my bike was running until one day i changed the throttle cable on it. It took me about three attempts to get the throttle cable on. after the first attempt, i turned on the bike, it struggled a little to turn on. Then I operated again with the throttle cable, then when i went to lite it up, it took a while, it barely would start. Then after the third time, I finished installing the cable like i wanted it to work, when I went to turn on the bike, it wouldnt lite, and it still wont lite upto now. I was guessing that I had flooded the engine with gas. I took out the spark plugs, turn the engine over a couple times for the gas to come out, then I let it dry. The piece of garbage is still not working. I pulled out the carb. I investigated it alittle bit, when i turn the carb to spray, it sqirts the gas out in a straight line out the pump, like a water gun, I read the workshop manual for the bike, and its says that its supposed to spray in a cone shape mizxing the gas and the air. I believe thats my problem. The throttle cable is not binding or anything. Let me know if Im wrong. I must have cleaned the thing out about 4 times and it still doesnt spray like i want it to. Im sure the bike works, I think it maybe the carb. how do i adjust the carb to spray out in a cone shape, is there a screw on too tight or something? Im a regular hangman, so I dont know anything about this bike except from what I read so bare with me. I have no money to get it fixed. Guys please help, Here, visit this page to give a better understanding of what im dealing with, it has pictures of the bike and a mini clip. Its a yamaha visionI need this bike for work, I cant keep busing like this, it takes me bout 1hr and 15 to get to work. I appreciate you reading this. Thanks
