Engine Enamel.
Discussion in 'UK Motorcycles' started by Krusty, Feb 1, 2011.
  1. Krusty
    Any tips for brush painting engine enamel to get a good finish? Good
    prep's taken as read, I'm thinking more of brush technique, thickness
    of coats etc.
    Krusty, Feb 1, 2011
  2. Krusty
    Pete Fisher Guest
    Dunno about specific engine enamel but I find Smoothrite satin (not high
    temp) goes on best applied thickly in a warm place to warm metal, thus
    allowing the brush marks to sort themselves out. Keep in a warm place
    until really set and hard with that technique though.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 1, 2011
  3. Krusty
    Makes sense. Finding a warm place will be tricky though, unless I leave
    it in the oven.
    Krusty, Feb 1, 2011
  4. Krusty
    Gyp Guest
    I'd not be brave enough to use a kitchen appliance for a motorcycle
    maintenance related activity.
    Not after the last time
    Gyp, Feb 1, 2011
  5. Krusty
    Steve Guest
    Does it have to be done In Situ?
    Smoothrite Aerosol is marvellous stuff and is a damn near perfect
    match on BMW engine/fork silver.
    Steve, Feb 1, 2011
  6. Krusty
    It definitely won't be done in situ.
    Which would be very useful advice if I was painting a silver BMW engine
    or forkleg rather than a black Triumph generator cover.
    Krusty, Feb 2, 2011
  7. Krusty
    Steve Guest
    Then I would use smoothrite black aerosol which is also marvellous
    stuff.
    You pedantic fucker.
    Steve, Feb 2, 2011
  8. Krusty
    That'll be plan B if the brushing doesn't work. Plan C will be buying a
    new generator cover & ebaying the old one.
    I'm sure extreme pedanticism was listed as a requirement in the UKRM
    welcome pack.
    Krusty, Feb 2, 2011
  9. Krusty
    SIRPip Guest
    I'd have aerosol as PLan A, myself. I've had much better results than
    with brushes. I'll give you a Plan D, though: polish it. I'll polish
    it for you if you haven't got the kit.
    Stone the non-pedant!
    SIRPip, Feb 2, 2011
  10. Krusty
    I would recommend
    www.bikedevils.com/pj1-fast-black-gloss-epoxy-spray-paint-aerosol-1391-p.asp
    bloody marvelous stuff and tough. Warm the part a little before spraying and
    it dries quickly.
    If you need more heat resistance
    www.bikedevils.com/pj1-fast-black-gloss-engine--case-spray-paint-aerosol-1388-p.asp
    is also feckin good
    and they do a full on exhaust paint
    www.bikedevils.com/pj1-fast-black-special-high-temperature-exhaust-paint-17280-p.asp
    though I find on downpipes such things never survive long.
    Hog, Feb 2, 2011
  11. Krusty
    It is also a perfect match for SV650 rear subframe paint
    Lozzo
    they churn out)
    Lozzo, Feb 2, 2011
  12. Krusty
    Steve Guest
    Mine didn't mention it. The bit about Jews yes , but no mention of
    pedants.
    Steve, Feb 2, 2011
  13. Krusty
    That would mean going & buying stuff though, & the nearest place has
    only got matte.
    I've got the kit, but a polished cover on a black engine would look a
    bit weird. This is 'preparing for sale' so I want it standard.
    Krusty, Feb 3, 2011
