Electrical question from an electridiot
Discussion in 'Motorbike Technical Discussion' started by messenger1, Jul 25, 2006.
  1. messenger1
    messenger1 Guest
    Hi All. 1985 Kawasaki GPz900R. This bike has a totally inadequate light for
    night riding (unless you ride 20kph in the city) so brilliantly (no pun
    intended) I decided to add a set of driving lights. I bought a pair of 55w
    halogen, (H-3 bulbs), running lights at the local surplus store and
    installed them wired in with a relay and toggle switch. I should have
    labeled the damn switch as it was identical to my fan switch and I
    inadvertently left the lights on for an 80 kilometre daytime errand last
    weekend. I didn't notice they were on till I pulled up behind a minivan. I
    shut them off and thought nothing of it, and continued on my merry way till
    the bike started to bog. Checked the usual, fuel was on, so switched to
    reserve and finally it just died. While pulled over on the shoulder I
    discovered I had no battery power left. Got a boost, made it about 20 km
    back till it died again. Several boosts later I got it home and discovered
    my alternator is no longer producing much juice, approx 8 volts at the
    battery while running, bike stops if the battery is disconnected. Was the
    draw from these 2 running lights (coupled with my fan being run all the time
    to keep this bike running cool enough in 26 degree heat) too much for my
    stock alternator? Or was it on its way out already and this simply pushed it
    over the edge? I really need additional lighting to ride this bike at night,
    so any suggestions on how to achieve it without frying anymore expensive and
    nearly unobtainium 21 year old parts?
    thanks all !
    Tom B
  2. messenger1
    Leon Guest
    The lights weren't bad on the 1984 A1 GPZ900R I had a few years ago.
    Have you checked that the battery is OK, it's more likely to be that
    than the alternator that is causing the problem. It's not a good idea
    to disconnect the battery while the engine is running, I think it can
    damage the rectifier.
    Leon
    Leon, Jul 25, 2006
  3. messenger1
    FB Guest
    Yes, you are an amateur when it comes to electrical system design.
    Aren't we all?
    Don't feel bad, we all get caught out by our ass-umptions about how
    much electrical
    equipment we can add to our motorbikes.
    Basically, a motorcycle is a gasoline powered flashlight that you can
    ride on. I hardly ever ride at night anyway, but I once added two
    Carello driving lights, skillfully aimed to illuminate the road
    regardless of which way I leaned as I dashed about in a sporting
    manner.
    Of course the extra load on the electrical system reduced the amount of
    power available for charging the battery, and riding the motorbike
    through the desert in 100 degree heat was bad for the battery too.
    But, more subtle things were happening besides the discharging,
    dehydrating, and sulfating of the poor battery.
    The Big Four Japanese motorbike manufacturers do not make their own
    electrical equipment. They outsource that stuff from a few
    manufacturers of alternators and
    regulators, and what fits one machine will work on another machine if
    the electrical system designer can figure out what kind of connector to
    use to plug in the selected parts.
    Of course the electrical system on a motorbike has a myriad of small
    plastic connectors, and the connectors are there to make it possible
    for a *mechanic* to quickly change parts and still make money.
    It would be far, far better, if every electrical bit had a soldered-on
    terminal (the Brits called them "ring tongue tags" on a business jet I
    once worked on). It might take five minutes longer to hook up the
    terminals, and the mechanic would have to *pay attention* to what he
    was doing, but the terminals would make far better connections than the
    damned plastic plugs that Japan Inc. uses on all of its motorbikes.
    The connectors on an alternator are often bullet and socket type
    terminals like Honda used back in the early 1960's. But the connector
    on the regulator will usually be a square plastic plug.
    How do you connect the alternator to the regulator, if the connections
    supplied by the
    various manufacturers are so different?
    You have to add extra wiring and short pigtail wire harnesses to plug
    the parts together. Every extra electrical connector generates more
    heat, and this causes plugs and bullet connectors to get so hot they
    melt plastic, the turn their insulating sleeves black from heat.
    So, besides replacing your poor dead, dehydrated, sulfated battery, you
    will need to inspect the electrical connections all the way from the
    alternator to the regulator and all the way through the system.
    The bullet type alternator connectors on my Suzuki melted after riding
    at night using the extra lights. The extra plastic connectors and the
    pigtail harness melted. A wire that went all the way to the headlight
    bucket to a headlight switch that foreign models used (but my machine
    didn't have) melted.
    So, check all your electrical connections for overheating, turning
    black, melting, etc., before you start buying alternators and
    regulators. The battery is probably toast, though.
    FB, Jul 25, 2006
  4. messenger1
    FB Guest
    Old dirt bikes were like that, but street bikes use DC to run the
    lights.
    That's still very true. Motorcycles are like gasoline-powered
    flashlights.
    There is enough electrical power to charge the battery and run the
    lights and operate
    some accessories, but the owner needs to realize that all add-on
    accessories have to go through three bottlenecks, which are:
    1) the connector where the alternator feeds the
    rectifier regulator;
    2) the connection by which the rectifier regulator feeds the battery
    and the fuze box;
    3) the ignition switch.
    If any of the three bottlenecks makes a bad connection, the owner won't
    get good results from his accessory lights and his battery will go dead
    and he might even damage the wiring harness connectors.
    FB, Jul 25, 2006
  5. messenger1
    MadDogR75 Guest
    While I'm not familiar with your bike, it's pretty clear.
    The OEM alternator circuit was designed/sized for running
    with a single (55W.?) headlight.
    You just added 110W. of load to the system & rode off.
    The alternator was not up to the new load, (probably overheated),
    and the battery drained, trying to fill in the extra current.
    You might be able to recharge the drained battery, but I am
    worried that you may have fried the alternator or the voltage
    regulator.
    Have them both checked.
    MadDog
    MadDogR75, Jul 25, 2006
  6. messenger1
    Manjo Guest
    FB,
    I agree on all points. It took me a while to realize that the extra
    current I was pulling through the stock circuit for heated clothing was
    frying the reg/rec connector, but was not blwoing the accessory fuse.
    As suggested by the heated clothing vendor, I routed their wiring away
    from the stock wiring, drawing current directly from the battery
    (through a 10 amp in-line, replaceable fuse and a separate ground wire
    to the bike frame). The "new" circuit includes a relay activated by a
    running light circuit activated by the ignition on/off switch. I
    believe a similar set-up would accommodate the extra lights and perhaps
    the fan switch to avoid accidentally leaving these circuits "on".
    Manjo
    Manjo, Jul 26, 2006
  7. messenger1
    FB Guest
    Well, hooking the accessory feed directly to the battery does help the
    motorcycle's wiring harnesses somewhat by reducing load on the wires
    going to the fuse box and the accessory outlet terminal.
    But the alternator and the rectifier regulator STILL have to pass the
    current to operate the accessories, light the lights and charge the
    battery, so the alternator and RR connectors have to be clean and the
    connections have to be tight or the connectors will melt.
    The only way I can think of to get around this connector problem would
    be to install ANOTHER battery that wasn't connected to the motorcycle's
    electrical system at all, and run it TOTAL LOSS, recharging it at home
    or at work by a battery charger.
    There isn't much room on any motorcycle for another lead acid battery,
    they are inconveniently shaped and there is no available space.
    One poster came up with the idea of wiring a whole bunch of
    rechargeable NiCad batteries together in a thin mat that would fit
    under the seat of his motoX bike that he wanted to convert to street
    use.
    A portable NiCad battery pack might not be a bad idea for a commuter
    who just rides about an hour to work and an hour home. He could
    recharge his battery pack at home and at work.
    FB, Jul 26, 2006
  8. messenger1
    John Johnson Guest
    You can, of course, reduce the number of connections in your wiring
    harness (and yes, FB has advocated this in the past).
    The stock wiring harness on my '94 VFR had a connector for the 3
    alternator wires at the alternator. This connector allows the alternator
    pigtail to be separate from the vehicle harness. There is another
    connector at the RR.
    I cut off the connector at the Alternator, soldered the wires together
    and and covered the junctions with heat-shrink and weather-seal. This
    removes one possible corrosion site from the harness, and it's a
    connector that I only ever used to check for corrosion...at that
    connector. Going all-out would involve installing heavier-gauge wire
    from the alternator to the RR, and then from the RR to the battery. That
    eliminates the possibility of melting down the wiring because it's too
    small to carry the current without overheating.
    This strategy does not allow one to pull more current than the RR or
    alternator can supply (without draining the battery), nor does it
    prevent overheating the RR, but that's an entirely different subject
    (though it too has been covered in this group and in many other places
    on the www.
    Later,
    John
    John Johnson, Jul 26, 2006
  9. messenger1
    FB Guest
    It just occurred to me that if you have the automotive style alternator
    behind the cylinder block underneath the carburetors that the brushes
    might be worn out.
    FB, Jul 26, 2006
  10. messenger1
    messenger1 Guest
    Thanks all for the very informative reading! I read all replies and learn
    from it all, although as I age I retain less of it. The brushes are indeed
    done, cooked to charred little nubs. I suspect they have been on their way
    out for some time now, which might explain the premature death of my
    previous battery <?> Bought a newsed alternator on eBay and will repair the
    old one at my leisure, although my track record with fixing electrical
    gizmo's sucks. Still haven't come up with a solution for my inadequate
    lighting however.....I liked the suggestion of a Halogen, but since this is
    unfortunately a sealed beam headlight, in a size that's not common ....at
    least I think it is proprietary to this bike, methinks I'm outta luck there.
    thanks again all!
    Tom B
    messenger1, Jul 27, 2006
  11. messenger1
    messenger1 Guest
    yoikes! Thanks Mark, I double checked it and you are right, I've never
    looked closely at the back of the headlight (joy of a plastic wrapped bike
    eh)till now and it is indeed a replaceable bulb. I have some 65/55 "Bright
    white's" for my Volvo which I'll try in the bike after I find a heavier
    plug. Now I've also learned why the same Volvo burns headlight bulbs at an
    alarming rate....last time I changed a bulb my connector was melted and
    charred, I thought it was because of the dumbass are I had to wiggle my hand
    into to fit the connector, I had just not pressed it on tight enough. When I
    bought the brighter/hotter bulbs I was warned about possibly melting the
    lens on the lights but since they are glass I ignored that! I'm still lost
    on the theory here....if a bulb is 65/55 what difference in current draw or
    voltage or whatever other electrical definition can a similar 65/55
    "brighter" bulb make? I understand the connections having an impact, (I am
    just finishing building a pro street bike out of a KZ750 frame, Z1000
    engine and a bunch of ZX parts, and made my own homemade wiring harness
    which uses heat tubing wrapped, soldered or soldered and ring terminal
    connections).
    thanks again!
    Tom B
  12. A single H4 bulb should be adequate. As for unobtainable parts, ITYF
    they're far from that.
    The Older Gentleman, Aug 5, 2006
  13. <VVBG>
    Positively avant-garde, in fact.
  14. messenger1
    hlblybowski Guest
    First of all, if your headlight was that dim I'd think your alternator
    was going bad to start with. Fix that problem first and see how bright
    it is after that, you might not need extra lights at all.
    hlblybowski, Aug 7, 2006
  15. messenger1
    MadDogR75 Guest
    Basic D.C. Electricity - V. (Volts) x A. (Amperes) = W. (Watts)
    The Volts can be asumed to be constant at 12 (+/-).
    65 Watts. draws 65/12 or 5.42 Amp.s
    55 Watts. draws 55/12 or 4.58 Amp.s
    B.T.W. - If you really need more light, and don't have a lot of
    extr power there are 12 Volt. - 25W. 'narrow spot`sealed beam
    units used for tracklighting that might be fitted. If separately
    switched
    as auxiliaries and used sparingly they might fill your needs.
    They would fit the outdoor holders for some tractor lights.
    MadDogR75, Aug 8, 2006
  16. messenger1
    messenger1 Guest
    yup, just replaced the alternator with a newsed one compliments of eBay and
    the light output has improved considerably!
    thanks all!
    Tom B
    messenger1, Aug 8, 2006
