Engine breathless at higher throttle openings
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Nov 10, 2005.
  1. Sorry, i'm sure this problem has been posted before...but when I open up
    the throttle more than just a little bit, the engine wheezes and the
    bike slows down. I can only get the bike up to about 40 mph.
    The bike also makes some clatter when it's idling...maybe valve clearance?
    I just bought the bike, a 1984 KZ700 with 8500 miles. The carbs are
    definitely sketchy and I plan on opening them up but I wanted to have an
    idea what to look for before I went in.
    Thanks for advice! It's always appreciated.
  2. Masospaghetti
    skimmer Guest
    Plan on going through the fuel system and the air intake system and
    cleaning it all out.
    Dirty or old gasoline in the tank. Dirty petcock with fouled fuel
    filter. Fuel float valve dirty, float stuck. Plugged up idle jets and
    idle passages. Really dirty or oil-fouled air filter. Install new spark
    plugs too.
    Maybe. The clutch basket will rattle until you pull the clutch lever
    in. The starter clutch won't stop rattling. It's under the cover on the
    left hand end of the engine.
    Problem could also be a loose cam chain, check the tensioner and check
    the valve clearances.
    Same game as before. Look for the EPA anti-tamper plugs and see if
    they've already been drilled out. If not, you'll probably have to do it
    anyway to remove the idle mixture screws so you can spritz the idle
    passages out.
    skimmer, Nov 10, 2005
  3. Sounds like the diaphragms, assuming it's CV carbs (sounds about right).
    When you take the carbs apart to clean them out (another thing you need
    to do), check the vacuum diaphragms for tears or holes.
    All Kawasaki in-line fours of that era make some clatter while idling.
    The cam chain is the typical culprit, but the valves clatter too if set
    to the best place for assuring good cam wear (towards the loose end of
    the spec). I suspect you have nothing wrong other than typical Kawasaki
    noise, I've never had a Kawasaki that didn't sound like a freakin'
    diesel at idle what with all rattling chains and clattering valves.
    Do check the valve clearance. Also check the cam chain guides at the
    same time. If (when) the cam chain guides wear out, the chain rubs
    directly against metal, making a horrible racket, but on a bike with so
    few miles that's unlikely. Also check to make sure that the cam chain
    tensioner is working okay. I don't recall whether Kawasakis of that era
    had a ratchet tensioner or a manual one, find a service manual. If it
    has a manual tensioner, adjust it. If it has a ratchet tensioner, take
    out the spring (the center bolt on the thingy), pull the tensioner,
    check that it works (push the spring in and watch to see that the "foot"
    sticks out and won't ratchet back in), then reset it to full in and
    re-install. Then push the ratchet with a skinny screwdriver or such
    until you feel it push against the chain guide and make one final
    "click", then re-install the spring. (Springs get old too, and may not
    make that final "click"). That final "click" tends to quieten the chain
    down to reasonable levels, though Kawasaki engines of that era will
    never be accused of being smooth -- they were crude, noisy, and
    rough-idling beasts with the redeeming quality of also being simple
    well-proven technology that even today is relatively easy to maintain.
    You're welcome!
    - Elron
    L. Ron Waddle, Nov 10, 2005
  4. Masospaghetti
    Matt Guest
    Do all the exhaust pipes come to about the same temperature?
    Check the compression and the plug in each cylinder.
    Matt, Nov 10, 2005
  5. Masospaghetti
    P.J. Berg Guest
    Check for missing airfilter or airfilter housing leaks on the filtered
    side(goes lean and will try to stall like you are describing).
    J.
    P.J. Berg, Nov 10, 2005
  6. The bike is actually running with the filter and filter pipes removed.
    If this were the case, would running with the choke on make it run
    slightly better?
  7. Masospaghetti
    P.J. Berg Guest
    In short, yes!
    J.
    P.J. Berg, Nov 11, 2005
  8. Masospaghetti
    Pale Fire Guest
    Probably not, your carburetors most likely don't actually have a choke
    plate. Some slide valve carburetors used on the Kawasaki KZ650 in the
    mid-1970's did have a real choke like a car. When you close the choke
    plate, it makes the carbs suck harder and more gas gets pulled out of
    the float bowls. But, with a constant vacuum carburetor, there is
    usually no choke plate. There is a bypass passage around the butterfly.
    And that passage is a lot smaller than the open area in the carburetor
    throat when you open the throttle butterflies. So no extra fuel gets
    sucked into the engine when you use the newer type of choke, which is
    called a "starter".
    Pale Fire, Nov 11, 2005
  9. Masospaghetti
    P.J. Berg Guest
    And how do you think this starter circuit works? By letting more
    gasoline into the carb/intake, fattening up the mixture. Same function,
    different principle.
    J.
  10. Masospaghetti
    Pale Fire Guest
    I know exactly how it works. There's a plunger (also called a
    "starter") in a bypass passage that goes around the closed butterfly. A
    rather large jet (about 0.6 mm orifice size) in the float bowl supplies
    gasoline. The mixture drawn through the starting enrichener can be as
    rich as 1 to 1.
    But, as soon as you open the throttle, vacuum drops off to the point
    that NOTHING gets sucked through the enrichener bypass.
    This can be demonstrated by the fact that the engine will quit if the
    pilot jets are plugged up. If the starting enrichener was capable of
    keeping the engine running with such a rich mixture as 1 to 1, why
    would it even need the tiny amount of gasoline that would come through
    an idle jet that is 0.35mm to 0.45mm orifice diameter?
    If the enrichener worked like you think it does, it would continue to
    supply enough mixture to keep the engine running with plugged idle jets
    when you open the throttle.
    Go ride your motorcycle and see what happens when you're operating at a
    large throttle opening. You won't notice any difference in engine
    operation the way you would with a plate type choke.
    When you slow down and stop, the engine will run a little rough though,
    with the throttle closed.
  11. Masospaghetti
    P.J. Berg Guest
    This is not correct, it would not be possible to run a bike on a cold
    morning if the enrichment circuit dropped off as soon as you opened the
    throttle, try and see!!
    I was working today with this exact problem! 50cc four-stroke Vespa,
    plunger type cold start circuit(automatic via bi-metal and heat coil).
    Place it outside in the cold and you are barely able to start
    it(Accelerator pump lets you), try to drive away and it does 2Mph and
    sputters till it warms up.
    This proves that the starter circuit does indeed fatten up the mixture
    even as you open the throttle.
    But hey, I@m not here to argue, believe what you want....
    Jørn Berg. In Norway.
  12. Masospaghetti
    Pale Fire Guest
    If you have to open the throttle to start the engine with the starting
    enrichener valve fully open, the idle mixture screws are set too lean,
    or the idle jets are plugged up. An engine with constant vacuum carb is
    particularly difficult to start by twisting the throttle because the
    starter won't spin the engine fast enough to crank up very much vacuum.
    Some of what little vacuum it does make at cranking speeds is needed to
    open the automatic petcock. That's something else that confuses
    newbies. Engine won't start after the motorbike hasn't been ridden for
    a few weeks, even though he has gas in the tank.
    But we weren't talking about a 50cc Vespa, we were talking about a
    Kawasaki 700cc
    I-4.
    That's what you say. The usual routine in this NG is that somebody who
    doesn't know much can't get his machine running right. So he posts a
    query on rec.motorcycles.tech. Then somebody answers him. Then somebody
    else who likes to argue tells the first respondant that he doesn't know
    what he's talking about.
    Let me point out something about the starting enrichener that you may
    not have noticed. The bypass is around 1/4 of an inch in diameter. It's
    pretty much straight. There's no room in the bypass for much of a
    venturi, so there isn't very much pressure diferential to suck fuel out
    of the float bowl. The engine has to suck air through what is basically
    about the size of a straw. That's why the starting enrichener quits
    working when you turn the throttle grip. Not enough vacuum to suck the
    gas up.
  13. I opened up the carbs yesterday, they looked ok. I was concerned that it
    was getting *too much* fuel instead of not enough before but this
    doesn't seem to be the case...
    So running the bike without the air filter and filter pipes could cause
    the problem I am having, to this severity? I never thought it made such
    a large difference.
    Masospaghetti, Nov 15, 2005
  14. Oh, and if it makes any difference...when the engine is warm and I pull
    the choke, the RPM's jump to about 5000(!)
  15. One last thing - I did check compression, it's good (150 psi) and the
    spark plugs are clean.
    The diaphragms seemed alright from what I could tell (pushing them up
    with my finger, plugging the port, and releasing them - they all came
    down pretty slowly) and the two I can see while the engine is running do
    respond to throttle inputs.
  16. Masospaghetti
    Pale Fire Guest
    Have the EPA anti-tamper plugs been drilled out yet? If you can see the
    slotted heads of the idle mixture screws, they've already been monkied
    with.
    The mistake a lot of shade tree mechanics get into is that they expect
    the engine idle speed to increase as they turn the idle mixture screws
    counterclockwise. The engine speed increases to a point, and then
    actually starts slowing down.
    So the shade tree mechanic turns the master idle knob to make the
    engine idle faster.
    And the idle RPM runs away when the engine is hot. The idle RPM will
    also be too high when the engine is on the choke when it's cold in the
    morning.
    If you can't see the idle mixture screws, the EPA plugs are still in
    there and my diagnosis is that your idle mixture passages are all
    plugged up and the engine gets fuel from the starting enrichener
    ("choke") when you open the throttle a lot, but the engine falters and
    stalls at smaller throttle openings.
    Been there, had that problem. Fixed it by cleaning the carbs with
    Berryman's B-12 Chemtool Chose and Carburetor Cleaner in the aerosol
    can.
    You can open up the carbs and clean out the pilot jets and still have
    idle mixture passages full of gum and varnish if yuo don't know how the
    idle mixture passage goes four different ways.
    With the anti-tamper plugs drilled out and the idle mixture screws
    removed (1), you can squirt Berryman's B-12 through the hole the idle
    mixture screw came out of and the
    carb cleaner must squirt out four different ways.
    1. It must come out the hole closest to the idle mixture screw.
    2. It must come out the three holes next to the throttle butterfly.
    3. It must come out the pilot jet.
    4. It must come out the pilot air jet in the intake bell.
    Since you don't have a lot of pressure out of an aerosol spray can, you
    can hold your fingers over some of the holes while you are spraying
    carb cleaner through any of the holes.
    (1) Count the number of turns it takes to lightly seat the idle mixture
    screws in the bottom of the hole. Write those numbers down on a piece
    of paper. When you reinstall the screws, make sure you get each screw
    back into the hole it came out of.
    All four screws should probably be around 1/4th to 1/2 a turn open,
    unless your carbs have extremely small pilot jets.
    With CV carbs, turning the screw clockwise leans the mixture up.
    Turning the screw counterclockwise richens the mixture up. What you are
    trying to do when adjusting the screws with the engine running is to
    get the engine to just start running rough as you turn the idle mixture
    screw clockwise. Then you can turn the screw back counterclockwise
    about 1/8th to 1/4th of a turn to get the engine to run smoothly again.
    Pale Fire, Nov 15, 2005
  17. The tamper plugs are intact.
    I don't fully understand this...because the bike idles fine when the
    starter circuit is off at around 1000 RPM, but even when the bike is
    warm it will rev wayyy up when the starter circuit is enabled. Won't a
    correctly operating bike slow down in this condition, or even stall?
    I thought the bike would be running way too lean, and that the richer
    starter mixture was closer to optimal and this is why the bike would
    speed up so much.
    Again, the air filter and piping is completely disconnected, would this
    alone cause the problem I am having or does it sound like there is
    something else at work here?
    I did run cleaner through it, although I will admit I was not this
    thorough. The carbs will surely be out again soon, and I will do this.
    I had this experience with my KZ750 twin...oh god, what a nightmare.
    Hopefully it was just a weak spark after all.
    Thanks for the response, always appreciated.
    Masospaghetti, Nov 16, 2005
  18. Masospaghetti
    P.J. Berg Guest
    If the airfilter setup is missing and the carbs have NOT been
    re-calibrated with larger mains(might also need larger idle jets), it
    will stumble/hesitate like you describe.
    J.
    P.J. Berg, Nov 16, 2005
  19. Masospaghetti
    Pale Fire Guest
    I'm sorry. I forgot that Kawasaki put a fast idle mechanism on the
    right hand end of the
    shaft that opens the starting enrichener valves. On a car, the fast
    idle mechanism will have some sort of dashpot rigged to a heat
    controlled choke plate, but this mechanism is stupid, it just blocks
    the throttle open a little bit while the choke is on, making Kawasaki
    engines run away whether hot or cold.
    TOG knows about this, I'm surprised he didn't catch it.
    Go to www.partsfish.com and look at the Carburetor Assembly 1 2 drawing
    and you will see"
    13168 LEVER,CHOCK
    16041 SHAFT-CARBURETOR,CHOC
    92022 WASHER,SPRING
    92033 RING-SNAP,E
    92045 BALL,STEEL,1/8"
    92081A SPRING,FAST IDLE SHFT
    39184A BRACKET-ASSY,THROTTLE
    Pale Fire, Nov 16, 2005
  20. X
    Put the airfilter back, it's there for a reason
    The dust particles are going to cause extra wear to the engine
    Brother-Peter, Nov 16, 2005
