Engine grime cleaning products
Discussion in 'UK Motorcycles' started by Tim B, Mar 22, 2009.
  1. Tim B
    Tim B Guest
    I can't be arsed cleaning the bikes at the best of times. But I've not
    touched them over the last couple of months while doing my bathroom.
    The winter road grime appears to have welded onto the engine.
    Any suggestions for a good cleaning product? I've tried cleaning
    gel/wax, chrome cleaner, some AutoGlym Bike grime/salt cleaning thingie,
    mountain bike Muck Off. I'd thought that using some Scottoiler FS365
    would have given me a sporting chance, but I guess it's no use if left
    in the bottle for a couple of months ;)
    Tim B
    Tim B, Mar 22, 2009
  2. Tim B
    crn Guest
    Start by stippling the heavy deposits with parafin and a stiff paint brush.
    Blat off with a pressure washer, repeat as required.
    For lighter deposits spray with neat Traffic Film Remover, leave for a
    cup of tea, blat it off with a pressure washer.
    CAUTION - some varieties of TFR are rather caustic and should not be
    allowed to touch aluminium. Test a tiny inconspicuous spot first.
    crn, Mar 22, 2009
  3. Gunk or Jizer or similar.
    The Older Gentleman, Mar 22, 2009
  4. Tim B
    T i m Guest
    Is it just me or are all the latest environment friendly /
    bio-degradable cleaners not a patch on the old full fat stuff?
    You could spray some Gunk on some real dirt / crap / grease and it
    would nearly just all fall off, now you need several applications and
    plenty of brushing and it still isn't quite as clean?
    You can tell if something is good as it melts yer gloves. ;-)
    I recently bought one of those bench top cleaning tanks from Machine
    Mart and so far have only used the cleaner they supply to go with it.
    I tried cleaning some of our daughters chainsaw parts and it didn't
    touch any of the real hardened oil / grease at all (like Muck Off on
    my cycle chain). I'll try some Gunk in there and hope the pump doesn't
    mind it?
    I wonder how many hours I spent with my head over a bowl of 4* petrol
    as a kid, cleaning all sorts of stuff?
    T i m
    T i m, Mar 23, 2009
  5. Tim B
    T i m Guest
    I'd forgotten about that! Luckily my back yard is concrete and has
    seen the good de-greasing of numerous motorbikes over the years and
    the kit car (donor parts) when we built it. If a gallon of Gunk was a
    fiver 20 years ago is it still as cheap at nearly £20 / 5L now I
    wonder?
    On a road bike, for things like main stands and engine webs to become
    solid with crud, is it likely they have never been cleaned out from
    new? When I get a new (to me) bike I often flush out 1/2 hundredweight
    of mud from the things (but they are generally just runabouts).
    T i m
    T i m, Mar 23, 2009
  6. Tim B
    Nige Guest
    Also, if you have a tarmac drive it will make a right fucking mess of
    it.
    Nige, Mar 23, 2009
  7. Tim B
    Beav Guest
    If they're rideable, bimble to a car valetter hand him the cost of a pint
    and let him blast the engine with a steam cleaner. 2 minutes, no rinsing, no
    drying, just clean engine cases.
    It's the only way.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 23, 2009
  8. Darsy'll fix it.
    The Older Gentleman, Mar 23, 2009
  9. Tim B
    SD Guest
    Would that be liable to take old, flaky, paint off, too?
    Sounds promising.
    | ___ Salad Dodger
    _/_____\_ GL1500SEV/CB1300SA-9/CBX1000Z
    |_\_____/_| ..99843../..00312.../..32117.
    SD, Mar 23, 2009
  10. I find my biodiesel will eat grease quite well, actually.
    Grimly Curmudgeon, Mar 24, 2009
  11. Tim B
    T i m Guest
    I know it sounds like it's obvious but once turned into a fuel, is it
    'safe' to introduce back in/on-to the ecosystem in anything other than
    small quantities?
    If I'm doing small stuff in the workshop I still like to use some
    paraffin as it also does seem to actually melt grease. Left in the
    cleaning tank for a while the clean stuff can be siphoned off to work
    another day (cos it's not cheap).
    T i m
    T i m, Mar 24, 2009
  12. It's quite degradable. In fact, one of its myriad uses is a contact
    weedkiller.
  13. Tim B
    Tim B Guest
    It's only the engine that's suffering, maybe a quick steam clean might
    help. I was always under the impression that a steam clean was just a
    good way to get moisture in places it generally shouldn't be. Bit of a
    pain that fenders don't look quite so good if they're long enough to be
    functional.
    So of the products suggested sound pretty industrial. I've got some
    meths in the garage, might see if that is similar to paraffin before
    going for the more industrial stuff.
    Tim B
    Tim B, Mar 24, 2009
  14. Tim B
    crn Guest
    Just DONT.
    Meths is even more dangerous than petrol.
    Parafin is cheap enough, get a 4 litre plastic can from your local
    hardware store.
    crn, Mar 24, 2009
