Electronic ignition
Discussion in 'Australian Motorcycles' started by Clive Reynolds, Jul 18, 2003.
  1. Has anybody installed arftermarket electronic ignition on a older bike
    (mine 1974 bmw 750/6)?
    Clive
  2. Clive Reynolds
    Not me but I've got a mate with an R90S who'll be very interested to hear what you find out.
    Knobdoodle, Jul 18, 2003
  3. Clive Reynolds
    Boxer Guest
    Boxer, Jul 18, 2003
  4. On Fri, 18 Jul 2003 07:45:42 UTC, Clive Reynolds
    } Has anybody installed arftermarket electronic ignition on a older bike
    } (mine 1974 bmw 750/6)?
    I've fitted a Silent Hektik (http://www.silent-hektik.com/) unit on my
    boxers. The SH kit is a total replacement, pulse sensor, control box
    and coil. It doesn't use the original trigger can like some other
    aftermarket kits do, so it shouldn't care about can or points, and
    should fit equally easily on any /5 and newer. The control box can
    drive two coils, so you can opt for dual-plugging.
    Utterly coincidentally, I visited Silent Hektik yesterday, and he's a
    cool and knowledgeable fellow.
    The pulse sensor sits on the crankshaft, so you get rid of the effects
    of camchain slap at low revs. The coil mounts against the original
    mounting points; I had to drill and tap an additional hole in the
    bracket so that the coil would mount at a slightly different angle to
    clear the tank and a connector bracket, but this is standard now. The
    control box is about the size of a packet of cigs, just a bit thinner.
    You can see it in http://www.xs4all.nl/~rsteenw/pics/dscn2282.jpg ,
    second box from the right. The finned doodad is a regulator/rectifier,
    also from SH.
    // Rik Steenwinkel '85 R80ST Skippy bike
    // Enschede '91 R100GS/PD The Great Unwashed
    // Netherlands ('76 Honda CB250G Bouwpakketje)
    // "Far away is only far away '90 K75C Kommutabike
    // if you don't go there" '81 MZ TS250/1+LSW Badkuip
    Rik Steenwinkel, Jul 18, 2003
