Ebay and 400/4
Discussion in 'Classic Motorbikes' started by Mark, Jul 26, 2007.
  1. Funnily enough, this is something I've noticed on some other 400 Fours.
    As Timo says, a carb balance should sort it out. They don't stay in tune
    for long.
    Getting the carbs off is an utter, utter bastard, especially if they
    haven't been off for years. The best way is to remove battery, panels,
    and undo all the mountings for the battery/air filter box so you can
    move this unit back a bit.
    Getting the carbs back on is even worse.
    Do a plug chop, check the ignition timing, set the carbs up properly
    (you will need vacuum gauges for this) and I'm 99% sure it'll be OK.
    What utterly *fucks* the carbs is if the bike has been left standing for
    a year or more, particularly outside. A certain ukrm-er came to the
    Chateau in search of a decent main jet from an old bank of carbs I had,
    and I had to open up three carbs out of the four before I found one. The
    others were corroded and gunged to hell.
    And one final tip. Don't, whatever you do, be tempted to remove the
    float bowls with the carbs in situ.
    The Older Gentleman, Jul 28, 2007
  2. Mark
    Mark Guest
    message
    Groan.. but thanks for the info
    I don't suppose they had a vacuum fuel tap, with the feed taken from the N/S
    carb? (is that no 1 or 4 ?)
    Mark, Jul 28, 2007
  3. Mark
    No, it's just a regular tap.
    Timo Geusch, Jul 29, 2007
  4. Don't be silly!
    The Older Gentleman, Jul 29, 2007
  5. Mark
    Mark Guest
    When looking at it from the front or back ?
    Mark, Jul 29, 2007
  6. Mark
    Old Shit.
    platypus, Jul 29, 2007
  7. Mark
    Mark Guest
    Donno, what does Johnny foreigner use as the motoring equivalent to 'port'
    and 'starboard'
    Mark, Jul 30, 2007
  8. Mark
    Gauche and droit. As opposed to 'tout droit' of course, which quite
    obviously means 'straight ahead'.
    _______
    Ace, Jul 30, 2007
  9. Mark
    "Celui-là."
    platypus, Jul 30, 2007
  10. Mark
    Mark Guest
    I said, I don't know
    Your chance to show your multi-lingual skills
    Mark, Jul 30, 2007
  11. Mark
    Mark Guest
    But then I could be French, and even if I can understand English im beggared
    if l will ever speak it !
    Mark, Jul 30, 2007
  12. Mark
    Not sure what that sentence is supposed to mean - the only thing
    that's clear is that you don't seem to be able to speak, or write,
    English properly.
    _______
    Ace, Jul 31, 2007
  13. Mark
    Mark Guest
    You could be on a winner this time
    Mark, Jul 31, 2007
  14. Le blinky-blinky est kaput, por favor.
    Grimly Curmudgeon, Aug 4, 2007
