Electrical or carbs?
Discussion in 'Motorcycle Technical Discussion' started by messenger1, Mar 13, 2005.
  1. messenger1
    messenger1 Guest
    Hi all. I am trying to start my project Z750/1105. Its an 84 Kz750 frame
    with an 82 KZ1000M engine. I have installed a new out of the box Boyer
    electronic ignition. Its wired up as per their instructions. When tested
    individually each plug lead is firing. All plugs are good. Carbs are getting
    fuel, lots of compression. the most I can get is a near start with an
    occasional backfire through the left side exhaust (4-2's). The bizarre thing
    is the pipe on 1&2 is getting warm while trying to start but 3&4 pipe is
    remaining cold. I have tried swapping carbs with no luck. Can anyone tell me
    how I can test the electronics and timing without actually being able to
    start the bike? At first glance it would appear that only 1 plug per coil is
    firing, i.e. firing plug 1 on the left coil and plug 2 on the right coil.
    Anyone ever experienced this or have any idea if its possible? I've wired
    the coils as per the Boyer instructions, common power 12V to positive on the
    left and right coils, and the green from the ignition module to the negative
    on the right coil, black from the ignition module to the negative terminal
    on the left coil. Are the plug leads from the coil position specific, i.e.
    does it matter on the rh coil if #1 comes from the top and #4 from the
    bottom of the coil or vice versa? The Boyer came with a stator plate and
    rotor, I removed all the old components ( stock stator plate points breaker
    etc) from the housing, am I an idiot and should have kept something from the
    old ignition?? Please HELP!!!!! I'm pulling my hair out trying to figure
    this out but have hit a wall.
    tia
    Tom
  2. exhaust (4-2's). The bizarre thing is the pipe on 1&2 is
    When the exhaust pipes are cold, I blame the carburetors...
    The carbs may be a little out of synch, but you can't synch the carbs
    until you get the engine started and warmed up...
    Turn your master idle knob all the way counterclockwise so the throttle
    slides or butterflies are completely closed. Most CV carbs don't have a
    real choke plate, but I understand that some Kawasaki carbs did have
    choke plates. But, if you carbs have the little starting enrichener
    valve on the side of each carb, they won't suck enough fuel air mixture
    past the slides or butterflies to start if the slides or butterflies
    are slightly open. There just won't be enough vacuum to suck enough
    fuel/air mixture to the cylinders. It gets worse if the idle jets are
    plugged up, the engine also needs fuel from the idle jets to start. So,
    turn the master idle knob all the way counterclockwise, and try to
    start the engine without twisting the throttle grip...
    If the engine starts, you can keep it running by holding the throttle
    until the engine warms up, then reset your master idle knob so the
    engine idles at the correct speed...
    Then you can try synching the carbs...
    krusty kritter, Mar 13, 2005
  3. messenger1
    messenger1 Guest
    Thanks thus far Krusty! The carbs I originally tried on the engine were
    Mikuni smoothbores, here's a link to the exact set
    http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=4512521960
    they are totally foreign to me, any tips as to areas of concern to look at
    when I take them apart for cleaning? I've cleaned my cv's many times, but
    have never had any experience with carbs like these.
    Something I should also have mentioned. While trying to start it the second
    time, with the old cv's on it, I actually choked the # 4 carb with my hand
    and while I ended up with a wet hand, the plug was still relatively dry and
    clean in that cylinder?!?
    Tia
    Tom
  4. messenger1
    fweddybear Guest
    This may sound silly, but do you have the plug wires in the right firing
    order ? Was it running before you did any of the work?
    Good Luck...
    Fwed
    fweddybear, Mar 13, 2005
  5. messenger1 wrote:
    They aren't VM29 or VM33 smoothbores at all. Those two smoothbore carbs
    had round slides and they were popular conversion carbs in the early to
    mid-1980's. I can tell that they aren't smoothbores by looking at that
    black choke knob, which you have to pull to the left to apply the
    "choke". VM29 and VM33 smoothbores had a lever that you lifted up to
    apply the "choke". Maybe those are just the stock carbs
    from an early Kawasaki I-4?
    They probably don't have EPA plugs concealing the idle mixture screws,
    so you should be able to remove the idle mixture screws easily, they
    are on the sides of the carbs, 2 on the left side of 1 and 2 carbs, 2
    on the right side of 3 and 4 carbs...
    That type of idle mixture screw adjusts the idle *air* on slide valve
    carbs, so turning the screw clockwise decreases the amount of air to
    the idle fuel/air mixture, making it richer. That's the opposite of
    what a CV carb's idle mixture screws do...
    To synch the carbs, the black covers have to be removed and there's a
    screw under the covers that raises and lowers the slides...
    If the carbs are off the engine, you can do a "bench synch" by turning
    the master idle knob clockwise many turns so the slides come up off the
    bottom of the venturi and then lay 4 rods of the same diameter under
    the slides. If you happen to have 4 drills about 1/8th inch in diameter
    that works good....
    Then you can turn the master idle knob back the other way until the
    first slide just touches one of the rods. Then you can adjust those
    screws under the caps so the other three slides all just touch the rods
    at the same time...
    Then the master idle knob can be unscrewed all the way and when you
    start the engine, you'll have to hold the throotle open until the bike
    warms up enough so you can adjust the master idle knob to the specified
    idle speed...
    I've experienced the same thing, hand choking an engine that's
    reluctant to start. It makes the engine suck gasoline up past the
    needle jet/jet needle orifice, instead of pulling gasoline through the
    idle jets and starter valve, which is what you want to do...
    And, engines can't burn great big drops of raw gas, they like to have
    the gasoline well-atomized, into the finest mist possible, for
    good burning...
    That's why idle jets and needle jets are cross-drilled for fuel/air
    emulsification...
    If you ever got any water into your gas tank, and it found its way down
    into your float bowls and got sucked up into the carbs, the water could
    have combined with the alcohol that's added to gasoline.
    Then that stuff turns into calcium carbonate and blocks the tiny holes
    in your idle jets and blocks the emulsion holes and it all has to be
    cleaned out by very gently poking a fine needle through the holes...
    The needle jet can usually be pushed up or down to get it out of the
    carburetor body, it's just a light push fit. The idle jets are a
    special problem, you should never attempt to remove an idle jet unless
    you have a small slot screwdriver that fits the jet perfectly.
    You need to push hard against the idle jet to keep from slipping out of
    the slot and buggering the jet...
    Also, how are the valve clearances? Are both intake and exhaust valves
    closing fully and sealing the combustion chamber?
  6. I have mixed up the spark plug leads a few times. The engine will
    usually resist starting, but often starts on one or two cylinders...
    On an I-4 with 2 dual lead coils, one coil, usually the left hand coil,
    fires cylinders #1 and #4, the other fires cylinders #2 and #3 at the
    same moment, producing a "waste" spark on the exhaust stroke of one of
    the pair...
    When adding an aftermarket ignition system, the mechanic does need to
    pay attention to where the spark plug leads go, as well as paying
    attention as to which pickup coil or set of points goes to which coil...
  7. messenger1
    messenger1 Guest
    I'm copying all this down for future reference! Valve clearances are within
    specs, the engine has about 500km since a head job by the previous owner (a
    mechanic fwiw). I've cleaned the carbs as best I can, they were very clean
    no deposits all orifices clear, ran a fine wire through them anyhow, blew
    out all available passages with compressed air etc. I now noticed when
    checking the plugs for the 400th time, they will arc up to 1/2" when held
    ungrounded, but will not arc when the plug is grounded (i.e. installed) ???
    any ideas on this ?
    tia!
    tom
  8. messenger1
    messenger1 Guest
    doh!
    Boy do I feel dumb, I went and bought 4 new plugs just for the hell of
    it....and guess what....damn thing sparked right up as though it had been
    ridden all day instead of not been started in a year! Overthinking is the
    death of me, I could not wrap my feeble brain around the possibility of
    something as simple as the plugs!
    thanks all for the invaluable advice and input, anything I've learned here
    is a bonus for me
    regards
    Tom
    (biggest assed grin I've had in a long time, darn thing sounds like a top
    fueler)
  9. Heh. I had that happen with a little Z200 single last year. I'd fitted
    brand new plugs (and points....) and all of a sudden it died.
    "It can't be the plug; it's new."
    Oh yes it was....
    The Older Gentleman, Mar 13, 2005
  10. when the plug is grounded (i.e. installed) ???
    It means that you have about 15KV to 20KV at the plugs but the voltage
    rise time is too slow to overcome the voltage leakage across the
    insulator, so the voltage gets used up before a spark can occur.
    Holding the whole spark plug away from the cylinder head prevents the
    voltage leak...
    Once upon a time, "voltage boosters" were made for spark plugs. All
    they were was an external spark plug gap that fit on the outside of the
    spark plug so the voltage would have to build up high enough to jump
    the bigger external gap before jumping the smaller gap on the spark
    plug. The "voltage boosters" were designed to overcome voltage loss in
    engines that burned a lot of oil...
    Look deep into the spark plugs with a magnifying light that is made for
    inspecting spark plugs. If you don't see a very black ring inside the
    plug, then the plugs have been overheated and the insulation has broken
    down inside. The voltage leak may be internal, instead of across the
    insulator nose...
    I have seen this happen, too, especially on the old-style Champion
    plugs with steel cores. NGK and ND plugs have used copper cores for
    years, the copper is more temperature stable, so the copper core plugs
    can withstand more heat cycles...
  11. messenger1
    messenger1 Guest
    thanks all for more invaluable info! as usual this forum proves to be an
    invaluable resource for any mc related technical questions.
    Tom
    messenger1, Mar 15, 2005
