Electronic tachos
Discussion in 'UK Motorcycles' started by WavyDavy, Apr 18, 2005.
  1. WavyDavy
    WavyDavy Guest
    As subject.
    Do they have some sort of 'damping' mechanism in them?
    I ask as the NS is now nearly half way through its running in period and I
    noticed that, once the bike has been running for a while, the tacho goes a
    bit wibbly-vague...
    The only reason I can think of is that it has an oil (or similar) based
    damping mechanism and that, when the oil (or similar) gets warm, the needle
    isn't 'damped' into position as well as it should be......
    Is thi the case or is there another reason (bearing in mind it's fine until
    the tacho has been operating for a number of miles and the needle has done a
    fair bit of sweeping round the clock etc...)
    TIA
  2. WavyDavy
    Salad Dodger Guest
    Eee.
    Leck.
    Tron.
    Ick.
    hth
    | ___ Salad Dodger
    |_\_____/_| ..74309../..18302.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, Apr 18, 2005
  3. WavyDavy
    tallbloke Guest
    Well it beats my water cooled FJ
    Read the subject line - YTC :))
    tallbloke, Apr 18, 2005
  4. WavyDavy
    Bear emerged from their own little world to say
    Evidently.
    First we have water cooled FJs, now cable operated electronic tachos. Is
    it the YTCery season?
    wessie, Apr 18, 2005
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    Well, 'ow else do the poor little electrons get all the way up to the
    tacho then? Bless 'em.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Apr 18, 2005
  6. WavyDavy
    WavyDavy Guest
    That would appear to be the best option ATM.
    May I refer Sir to SD's more detailed description......
  7. WavyDavy
    Wicked Uncle Nigel emerged from their own little world to say
    They loom.
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Good night Bear.
    I said GOOD NIGHT BEAR!
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    Well I never! So *that's* why....
    Every day is, without doubt, a school day.
    If only we could find a way to harness their power.
  10. WavyDavy
    Salad Dodger Guest
    No, not you. Rog had a moment earlier.
    | ___ Salad Dodger
  11. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "WavyDavy"
    It's just a voltage meter, so yes, probably.
    Grimly Curmudgeon, Apr 19, 2005
  12. WavyDavy
    PDannyD Guest
    Dunno how the drag thingy works but I think it uses magnetic damping.
    My guess is that a connector or wire is going bad so the tacho receives a
    confusing signal. Might just be water in the electrics.
    PDannyD, Apr 19, 2005
  13. WavyDavy
    WavyDavy Guest
    But it works fine from 'cold' and plays up *only* after its been working a
    while.....
    If it was a bad connection or water, surely it'd be playing up all the
    time...?
    WavyDavy, Apr 19, 2005
  14. WavyDavy
    WavyDavy Guest
    So are these sort of things fixable or would it be easier (i.e. cheaper) to
    just get another tacho from a breaker or can you just pop the back off,
    change the oil for some new 10w/40 and Bob's yer uncle-type-stuff?
  15. WavyDavy
    antonye Guest
    It'll be a bad earth somewhere along the line. Had exactly
    the same happen on an RGV250 where it went all screwy because
    of a bad earth caused by a corroded plug, and then again on
    the 748 when I didn't tighten the battery cable on properly
    after fitting the Optimate lead and the vibrations caused the
    lead to jump and spark on the terminal which sent the tacho
    crazy.
    Check that first, then suspect a bad guage.
    antonye, Apr 19, 2005
  16. WavyDavy
    WavyDavy emerged from their own little world to say
    Not necessarily. If the loom is routed near something that eventually
    gets hot, which happens to correspond to the the location of the fault,
    then it might take a while before it becomes evident. Electrical
    resistance increases with temperature as well as the more obvious
    possibility of expansion causing an intermittent connection.
    I would initially go for the point where the tacho and/or sensor are
    earthed to the frame/engine. This type of fault is typical of a poor
    earth.
    wessie, Apr 19, 2005
  17. It was somewhere around Barstow, on the edge of the desert, when the
    Hum... most things are fixable, but I suspect that the manufacturing
    technique used might preclude it; ie, made down to a price and not
    designed to be taken apart - or more to the point, not designed to be
    put back together.
    The damper is likely a damping coil or magnet or a tiny spring, so
    possibly fixable, but who knows.
    Years since I pissed around with meters, so bear with me if I'm wrong on
    this.
  18. Yes, instruments do frequently have a tiny amount of damping oil in a
    little dashpot for the needle.
    This is one reason why you should never store them upside down - the oil
    eventually leaks out and the needles go wobbly.
    If your NS clocks have spent a lot of their time in Australian mode,
    this could very well have happened.
    And no, this is not a windup, and not based on experience - merely
    repeating something I read in a classic rag. SWK will be along shortly.
    The Older Gentleman, Apr 19, 2005
  19. WavyDavy
    Loz H Guest
    Spot on. Totally.
    The speedo on my 550 used to wobble all over the place for this very reason.
    Not that it had been stored upside down at any time that I know of, but
    because the damping oil had at some point in it`s life leaked out of the
    dashpot that the needle sits in.
    It is repairable, however. On the 550, I had to carefully lever off the
    metal hoop surrounding the speedo body so I could get access to the innards.
    Once I had access, carefully remove the needle, and you then come to a small
    brass dashpot with a pin sticking out that the needle sits in. Unscrew the
    top of this dashpot and that`ll come out with the pin. Now, what you have
    left is the bit you need to refill.
    The oil used in these things is very thick indeed. I ended up using the
    dregs from an old bottle of gearbox oil that I had lurking around. It had
    gone as thick as the Jism of the Gods, and I had to scoop it out with a
    small spatula. Perfect.
    Fill the small dashpot with it, carefully screw the top back on and refit
    the needle. Whether it`s going to work is evident straight away by flicking
    the needle across the scale and seeing how damped it is as it returns.
    All good fun, and an interesting way to kill an hour or two.
    Loz H, Apr 19, 2005
  20. WavyDavy
    rb Guest
    I know someone who always had a problem hot starting a Ford Orion. In
    the end we decided it was because the starter cable ran too close to
    the exhaust manifold and would heat up. The extra resistance caused a
    significant voltage drop at the starter motor and it wouldn't turn fast
    enough to start the engine.
    rb, Apr 19, 2005
