Engine Oil Aging
Discussion in 'UK Motorcycles' started by Antonio, May 13, 2006.
  1. Antonio
    SteveH Guest
    But I'm not selling my VFR....
    SteveH, May 13, 2006
  2. In uk.rec.motorcycles, Beav belched forth and ejected the following:
    I've only just recently noticed it when I last checked the oil level.
    There is what appears to be coolant leaking from the head because
    there's a yellowy hue to the exhaust paint which I sprayed the engine
    in. That's been like that for at least the last 10,000 miles, I reckon
    and I have been using it for very short journies to work and back when
    there's still a bit of a nip in the air.
    The oil needs changing anyway so I'll keep an eye on it after that.
    It isn't really bad, btw but it's reassuring to know the ratbike has a
    bit of life left in it yet.
    Whinging Courier, May 14, 2006
  3. Antonio
    Antonio Guest
    Actually I was intimidated with DIY fitting, but now I have one, I'm
    actually impressed with how relatively easy to fit it appears to be.
    They include enough options for connection to make it a piece of piss
    really. I imagine it will still take me a while though, and the photo
    suggesting
    "cut the vaccum here" is a bit vague for an illiterate like me.
    Antonio, May 14, 2006
  4. Antonio
    Beav Guest
    If there's a leak to the outside world, it's possible an amount is leaking
    into the motor too causing the discolouration of your oil.
    And short trips rarely (if ever) get the engine hot enough to boil off the
    water in the oil. Well not unless there's not enough coolant to keep the
    temp under control. When it's cold weather, it's not a bad idea to
    occasionally let an engine run hot enough to fire up the fan (104c on the
    Zed) so you *know* the water is removed. The Zed will reach 104 in traffic
    now the temps have come out of the depths of hell, but over winter, NO
    fucking chance, and I make sure it's at that temp when I change the oil, to
    make sure any water id gone and the oil is as thin as possible.
    Never a bad idea.
    I've got to get a tuit for my VN sofa. I've been "doing the engine" all
    winter and I've yet to turn a fucking spanner. I think I'm getting lazy as
    well as old.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 14, 2006
  5. Antonio
    Antonio Guest
    Ditto. However I mustered some effort, and managed to extrude the old oil,
    did a few other things like hook up the optimate to condition the battery
    (again).
    Also had a poke around to see how difficult other jobs would be, and
    subsequently got quite depressed about it.
    Warmed the engine up, aside from being a bit smokier than I hoped as it
    always is after a while (which subsided - probably excess fuel/choke to the
    engine) it seemed to idle out ok, but is a bit too tappity sounding for my
    liking.
    Surprisingly black, it was but no sign of contaminates I could see.
    Maybe I have done closer to 1000 x miles instead of 500 from the last change
    after all.
    Even wiuth the oil mesh thing or whatever its called - which I did go to the
    effort of checking over as a proper approach to servicing - was definitely
    showing no signs of wear to the engine so that is a good thing, surely.
    On the bad side, it seems that fork oil replacement and fitting the
    Scottoiler (given I have other accessories) is going to be a real ballache.
    Not from the point of view of fitting the Scottoiler which technically is
    quite simple - its just there SO much to come off like the luggage rear
    rack, mudguards and such. And there ain't any point doing that until I also
    get a MityVac for the brakes bleedin side of things.
    The lack of centre stand, fork drain bolts, & easy access to brakes, chain
    etc is duly noted. Part of the reason I am getting the Scottoiler TBH.
  6. Antonio
    Air cooled engines can also get mayo - my Quota gets rockerboxes lined
    with the stuff in winter and that's even with moderately regular
    50-miles-per-day use.
    I think in that case though it's prolly condensation from blow-by etc.
    and the rocker boxes are like angular cathedral domes that stick out
    in the cold wind.
    Pip Luscher, May 14, 2006
  7. Antonio
    Dan L Guest
    My Zephyr has had a fairly cloudy sight glass all winter, although
    yesterday's inspection of the camshaft revealed it to be very clean indeed,
    no signs of any sludge or other crap in there, and cams as smooth as very
    smooth things, plus very shiny shims.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, May 14, 2006
  8. Pip Luscher wrote
    My (red) GS doesn't and it has been very neglected this winter.
    steve auvache, May 14, 2006
  9. The Ducati's the same - the only time the sight glass hasn't been
    streaked has been on many-hundred-mile thrashes in French summers.
    The Older Gentleman, May 14, 2006
  10. Antonio
    Beav Guest
    I *did* say "superb" VFR.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 15, 2006
  11. Antonio
    Beav Guest
    Yeah, that's me. I know I've got to get the motor out and stripped and I
    know it'll only take me a day and a half (the whole bike seems to need
    ripping apart to get the engine out) and I've got all the new parts except a
    pair of pistons & rings. I could have everything done within a week, even if
    I piss about, but ......
    Could just as easily been oil weeping past the valve seals as anything else
    (choke) too, but the tappity sound is why I'm "about" to rip mine out. I
    hate noises that shouldn't be, in engines.
    Thats one of my pet hates with bikes. They're full of bits that need
    removing to do the simplest jobs.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 15, 2006
  12. Antonio
    Beav Guest
    Yeah, but it's a Guzzi:) Actually, other than condensation, I can't
    understand why it'd get mayo-ed on an aircooled motor, and it'd need quite a
    bit. I used to see a smattering on my VW years ago but never gave it a
    thought and that was used every day.
    And rain.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 15, 2006
  13. Antonio
    Try "vacuum" (pipe) and it may well come easier to you.
    Pip, May 15, 2006
  14. Antonio
    ChrisDC Guest
    I'd rather change the spark plugs on my Drifter than on my V6 Mondeo.
    The Ford's engine compartment is a tightly-packed nightmare, and I'd
    have to strip off some of the inlet manifold before I could even see
    the rear bank of plugs.
    The Drifter's plugs are all visible and accessible. I'll admit that
    you do have to pull off the HT leads before you can undo the plugs,
    but it's easy.
    ChrisDC, May 15, 2006
  15. Antonio
    Beav Guest
    Well yeah, but that's a given. The Drifter's plugs are accessible after all.
    I looked at doing the plugs on the Zed and decided to leave it until it's
    service (this Wednesday) and get the man to do it. Too much electrickery and
    other gubbins under the tank for me to piss about with.
    Easy, but time consuming :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 16, 2006
