Bit of a weird problem here. Turn on ignition key, lights are fine, press starter and it buzzes a bit (solenoid) then all electrics die, completely. But bike will still start on the kickstart... And if you leave the bike for a while without loading the electrics the power comes back on, but as soon as you touch touch the 'leccy start it kills everything. Even sometimes putting on the lights loads it too much and trips it. Something is breaking down under load? Cant be the reg/rec or the CDI, because they have nothing to do with the light circuit. In fact you can unplug the reg/rec and take it out the equation. And all the fuses are ok. Battery is fully charged. The bike runs fine when I kickstart it, as do the lights, when it's running, which means it's not getting juice from the battery..? Everything just dies when I touch the starter button, but it can even do it when I even put the lights on... But it all comes back on 5 minutes later.. WTF is that all about? I have checked the battery terminals and all the earths, they seem fine. It must be a wiring problem 'cos there is no other components to break down? If it's a bad earth/connection it's the weirdest one I have come across, it is like a component is breaking down under load, but WTF other components are there on a simple bike like this? It is an NX650 Dominator BTW.
