engine flush?
Discussion in 'UK Motorcycles' started by apgamsa, Jul 21, 2007.
  1. apgamsa
    apgamsa Guest
    I've bought a 15 year old Kwak air-cooled twin with 12k on the clock
    and am giving it a thorough going over. Would you recommend using
    engine flush? It's been well looked after and the oil I drained out
    was discoloured, but not terrible.
    Adam
  2. apgamsa
    Buy some cheaper oil and change twice or thrice at 500 mile intervals.
    Timo Geusch, Jul 21, 2007
  3. apgamsa
    Dave Emerson Guest
    "Engine flush" can cause more problems than it solves. Better to just put
    in some cheap oil and change any in a weeks time, remembering to drain when
    it's really hot.
    Dave Emerson, Jul 21, 2007
  4. apgamsa
    I used to use engine flush regularly and never had any of the problems
    people talk about, but I've heard warnings of terrible things
    happening. Having said that, I've never heard a first-hand tale of one
    of these terrible happenings, either.
    These days I don't bother: having never done a control test I never
    knew if it helped or not, so I figured that it probably wasn't worth
    it. Certainly my Guzzi's internals were spotless after 30K miles of
    just using good quality oil changed more-or-less at the correct
    intervals; I never used flushing oil on it.
    If you have doubts about the state of the engine internals then just
    run the engine for a hundred miles or so on cheaper oil and then do a
    proper oil/filter change.
    Pip Luscher, Jul 21, 2007
  5. Don't bother mate, it is a 15 year old Quack, the oil will be out of
    that and marking your passage with a thin black line on the road behind
    you soon enough anyway. Just keep topping it up as needs be.
    steve auvache, Jul 22, 2007
  6. What 'e said but I'd do it at 200 ;-)
    Whinging Courier, Jul 22, 2007
  7. apgamsa
    Wouldn't go past 150, myself.
    Pip, Jul 22, 2007
  8. apgamsa
    Cab Guest
    I think you're all out and wouldn't go past 100.
    Cab, Jul 22, 2007
  9. You fucking liar. I can't remember you changing your underpants at those
    intervals.
  10. apgamsa
    apgamsa Guest
    Nope, black. Have you seen oil coming out red from a bike?!
    apgamsa, Jul 22, 2007
  11. apgamsa
    apgamsa Guest
    OK, I won't risk it if people think it's risky.
  12. apgamsa
    Have you never seen oil before it goes into an engine? Hint: It's not
    black before use.
    _______
    Ace, Jul 22, 2007
  13. apgamsa
    Cab Guest
    Snip the sigs. There's a good chap.
    Cab, Jul 22, 2007
  14. apgamsa
    It turns black.
    YTC.
    _______
    Ace, Jul 22, 2007
  15. apgamsa
    Dan L Guest
    Erm, yes.
    When I changed the oil in the TS50 and used 2-stroke stuff.
    Not very bright.
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Jul 22, 2007
  16. apgamsa
    But it's a pretty good general rule, no?
    _______
    Ace, Jul 24, 2007
  17. apgamsa
    deadmail Guest
    You seem to frequently offer your opinion on motorcycling when you have
    very little experience of it. I can understand why Champ would post
    what he did; I've done the same. It's not because it's "time of the
    month" but it's because you're relatively ignorant of
    bikes/mechanics/riding but post in a confident fashion.
    Many of the posters here have >25 years of fucking about with/riding
    bikes. You've nowhere near this but continue to 'give advice' to new
    posters when frankly you often don't know what you're talking about.
    In this ocassion you had nothing to add so why bother asking questions,
    you couldn't explain from personal experience what contaminated oil
    looked like in any case.
    deadmail, Jul 24, 2007
  18. apgamsa
    deadmail Guest
    *sigh* I was even polite.
    On occasion you post stuff worth reading, just not in the bike threads.
    Oh, and I really don't need advice from you on how to operate a news
    reader thanks.
  19. No that is not what his killfile is for at all. With regard to
    motorcycles and ukrm, newbies, wimmin and other hard of thinkers have to
    be protected from poor advice and if you are giving poor advice it is no
    good having you in a killfile.
    steve auvache, Jul 24, 2007
  20. apgamsa
    ginge Guest
    Maybe you could do a lesson on how to snip posts next.
    ginge, Jul 24, 2007
