Electronic tachos
Discussion in 'UK Motorcycles' started by WavyDavy, Apr 18, 2005.
  1. WavyDavy
    rb Guest
    Routing electrons, it's like herding cats, but some bright spark will
    come up with a way one day.
    Of course you still have to get the holes back to the battery somehow.
    rb, Apr 19, 2005
  2. WavyDavy
    The one on my Quota uses a variant of a standard frequency-to-voltage
    converter chip. The damping could well be electronic as well as
    mechanical.
    If there's a dry joint then the electronics could be playing up.
    Pip Luscher, Apr 19, 2005
  3. WavyDavy
    rb Guest
    In the case of a starter motor circuit the current drawn is such that
    even small increases in resistance cause a significant voltage drop.
    This is a circuit that draws ~140A from a 12V battery. That's a total
    circuit resistance of about 0.085R, of which about 11/12 is the motor
    itself.
    So adding just 0.07R of resistance will *halve* the voltage drop across
    the motor. I can provide workings if you like ;-)
    I'd like to say that the proof was in the eating but in order to route
    the starter cable away from the exhaust it had to be replaced with a
    longer one so it could have been a fucked cable. Either way the problem
    went away after this.
    rb, Apr 19, 2005
  4. WavyDavy
    rb Guest
    It's rusting in pieces now.
    rb, Apr 19, 2005
  5. WavyDavy has brought this to us :
    They are basically just an analogue meter movement. The electronics
    will have a capacitor, which should effectively damp the movement.
    Perhaps the above capacitor is breaking down or going open circuit?
    Harry Bloomfield, Apr 19, 2005
  6. rb brought next idea :
    No need, I will accept that figure. However, the resistance of the
    copper cable varies a totally insignificant amount with rise in
    temperature.
    I would suggest that all you did was fix the poor connections on the
    end terminations of the cable. The connection between cable and lug can
    become high resistance, as can the connection between lug and the bolt.
    Once there is some resistance in a heavy current carry cable, it will
    rapidly become much worse with oxidation due to heat build up.
