Engine cutting out
Discussion in 'UK Motorcycles' started by ben77, May 24, 2004.
  1. ben77
    ben77 Guest
    Hi all,
    I have a problem with my bike that I hope someone can help me with.
    It is a '97 ZX-6R F3.
    I've had the bike off the road for a few weeks and took it out for the
    first time in a while last Saturday. Engine started easily and all
    seemed fine, and same again on Sunday until I stopped for petrol.
    When I restarted the engine it cut out when I pulled in the clutch. I
    checked the sidestand was up but same result. This happened a few
    times until I pushed the bike to a parking space, and after scratching
    my head for a while I tried again and the problem seemed to have gone
    away so I drove home.
    Like a prat I put this down to a freak anomaly and drove the bike into
    work this morning [1]. Come home time I started it up but again the
    engine was cutting out every time I pulled in the clutch, and I ended
    up having to leave the bike at work. My guess is that there is a
    problem in either the sidestand switch or clutch switch. If I
    remember correctly I used to be able to engage 1st gear with the
    engine running and sidestand down, and the engine would only cut out
    when I let out the clutch to pull away; for this reason I'm thinking
    probably clutch switch rather than sidestand. I only need to pull the
    clutch a minute amount before cut out.
    I should say at this point that I know very little about motorcycles
    so my estimation may be way off. I am hoping that I haven't missed
    something obvious, please tell me if I have or alternatively whether
    this sounds like a reasonable diagnosis. If it is how could I go
    about testing before going out and buying new parts? I don't have any
    electrical testing equipment but may be able to borrow some. Or is
    there an easy way for me to bypass the safety circut and verify
    whether or not this is where the problem lies?
    Thanks in advance,
    mb
    [1] Probably not relevant but I noticed the temperature gauge was up
    over 3/4 when I got to work. If it persists I may be posting about
    this again later :0)
    ben77, May 24, 2004
  2. ben77
    SteveH Guest
    IMHO, you're most likely right with that assumption.
    Disconnect the switches, clean up the connectors and try again.
    If you're still having problems with them, then you could always bypass
    the problematic one.
    SteveH, May 24, 2004
  3. ben77
    This is definitely it.
    Champ, May 25, 2004
  4. ben77
    ben77 Guest
    How should I go about cleaning the connectors? A spray with GT85 and
    wipe with a rag? If the problem is still there I would like to try
    bypassing the clutch switch before buying a new one [2], but haven't
    got a clue how. Can anyone give me some idea, or is it just not worth
    the effort?
    Thanks again.
    [2] Even if it's just to get the bike home so I can do the job
    properly[3].
    [3] I use the term loosely.
    ben77, May 25, 2004
  5. ben77
    SteveH Guest
    IMHO, GT85 is too 'oily' for this. I'd try WD40 first, or an electrical
    contact cleaner.
    As for shorting them, then you can do this with a folded out paperclip
    prodded into the connector.
    Should be able to diagnose the faulty switch from this - personally, I
    probably wouldn't replace a clutch switch (I'd just snip off the
    connector and crimp the wires together), although a sidestand switch is
    pretty essential, IME, so I'd replace that.
    SteveH, May 25, 2004
  6. ben77
    Wha..? <shakes head>
    platypus, May 25, 2004
  7. ben77
    SteveH Guest
    You've obviously never suffered the embarassment / pain of being
    catapulted off on the first left hander of the day, then ;-)
  8. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember (SteveH)
    saying something like:
    Oh yes. And you only do it once.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 25, 2004
  9. Grimly Curmudgeon wrote
    You'll learn newbie, you'll learn.
    steve auvache, May 25, 2004
  10. ben77
    What he said. Although I wasn't catapulted off, just very nearly. Sobered
    me right up, that.
  11. ben77
    ben77 Guest
    Well, I took off the clutch switch and tried to clean it up a little,
    and at first it seemed to have fixed the problem because I could pull
    in the clutch without the engine cutting out. But instead it now cuts
    out when I release the clutch to drive away. I managed to get the
    bike home in the end by removing the clutch switch and taping it to
    the handlebars in the disengaged position. But I am now wondering if
    maybe the sidestand switch is also faulty; it does not make sense to
    me that a faulty clutch switch could be causing this latest problem.
    What do you all think? It seems a bit improbable for both to go at
    the same time, but I also seem have a problem with the radiator fan
    not coming on which I guess is most likely electrical so who knows?
    Thanks once again.
    ben77, Jun 2, 2004
  12. ben77
    ben77 Guest
    Somebody, please, I need some help!
    ben77, Jun 8, 2004
