Electrical question(s)
Discussion in 'UK Motorcycles' started by SaladDodger, Jun 23, 2008.
  1. SaladDodger
    SaladDodger Guest
    The battery on the Blackbird has gone all sulky.
    No charge at all last week, so I stuck it onthe optimate.
    Green light. 12.4v
    Thursday - fine. Started; ran; everything. Parked it up for the
    weekend.
    Went to start it last night: nothing. Nada. Zip. Optimate. Green
    light. 12.4v.
    This morning - fine.
    Battery fit for the skip? Or something more sinister? It's not *that*
    old. 2 years, at a guess.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, SaladDodger
    It sounds like *something* is pulling some (small) current somewhere, so
    over a few days it drains the battery.
    IIRC, you fitted something recently, did you not? Did you use a relay?
    If so, is it possible that the relay is powered up with the ignition
    off?
    I saw this once where a normally-closed relay was held open by current
    that drained the battery (it was on my old GL1000).
    If you've got an ammeter put that on the thing and see if you've got a
    drain.
    Wicked Uncle Nigel, Jun 23, 2008
  3. SaladDodger
    ginge Guest
    Sounds like what happened to mine. see if it smells of roadkill.
    ginge, Jun 23, 2008
  4. SaladDodger
    SaladDodger Guest
    I did. A Garmin power lead.
    Er. No. At a guess. Plus, I disconnected the lead on Wednesday.
    It's now completely stock. Except for the alarm - but that's been
    there for *years*.
  5. SaladDodger
    Gazz Guest
    If you dont have a multimeter/ammeter to test the current draw, easiest way
    to see if the bike has something thats pulling the battery down is to fully
    charge the battery, then disconnect the it,
    leave it for the ammount of time it took to flatten it before when
    connected, re-connect it and see if it'll start,
    if it will start, something on the bike is drawing power and killing the
    battery, if it wont start, battery is dying.
    Gazz, Jun 23, 2008
  6. Makes sense.
    The Older Gentleman, Jun 23, 2008
  7. SaladDodger
    Greybeard Guest
    there for *years*.
    I've encountered this before. Again, you'll need to rest it with an ammeter
    ideally, but you could try disconnecting the earth battery lead and leaving
    it off for a short while, then watch it very carefully whilst brushing it
    against the neg pole of the battery in a darkened garage. you *may* see a
    small splash. indicates something may be pulling power.
    If nothing else has been changed, then I'd get the meter on the volt reg!
    they have a habit of dropping a diode and drawing some current in the off
    state.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Jun 23, 2008
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Greybeard
    1. He's got an alarm . That will pull some power. He needs to know how
    much power is being pulled.
    2. Sort your fucking quoting out.
  9. SaladDodger
    Greybeard Guest
    I know, but the alarm should not cause a splash.
    He *needs* a meter, but since he doesn't appear to have one on hand, it was
    another suggestion.
    Or, leave it for a few days as Gazz has suggested.
    No
    Greybeard
  10. SaladDodger
    SD Guest
    No, but it might get the arsehole about the battery being
    disconnected.
    How the flying **** do you think I know the voltage across the battery
    without having a meter to hand? Divining rods?
    FFS.
    SD, Jun 23, 2008
  11. SaladDodger
    Greybeard Guest
    Well then why didn't you just measure the current drawn and then you'd know
    for sure!
    But that would still mean disconnecting the battery and the alarm may well
    get arsey about that if you don't put it to sleep first.
    Greybeard, Jun 24, 2008
  12. SaladDodger
    frag Guest
    SaladDodger scribbled:
    It heard you saying you didn't like it and were going to replace it...
    OTOH, dead battery.
    frag, Jun 24, 2008
  13. SaladDodger
    frag Guest
    Greybeard scribbled:
    Nah, multimeter reading amps (and leads in right holes!), couple of
    croc clips on meter leads. Clip onto frame and onto battery neg
    terminal, then remove lead from neg terminal.
    Multimeter will keep current flowing and show you how much is being
    drawn.
    Alarm is happy.
    frag, Jun 24, 2008
  14. SaladDodger
    SD Guest
    It's not the battery: the new does exactly the same.
    SD, Jul 1, 2008
  15. SaladDodger
    SD Guest
    Right, got it running: 11.8v. Revved it: 11.8v. Lights on: 11.6v.
    Got "Reg/Rec" written all over it, hasn't it?
    Ho hum. No sign of current drain AFAICT.
    Heh. Git.
    SD, Jul 1, 2008
  16. SaladDodger
    Possibly. Measure the output from the alternator before it hits said
    reg/rec. But OTOH it's a Honda. And I'd stick that battery on the
    charger ASAP unless you want to end up with another useless piece of
    lead.
    The 11.8V most likely come from the fact that you're running the starter
    motor and the ignition off the battery without recharging it. Good way
    to kill a battery, as I found out when Carole Nash's Recovery Muppets
    "fixed" my VFR.
    Which meant I had to get it recovered to a proper Honda dealer the
    following week, get it sorted properly and pay for the second battery within
    two weeks.
    Timo Geusch, Jul 1, 2008
  17. SaladDodger
    SD Guest
    It's charging atm.
    SD, Jul 1, 2008
  18. SaladDodger
    SD Guest
    They ain't cheap, either, by the look of it.
    SD, Jul 1, 2008
  19. SaladDodger
    Lozzo, Jul 1, 2008
  20. SaladDodger
    SD Guest
    Ta. £65 plus P&P plus VAT. I'll do some more tests tomorrow[1], then
    order one.
    Now that I've located my workshop manual.
    SD, Jul 1, 2008
