Early 1200 Bandit Brakes Upgrade?
Discussion in 'UK Motorcycles' started by Ken, Mar 8, 2007.
  1. Ken
    Ken Guest
    Has anyone swapped the original 4 pot Nissins for 6 pot Tokicos?
    If so did it noticeably improve the braking?
    Was it also necessary to change the master cylinder?
    Ken.
    Ken, Mar 8, 2007
  2. Ken
    Ken says...
    Anyone with an ounce of sense and who knows about these things leaves
    the 4 pot Nissins on there. The 6 pot Tokicos are notorious for having
    the pistons seize and becoming spongy. They don't work as well as the 4
    pot Tokico calipers as fitted to the TL1000 or the Nissin 4 pots as
    fitted to Bandit 1200s and the Triumph range.
    I recently stripped a pair of 4 pot Nissins[1] from a 1993 Triumph
    Trident Sprint for a check over. This bike has been sat for years and
    has been seriously neglected. The calipers were like new once all the
    brake dust and road dirt had been cleaned off, not a spot of corrosion
    anywhere. Nissin even anodise the inner faces of the caliper including
    the seal grooves, so they just don't corrode. Tokicos are plain
    untreated alloy and fur up at the first sign of moisture.
    Many club racers who had GSX-R1000 K1 and K2s threw their Tokico 6 pots
    away and fitted the 4 pots off the GSX-R750 K1/2/3 instead. The 6 pots
    were feeble.
    If you fit the Tokico 6 pots you'll be sorely disappointed.
    [1] Exactly the same caliper as the Bandit 1200 has, right down to the
    90mm bolt spacing. All that's different is the Triumph badging.
    Lozzo, Mar 8, 2007
  3. Ken
    rob2 Guest
    My next bike is the 2007 Bandit, 79lb ft at 3700rpm, 0% against rising
    inflation for a naked 5 grand. R1 and GSXR make a 86lb ft at 10,000 rp
    for 8 grand+
    rob2, Mar 8, 2007
  4. Ken
    Ken Guest
    Thanks Lozzo. That's what I needed to know.
    Ken.
    Ken, Mar 8, 2007
  5. Ken
    Eddie Guest
    Amen to that.
    I should've photographed AndrewR's old ones, before I started spraying
    brake cleaner on them: more fur than a teddy bears' picnic.
    Eddie, Mar 8, 2007
  6. Ken
    To be honest, I think you'd have to try hard to improve the brakes on
    an early Bandit.
    You aren't comparing like for like, not even slightly. This only
    reinforces my opinion of you as a fuckwit.
    Pip, Mar 8, 2007
  7. Ken
    DR Guest
    Okay, here's a silly question. As you know, I have a K3 Bandit 1200,
    with the aforementioned Tokico 6-pot calipers. I have recently become
    aware, in a first (right) - hand capacity, of the potential
    shortcomings of said calipers. Is there a simple retrofit (and more
    importantly, inexpensive) replacement which improves things?
    DR, Mar 8, 2007
  8. Ken
    DR says...
    The 4 pot Tokicos from the TL1000 or early GSXR600 SRAD, of which I have
    a fully rebuilt set sitting here belonging to a certain Mr Statto, they
    look like brand spanking new now I have finished them. I believe he
    would like to see the money he's spent on them back, which is 100 quid.
    That's about the same as a set of genuine Kawasaki seals for a pair of 6
    pots, Suzuki seals for the same calipers are cheaper though.
    Lozzo, Mar 9, 2007
  9. Ken
    Get fucking real.
    Try adding floating discs.
    Try adding decent pads.
    Try adding braided hoses.
    Try adding a radial master cylinder.
    I wouldn't call doing any of those things trying hard but they'd all
    improve the stock brakes on any bandit at no great cost per component
    part.
    Andy Bonwick, Mar 9, 2007
  10. Ken
    Pro-Lite discs, HH pads and braided hoses. Any one of the three will
    improve the stock brakes.
  11. Ken
    Andy Bonwick says...
    In much the same way as huge power is only good if you've got handling
    to match, good brakes are only as good as the chassis they are trying to
    stop.
    Lozzo, Mar 9, 2007
  12. Not taking the piss or maybe me being thick but I can understand radial
    slaves being an advantage but not a radial master cylinder. Are the same
    dynamics involved with the master cylinder?
    Mick Whittingham, Mar 9, 2007
  13. Ken
    Just like the ones on my new push-bike,. Heh, my push bike's more
    advanced than my motorbike.
    _______
    Ace, Mar 9, 2007
  14. Ken
    <opens popcorn, dims lights>
    ogden, Mar 9, 2007
  15. Ken
    Probably goes faster these days, too.
    ogden, Mar 9, 2007
  16. Ken
    toad Guest
    Amen to that. A child crying in the next street creates enough salt
    water to sieze my Tokico 6 pots.
    toad, Mar 9, 2007
  17. Gotcha! Thanks.
  18. Ken
    You should learn to look after them then. Adies 9R is six years old
    and the 6 pots still work perfectly well. Those calipers have 30k
    miles on them and have never been stripped and the most I've ever done
    to them is use a manky old toothbrush to remove crud when the pads
    have been changed.
    Before anyone shouts about fair weather riders she uses it to commute
    in the winter as well as summer so it's seen salt plenty of times and
    even though we've got a set of four pots sitting in the garage waiting
    to go on it's only because they've got braided hoses and new pads in
    them and we got them for a sensible price.
  19. Ken
    You can alter the ratio when you change the cylinder and there lies
    the advantage.
  20. Ken
    DR Guest
    A fine idea, but unfortunately I find myself in somewhat pikey
    circumstances right now. I'll have to pass, but thanks for the
    thought.
    DR, Mar 9, 2007
