Electronic Ignition
Discussion in 'Classic Motorbikes' started by Rasman99, Dec 1, 2005.
  1. Rasman99
    Rasman99 Guest
    I'm currently building another Gt750 (kettle). Part of the pile of crap that
    hopefuly will become a decent SOB is electronic ignition which is good.
    but.... the pick up plate has KH250 stamped on it.
    My question is will a KH250 unit work OK on a kettle? or will it burn holes
    in the pistons or cause similar amusing catastrophe's. Anyone any clues?
    Ras
    Gt750 red Gt750 blue (anyone interested) Gt750 grey
  2. Rasman99
    Healey Man Guest
    Yes, they are/were sold as kits for the GT750, and were simple to fit. Mine
    is now called an "electric Kettle"
    Healey Man, Dec 1, 2005
  3. Rasman99
    TOG Guest
    It will work perfectly, as long as you get the timing right. And
    assuming the pick-up plate fits in the Suzuki.
    TOG, Dec 1, 2005
  4. Rasman99
    Rasman99 Guest
    Cheers TOG, it looks like it will fit OK, the wirings another story.
    The wiring bodgery reaches new heights with this one, every concievable and
    some inconcievable connectors/connections have been made along with enough
    tape of varying colours to reach the moon!!
    That self amalgamating tape is a bastard to remove, particularly revolting
    with 2 stroke and years of road crud mixed in.
    Ta
    Ras
  5. Rasman99
    Timo @ Work Guest
    Sounds like you got the bike from the same wizard who worked on the
    'leccy bits on my CB450. I ended up buying a used good wiring loom on
    fleabay...
    Timo @ Work, Dec 1, 2005
  6. Rasman99
    TOG Guest
    Rasman99 wrote:
    Heh. I remember fixing up a Honda CB550, and there seemed to be some
    non-standard wiring round the fusebox. When I opened up the fusebox I
    found a hole melted right trhough it.
    TOG, Dec 1, 2005
