug 2004 15:50:23 +1000
    It never hurts to use later model oil.
    As long as it's dino oil - not synthetic - if you have been using
    non-synthetic before.
    In other words, don't use synthetic in a bike that's had non-synthetic
    oil unless you change the oil filter and flush the system.
    Otherwise, if the weight is close enough, and it seems to be, go for it.
    Oil quality isn't as important as frequent changes, You can use
    whatever you like as long as you change it early and often.
    Zebee
    Zebee Johnstone, Aug 29, 2004
  3. I went down this road recently, and ended up by sending an email to
    Castrol. Basically, I wanted to standardize on oils, rather than having
    one kind for the car, another for the K100, and different one for the XV
    and another for the GS (yeah yeah yeah - I know - I OVER emphasising).
    My concern was the wet clutch on the XV and the GS. I got a responding
    phone call from a tech at Castrol (very impressed with the promptness
    and personal approach to the customer) who informed me that NONE of the
    Castrol oils now have friction modifiers in them. HOWEVER, for wet
    clutches in motorcycles, they do not recommend going anything above an
    SG class oil. That means that the GTX-2 and GTX-3 products are a no-no.
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Aug 29, 2004
  4. Not according to the Castrol tech, when it comes to wet clutches.
    Agreed. I'd rather use Type-X oil that is half the price of Type-Y, and
    change it twice as often.
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  5. Alex Kelly
    Johnnie5 Guest
    and did they say why not ???
    Johnnie5, Aug 29, 2004
  6. Alex Kelly
    Justin Guest
    Well..... beat this..... a guy came into my shop today and bought oil for
    his mower. HE selected Mobil 1 (the TRUE fully synthetic Mobil 1 10w-30,
    not the semi-synth 5w-50 stuff) @ $100 a bottle!!
    Just a little bit of overkil you think?
    Justin
    Justin, Aug 29, 2004
  7. Alex Kelly
    Johnnie5 Guest
    you didn't inform him that mowers use straight 30 ??
  8. Alex Kelly
    atec Guest
    check the BWM site , it actually explains why their oil is better ,
    things like additional ashing properties etc .. the Motor Cycle oil does
    actually work better in the graphs they display .
    atec, Aug 29, 2004
  9. Alex Kelly
    Aaron Guest
    Depends if you are using Optimax or not.
    Aaron
    ZX6R
    Aaron, Aug 29, 2004
  10. Alex Kelly
    Uncle Bully Guest
    You'll find those graphs are made by marketing people, not engineers.
    Uncle Bully, Aug 29, 2004
  11. Alex Kelly
    Aaron Guest
    My favourite is graphs that don't start at 0.
    Almost useless.
    Aaron
    ZX6R
    Aaron, Aug 29, 2004
  12. Alex Kelly
    atec Guest
    I doubt they are far from the mark , this is from the land of anal
    engineers remember .
    atec, Aug 29, 2004
  13. Alex Kelly
    Justin Guest
    .... because his owners manual stated he had to use a 10w-30, so that's all
    he wanted to even look at.
  14. Virtually spot free.
    Hammo
    Hamish Alker-Jones, Aug 29, 2004
  15. Alex Kelly
    FuTAnT Guest
    That's one seet runnin mower! haha, kick ass!
    Cam
    FuTAnT, Aug 29, 2004
  16. Alex Kelly
    Moike Guest
    Not useless. They can be craftily misleading.
    Moike
    Moike, Aug 30, 2004
  17. Alex Kelly
    Alex Kelly Guest
    I have been using regular unleaded so far...
    Can anyone tell me the differences between the various classes of oil, or
    link me to a chart that explains it?
    Cant find much info on it, thanks for your help so far.
    Alex Kelly, Aug 30, 2004
  18. Alex Kelly
    Aaron Guest
    *sigh*
    Aaron, Aug 30, 2004
  19. Alex Kelly
    Johnnie5 Guest
  20. Alex Kelly
    Johnnie5 Guest
    Johnnie5, Aug 30, 2004
