Electrickery advise needed
Discussion in 'UK Motorcycles' started by Andy Bonwick, Oct 12, 2009.
  1. Andy Bonwick
    I need some resistive (resistance) wire for a little project I've got
    in mind so where's the best place to buy it from?
    I'm thinking Maplins would be a good starting point but my experience
    of their staff suggests that the useless cunts know even less than I
    do and that could be very dangerous.
    Another question is should I rely on altering the length of wire to
    get the temperature right or should I be sensible and wire in a
    potentiometer of some sort?
  2. Andy Bonwick
    muddy cat Guest
    Nichrome wire and a pot. Why not but a cheap toaster and get the bits
    you need?
    muddy cat, Oct 12, 2009
  3. Andy Bonwick
    Malc Guest
    Just twist the ends together and throw the switch YKIMS.
    I very much doubt if Maplins sell resistance wire (stands ready to be
    proved wrong) but their online catalogue is so useless I CBA to look
    at it. A quick google got this result http://www.resistancewires.co.uk/
    They sell as little as 1m they say.
    Personally I'd use a pot or a model railway controller.
    Malc, Oct 12, 2009
  4. Andy Bonwick
    Steve Guest
    Thats a brilliant suggestion. I want to go on this trip now.
    Steve
    Steve, Oct 12, 2009
  5. Eureka! That's what it's called.
    Paul Carmichael, Oct 12, 2009
  6. Andy Bonwick
    They look like a suitable target for my attention.
    They've even got a handy little calculator so I can work out what I
    need. Hmm, 3mm x 0.2mm tape comes in just right.
    Thanks for that one.
    I might not need to bother if I can get the correct thickness tape.
  7. RS components
    steve robinson, Oct 12, 2009
  8. Andy Bonwick
    Tim Guest
    In message
    http://www.maplin.co.uk/module.aspx?moduleno=2196
    Tim, Oct 12, 2009
  9. Andy Bonwick
  10. Andy Bonwick
    SD Guest
    "28swg Resistance Wire only £6.29"
    SD, Oct 12, 2009
  11. Andy Bonwick
    Cheers.
  12. Andy Bonwick
    Tim Guest
    28swg resistance wire on a small spool.
    "A 28.35g (1oz.) reel of 28swg Constantan (55-60% copper, 45-40% nickel)
    wire suitable for making rheostats etc. Can be used as a thermocouple
    when twisted with copper wire. A temperature difference between the
    wires of approx 25 C gives around 1mV with temperatures in the range 0 C
    to 50 C. Resistance: 4.2ohms per metre. "
    Tim, Oct 12, 2009
  13. Andy Bonwick
    Now I've had a look I can see it's 0.375mm diameter and can be
    soldered, that's good. It's slightly higher value in Ohms/Metre than I
    wanted but I can reduce that easily enough and it's not a lot higher
    than I needed so may not get too hot.
    I wonder if I can flatten it without breaking it? At a guess I'd say
    that if I squeeze it in a vice I could flatten it a bit and still
    leave the ends round to make connecting it easier.
  14. Andy Bonwick
    Guest Guest
    Stainless mig welding wire does a good job of slowing down current. I made a
    set of heated grips with 6 metre.
    Put your multi meter on ohms, clip your tester on 1 end and move the other
    tip along the wire until you get the resistance you want. Simples squeak
    Guest, Oct 12, 2009
  15. Andy Bonwick
    I reckon stainless welding wire will be too thick. I want something
    that's narrow in width and thin enough to be able to form it to the
    shape I want just by pressing on it rather than having to physically
    bend it iyswim.
    I might as well be honest about it and admit that I'm trying to sort
    out a heated visor so I don't get the inside of my visor freezing at
    seriously low temperatures and I don't want to buy a special helmet
    such as the ones sold to people using skidoos.
    It shouldn't be beyond me to sort it out but the last thing I want is
    to melt the fucking wires to my visor. I know that if I buy the tape
    type resistive wire I can superglue it to the visor and 2mm strips
    that are about 0.25mm thick should be flexible enough to do the job
    and not so wide as to make me feel like a polar bear in London zoo.
  16. Andy Bonwick
    bod43 Guest
    A likely tale. You will need to come up with a better
    story than that to cover your hot bondage fettish.
    Elephanters beware!
    bod43, Oct 12, 2009
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    See, ice inside a visor is god's way of telling you to get a car.
    Wicked Uncle Nigel, Oct 12, 2009
  18. Andy Bonwick
    Is that what it is? I thought it was gods way of telling me it was
    time to hit the bar.
  19. Andy Bonwick
    That's so last year.
  20. Andy Bonwick
    geoff Guest
    How much are you looking for ?
    I prolly have some lying around (or know someone who has )
    What's the application ?
    geoff, Oct 12, 2009
