Electrickery - USB
Discussion in 'Australian Motorcycles' started by Peter, Dec 6, 2011.
  1. Peter
    Peter Guest
    I got myself a weatherproof USB lead from
    <http://www.burnsmoto.com/usb-power-socket-weatherproof.php>
    Before I installed this I thought about it and got worried about the fact
    that USB is 5V and my motorcycle is 12V.
    So I got myself a voltage regulator like this
    <http://www.jaycar.com.au/productView.asp?ID=ZV1505&keywords=7805
    &form=KEYWORD>
    12v in will be fused.
    Do I need a fuse on the 5v out?
    Would you wire this up to permanant power or use a relay?
    Will this setup drain the battery even if nothing is plugged in to the USB
    if on permanant power? Does the regulator drain power?
    How long would it take 5v 1 amp to drain a motorcycle battery if the bike
    is not running?
    Peter, Dec 6, 2011
  2. Peter
    TimC Guest
    You didn't read the first sentence?
    "Direct connect to 12 VDC system (Input voltage is DC 12V +/-4)"
    It's got a builtin regulator.
    Nope. It can't supply more than what the input would supply, which
    would blow before anything catches fire. Can't say how well
    engineered the stepdown regulator is though. I had one supplied with
    my GPS, and I was using my GPS normally, and the bike was running
    normally, and then spontaneously the regulator went "*pop*". The
    chinese capacitor disease is spreading to transistors now too.
    Actually, did you read any of it?
    "Contains a built in automatic fuse that resets itself."
    Depends. Do you want to be able to run and charge stuff while you're
    sitting having a coffee? Will you unplug things when you leave your
    bike locked up for days at a time?
    I had all of my accessories wired up through a relay, until I realised
    that I wanted to be able to use every single one of them with the bike
    powered off, and they all take bugger all electricity, and I tend to
    unplug them and take them inside when I get home.
    Not measurably, unless its real crap.
    Depends on how good it is (shunt regulator vs switchmode). Say you
    have a 20Ah battery, then it will either last 20 hours at 1amp output
    (minus the fact that you want to be able to have enough left to start
    the bike, so don't drain it past 5 or 10 Ah. Or if it's a switchmode
    regulator, you might get up to 12/5*20=48 hours (or 12 to 24 hours if
    you want to be able to actually use the bike again).
    Now be warned - I spent 5 days or so in English and Scottish weather
    with my USB socket to the side of the bike mostly out of the weather,
    with the socket populated the whole time. It still corroded and broke
    within 5 days. It may be weatherproof when not being used, but isn't
    the point of one of these to use it?
    TimC
    Of course one does. The other 99 out of a hundred get bitter.
    -- Paula responding to TimC on ARK
    TimC, Dec 6, 2011
  3. Peter
    Diogenes Guest
    No. Your device probably uses a Zener diode.
    http://en.wikipedia.org/wiki/Zener_diode
    Onya bike
    Gerry
    Diogenes, Dec 6, 2011
  4. Peter
    Peter Guest
    I have been a little distracted lately. :)
    Okay. Point taken. :)
    Yes, and not have lights on at the time.
    No. Emergency charger for phone.
    You might want one of these.
    <http://www.burnsmoto.com/usb-power-socket-weatherproof-rubber-seal.php>
    I got one with my socket, you are welcome to it if you are going to use
    it (and I can find it).
    Peter, Dec 7, 2011
  5. Peter
    Peter Guest
    As Tim pointed out, I should have read the website!
    Thanks.
    Have a look at <http://www.ram-
    mount.com/Products/MotorcycleMounts/tabid/128/Default.aspx#/wizard> to
    see if there is something that works.
    I got one when my aldi gps mount failed.
    The Aldi GPS is trashed but I still have the mount somewhere.
    Let me know if you would like me to dig it up.
    Peter, Dec 7, 2011
  6. Peter
    Peter Guest
    I was hoping I could protect the device, not hope the device protects me.
    Peter, Dec 7, 2011
  7. Peter
    Peter Guest
    Subject: Re: Electrickery - USB
    Newsgroups: Peter:aus.motorcycles
    To: Moike <>
    Thanks.
    Peter, Dec 7, 2011
  8. Peter
    Peter Guest
    To: Diogenes <>
    Peter, Dec 7, 2011
  9. Peter
    Chris Baird Guest
    So I got myself a voltage regulator like this Do Want.
    My only concern would be what kind of voltage regulation is inside-- a
    LM7805-style regulator (as 90% of cheap devices like this are) wastes
    the 7 volts it drops as heat, so if you were doing 5V at its maximum
    1amp/5watt, it would really be sucking 12 watts from the battery-- so
    that's 40% efficient at best. So it's not something you would want to
    leave connected overnight.
    On the other hand, a quality mobile phone recharger uses switcher-style
    regulators that have efficiencies of ~90%
    Have you got an ammeter? :)
    Chris Baird, Dec 7, 2011
  10. And no-one has pointed out that the voltage has nothing to do with the
    drain. It's volts X amps that will kill ya. The thing could ask for
    20,000V but if it only uses .00001 Amps then it would be fine for
    days. V times A equals power. There are losses in the system, yes, but
    do you think the Yanks are running on half power with their 110V
    system?
    Kevin Gleeson, Dec 7, 2011
  11. In aus.motorcycles on Wed, 07 Dec 2011 20:43:59 +1100
    Or for much less faffing about you get a tankbag with clear map
    pocket.
    I use an SW-Motech tankring and Bag Connections Bag with a removable
    map pocket. Even had maps in it once or twice, but it works for
    navigator things. You can get a kit to wire the tank ring so you can
    get power to whatever's in the bag or map holder.
    If you use a BagsConnection tankbag other than the one I'm using you can get a GPS
    mount for the bag.
    I highly recommend www.motorradgarage.com.au for fast shipping,
    reasonable prices (compared even to overseas for the same stuff) and top class service.
    Zebee
    Zebee Johnstone, Dec 7, 2011
