Easy way to lift my bike?
Discussion in 'Motorbike Technical Discussion' started by joe, Aug 5, 2003.
  1. joe
    joe Guest
    OK... I'm going to attempt to turn myself into a mechanic and do some
    minor things to my ride. What's the best way to lift it up? How cheap
    can I get a lift? What's a cheaper alternative?
    Thanks
    joe, Aug 5, 2003
  2. joe
    Rob Munach Guest
    Harbor Freight? Now that IS quality stuff :>
    also Sears/craftsman
    Rob Munach, Aug 5, 2003
  3. joe
    olsonm Guest
    I paid $80 for the Sam's club lift (search for item # 288826 on
    http://www.samsclub.com) which comes with a universal adapter to allow
    it to be used on bikes that don't have a nice flat bottom area to lift
    them from. I used the adapter as a starting point for a custom welded
    fixture to lift my SV650S. My fixture uses a bolt through a convenient
    through-hole on the bottom of the SV's engine to positively attach
    the bike to the fixture and hence the lift. If you do buy one of these
    lifts, or a similar one, I strongly recommend that you fabricate a custom
    adapter that fits your bike and that you have some way of attaching the
    bike securely to the lift, just balancing the bike on the lift is a good
    way to have it fall off when you remove one of the wheels, etc.
    It's really a joy to be able to get the bike up off the ground, where
    I can work on the carbs, etc. without having to lean over.
    olsonm, Aug 5, 2003
  4. joe
    Steve Calvin Guest
    http://www.cyclelifts.com/
    The "detail lift" works well, at least for V-Stars
    Steve Calvin, Aug 5, 2003
  5. joe
    bowman Guest
    If you have a beam in your garage or the kid's swingset, you could sling it
    and use a comealong. Not bad if you do one end at a time, otherwise you
    might have to chase it around in circles.
    bowman, Aug 5, 2003
  6. joe
    Faye Kinnitt Guest
    I'm with you on that one. If I was to buy one, the Sam's Club model
    with the extra attachments would be the one. My PC800 has an exhaust
    pipe that hangs just a little below the frame members and wouldn't
    set well on a flat platform. Customizing it for a perfect fit for your
    own bike makes a lot of sense safety wise.
    Faye Kinnitt, Aug 5, 2003
  7. joe
    Posah Guest
    :OK... I'm going to attempt to turn myself into a mechanic and do some
    :minor things to my ride. What's the best way to lift it up? How cheap
    :can I get a lift? What's a cheaper alternative?
    Sears sells a functional lift for about $100. Depending on your
    bike, you may need to make some sort of jig or remove some parts
    to use it.
    I bought a $130 lift from Great Northern. It's not great, but it
    works with all of my bikes.
    Posah, Aug 5, 2003
  8. joe
    Phyloe Guest
    I use a come-along and a wire loop over the rafter of my garage. I use
    nylon straps around the frame of my bike and lift it with the come-along.
    Total cost about $35.
    Phyloe
    Phyloe, Aug 5, 2003
  9. You could just make your own, based on a simple design. Check out
    http://xidos.ca/FirstTestStore.asp [1]
    I have a hydraulic lift as well, but the one above is the one I use
    95% of the time. It's just much simpler and it's very stable.
    [1] The page referred to is not completely functional; it is the
    start of what was to be an online store I was going to put together.
    It demonstrates the gist of the lift idea, though.
    Instead of weaving, I should have been reloading
    (remove _NO_SPAM_ to reply)
    98 FLTRI
    83 Nighthawk
    Share yourself: http://xidos.ca/XManager/ReekyLogin.asp
    Home page: http://xidos.ca/scripts/Personal/
    Alaska trip: http://xidos.ca/scripts/Personal/Alaska/
    Road Glidin' Don, Aug 5, 2003
  10. what you want is a fulcrum I believe. You can have some metal pipe bent in
    such a manor that with a handle (to give the leverage needed) I have seen
    them in the motorcycle and go-cart racing. that it will lift your bike just
    like a center stand. you could also use a jack. or you could get a center
    stand, that would always be with you.
    chuck
    Chuck Donahue, Aug 8, 2003
  11. joe
    GaZ Guest
    Any help on lifting/standing a virago to takr the rear wheel off would be
    apreacted too. I 'stood it on blocks' but just about strained my 'nads. I
    cant use a padock stand as it is shaft drive and this makes one side of the
    swinging arm around 4inches lower than the other
    GaZ, Jul 28, 2006
  12. joe
    FB Guest
    Why are you replying to 3-year old threads?
    FB, Jul 29, 2006
  13. If you think it will help, NAPA (a USA autoparts chain) is offering a
    2-ton floor jack and two 2-ton jack stands for $30 US. I had a KZ650
    that is sans a centerstand up on the jack last night. I didn't find much
    of a spot for the jack stands, though. The mufflers didn't seem like a
    good idea.
    The jack has a ring with cutouts that fit around the frame member behind
    the engine quite nicely. Left to right stability is a bit of an issue as
    the ring is not very wide.
    - Nate >>
    Nate Bargmann, Aug 9, 2006
  14. \
    I first put a concrete block on either side of the front tire to keep
    it pointing straight ahead. I have a small 8 to 10 inch vertical
    hydraulic jack that just fits under the Sportster and there is a cross
    bar of the frame at the back of the engine. I pump the jack and as the
    bike is about to lift off the floor, I balance the bike very carefully
    and pump the bike/jack up as it comes off the kick stand. I insert
    about 5 pieces of 2 X 4s handlebar width behind the jack motor side as
    opposed to rear wheel side and let the jack down.
    enquiring minds, Aug 9, 2006
