Eating headlamps
Discussion in 'UK Motorcycles' started by Catman, Dec 4, 2007.
  1. Catman
    Catman Guest
    No, not M. Mangetout but my Sprint ST 1050
    That will be 4 since June.
    Especially interesting when the second one failed in 12 hours on the way
    to work this morning on the dark and windy crooked mile. Still no-one
    seemed to mind my full beam.
    Anyone else having the same problem?
    www.cuore-sportivo.co.uk
    Catman, Dec 4, 2007
  2. Catman
    Steve Parry Guest
    In
    On the end of the failed filament is it broken clean or is there a small
    ball of melted metal
    Broken indicates vibration, ball indicates excess current.
    Steve Parry, Dec 4, 2007
  3. Catman
    JB Guest
    Melted ball end on the filament tails is also the sign for failure when
    illuminaited or for normal end of life failure. Usually associated with
    'facetting' of the filament coils ('sparkly' crystalline facets) which is a
    good indicator of service life.
    I wonder what manufacturer produced these lamps.
    JB
    JB, Dec 4, 2007
  4. Catman
    Dave Emerson Guest
    What brand are the bulbs?
    Only when I bought some cheap bulbs from the local motor factor.
    Dave Emerson, Dec 4, 2007
  5. Catman
    Catman Guest
    Ahh the last two were clean, I'll check these later, when I go shopping.
    I'm guessing cheap bulbs probably don't help.
    Catman, Dec 4, 2007
  6. Catman
    Catman Guest
    The 'cheap' one I suspect.
    Catman, Dec 4, 2007
  7. Catman
    Catman Guest
    Cheap. I'll check when I'm back in the shop.
    Nail <> head interface I suspect.
    Catman, Dec 4, 2007
  8. Catman
    Catman Guest
    I was wondering about that very issue on the way to work.
    He is. He is also planning an HID upgrade over the festive period. But
    it's a time thing.
    Catman, Dec 4, 2007
  9. Catman
    M.Badger Guest
    On normal tungsten lamps it does, but not on halogens. They need to run at
    their rated voltage/current provide the heat to get them in to their
    regenerating cycle. Did you notice a clouding on the inside of the quartz?.
    M.Badger, Dec 4, 2007
  10. Catman
    JB Guest
    Stick some Osram Silverstars or Philips Vison Plus in there. You *will*
    notice the difference.
    Accept no substitute.
    JB
    JB, Dec 4, 2007
  11. Catman
    I only use the Osram Silverstars now, having found that they punch out
    the same sort of light as a 100W bulb, with less scatter and while
    remaining legal and not melting the fucking wiring loom - talk about
    biting the hand that feeds.
    I've always been happy with the headlights in the car, but when a bulb
    cried enough last week, a H7 Silverstar went in. The difference
    between it and its (admittedly 4 year old+) mate is more than visible,
    it's palpable. Brighter, whiter light with a sharper cutoff and in
    the current shitty weather conditions distinctly better penetration
    and less bounceback in mist and spray. Best fit the other one, I
    suppose ;-)
    No substitute.
    Pip, Dec 4, 2007
  12. Catman
    JB Guest
    Indeed. I've been working with lamps in the lighting industry for over 30yrs
    now and I only use Osram or Philips lamps for reference test purposes in my
    lab. They are far, far more uniform in output and as you say the filament
    geometry is bang-on so the beam quality is always optimal. You do get what
    you pay for as with most things in life.
    JB
    JB, Dec 4, 2007
  13. Catman
    deadmail Guest
    message
    Well... HID has got so cheap that this ought to be a consideration.
    I'd agree completely that the Osram lights are great- put them in the
    car ('cos I can't be arsed to **** around with HID because of the CANBUS
    system) and it's a lot better. However, it really doesn't compare to
    the HID I have on the K75.
    Must fit HID to the Pan in due course; once I trust it again.
    deadmail, Dec 4, 2007
  14. Catman
    Catman Guest
    Trying them now.
    Catman, Dec 4, 2007
  15. Catman
    Catman Guest
    Are Dane still the accepted supplier of choice?
    Catman, Dec 4, 2007
  16. Catman
    Nidge says...
    Do us a favour, cut the high beam terminals off them first.
    It's bad enough having one bike in the area ready to melt my retinas.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Yamaha SR250 SpazzTrakka
    Suzuki GSX-R750L
    Lozzo, Dec 4, 2007
  17. Catman
    We'll expect a full report within 24 hours.
    Pip, Dec 4, 2007
  18. Catman
    Mark Olson Guest
    So I came to understand after edumacating myself a bit. However, that
    did not explain how autos implementing Daytime Running Lamps by running
    their headlamps at partial power avoid this problem. I assume they use
    PWM to control the power, but the pulse rate is almost certainly too
    fast for the filaments to warm up completely each cycle.
    So, how do they avoid dramatically shortening the H4 bulbs' life,
    given that the typical GM DRL implementation is main beams at
    <mumble> percent power?
    Mark Olson, Dec 4, 2007
  19. Catman
    JB Guest
    PWM would be far too costly for auto manufacturers. They often just ran the
    high beam filaments of both lamps in series.
    For automotive lamps, the halogen cycle doesn't really start to fall down
    until you reach very low power levels indeed (~20%). The halogen/gas fill in
    these lamps is far more aggressive than you would find in a halogen lamp for
    domestic use, so is still operative at the lower lamp wall temps typical of
    DRLs. The halogen cycle is also reversible. Even if you run a halogen lamp
    at a low level enough to 'boil' some lamp filament tungsten onto the inner
    lamp wall and 'blacken' it, simply give it a few seconds of full power and
    the halogen will 'scrub' the deposited tungsten off and redeposit it back
    onto the filament.
    JB
    JB, Dec 4, 2007
  20. Catman
    Catman Guest
    <fx: Clears throat>
    They work, but it was still pretty much light on the way home
    Catman, Dec 4, 2007
