effects of flat battery ?
Discussion in 'UK Motorcycles' started by mr p, Nov 5, 2007.
  1. mr p
    mr p Guest
    One quick question.. can a faulty/ worn out battery cause a bike not
    to tick over ? It's a cbr 1000F?
    I am thinking that the voltage is just too low, since it will not
    charge up properly. I have a new one on order anyway !
    Simon
    mr p, Nov 5, 2007
  2. mr p
    Don't be surprised if the new battery goes flat too. As it's a CBR I'd be
    checking out the charging circuit before my new battery was fucked by one
    of Honda's shitty regulators. Also check the earth straps as a bit of
    corrosion will cause a voltage drop.
    wessie, Nov 5, 2007
  3. mr p
    TOG Guest
    Oh yes, it can. In fact, some bikes won't run with a totally fucked
    battery.
    Ask Ginge. Coming back from Chimay this summer, the battery on his
    ZRX1200 was *totally* dead (the TC hadn't thought that two days on the
    charger in order to get any life out of it was odd). As we headed out
    from Dover to Schloss Timo, where a new battery awaited, he couldn't
    use the brakes because the current drain caused the engine to die.
    Likewise the indicators, which cut the engine every time they flashed.
    TOG, Nov 5, 2007
  4. mr p
    mr p Guest
    thanks for replies, I have just taken deliver of 300 quids worth of
    spares from David Silver..
    including a new battery. I have never even seen genuine Honda brake
    pads before.. they look lovely. and the mirror was almost the same
    price as the rubbish copies they sell on ebay !
    Simon
    mr p, Nov 5, 2007
  5. An account with Mr Silver is a terrible, terrible thing.
    Acksherly, this I've noticed sometimes. Some genuine parts are nowhere
    near as pricey as you might think.
    The Older Gentleman, Nov 5, 2007
  6. Hmmm... depends on what a "clutch" comprises.
    Complete set of plates, springs, gaskets, whatever: - slightly on the
    high side, but not too bad, given the type of bike, as you say. And a
    piece of piss to replace, as well.
