Eating headlamps
Discussion in 'UK Motorcycles' started by Catman, Dec 4, 2007.
  1. Catman
    M.Badger Guest
    Ta for that. I didn't realise they were so tolerant at low power levels.
    UKRM, learn something everyday :)
    M.Badger, Dec 4, 2007
  2. Catman
    Poor earths can kill bulbs.
    sweller, Dec 4, 2007
  3. Catman
    Vibes kill them too.
    ....or was that chives. Herbidacious!
  4. Catman
    Catman Guest
    Can they? How so, pray?
    www.cuore-sportivo.co.uk
    Catman, Dec 4, 2007
  5. Catman
    Dave Emerson Guest
    Just over-winter under glass.
    Dave Emerson, Dec 4, 2007
  6. Catman
    deadmail Guest
    If they cause the current to fluctuate (like switching the supply on and
    off) to a hot filament I would presume the shock would damage the
    filament with time.
    deadmail, Dec 4, 2007
  7. Catman
    Chicory, surely?
    platypus, Dec 4, 2007
  8. Catman
    Any bulb - a halogen headlight bulb, or a domestic tungsten bulb -
    suffers thermal shock every time it is switched on. That's why when
    you switch dipped beam on, or hit the switch going into the living
    room, it suddenly doesn't work, when it has reached its allotted
    number of shocks (as it were). The good thing about the living room
    bulb is that you get to hear that unique 'ping' as it lets go.
    That's why it is always the dip filament in a H4 that goes first -
    switched on more often, see. But every filament has a hard life and a
    limited lifespan - and time is finite, just like our lifespan, dears.
    Pip, Dec 5, 2007
  9. Catman
    Catman Guest
    Fair point
    Catman, Dec 5, 2007
  10. Catman
    Catman Guest
    Well in the pissing dark today they were 'OK' Frankly they seemed less
    white than the old ones, less defined and generally not awe inspiring.
    I shall be order HID's directly I can find out what the 145 takes as
    SWMBO would like some.
    Catman, Dec 5, 2007
  11. Catman
    indeed: not even a Wheeler-deWitt equation in sight!
    darsy, Dec 5, 2007
  12. Catman
    You may be right there, but on the other hand ...
    Every division of time is finite, yes? A second is a second is a
    second, sixty of them make a minute and sixty of them an hour. I
    could continue, but I sense your attention span (which is definitely
    finite) is approaching its tensile and temporal limit.
    Pip, Dec 5, 2007
  13. Catman
    So? Every division of distance is finite, but distance itself is not;
    similarly many other measurements.
    _______
    ..'_/_|_\_'. Ace (bdotrogers a.t compaqnet.fr)
    Ace, Dec 5, 2007
  14. Catman
    apples/oranges comparison alert!
    darsy, Dec 5, 2007
  15. Catman
    Good analogy. Both dimensions, both fruit.
    I prefer oranges.
    ogden, Dec 5, 2007
  16. Catman
    Jérémy Guest
    Lucky for Zeno you weren't around then, eh? He wouldn't have had a leg to
    stand on.
    Jérémy, Dec 5, 2007
  17. Catman
    one dependant on the Robertson-Schrödinger relation, one not.
    african or european?
    darsy, Dec 5, 2007
  18. Catman
    deadmail Guest
    Er... Space is Deep.
    deadmail, Dec 5, 2007
  19. Catman
    Deep in our minds.
    Man.
    Pip, Dec 6, 2007
  20. Catman
    We are the warriors at the edge of time.
    Pip, Dec 6, 2007
