Earliest four?
Discussion in 'Motorbike Technical Discussion' started by The Older Gentleman, Nov 8, 2006.
  1. The Older Gentleman
    GaZ Guest
    Ok, but that's a mere technicality :]
    that'll teach me to read the post properly, wont it?
    GaZ, Nov 10, 2006
    #41
  2. The Older Gentleman
    B-12 Guest
    Take two aspirins and masturbate. You might get *some* satisfaction
    that way... ;-)
    B-12, Nov 11, 2006
    #42
  3. The Older Gentleman
    Berg Guest
    Who needs the Aspirin?
    J.
    Berg, Nov 11, 2006
    #43
  4. The Older Gentleman
    B-12 Guest
    If I said, "piss off", would you get the point?
    B-12, Nov 11, 2006
    #44
  5. LOL
    The Older Gentleman, Nov 11, 2006
    #45
  6. Indeed. Mind you, the correct stuff is usually wrapped up in hundreds,
    if not thousands, of words of irrelevant waffle.
    Question from a poster: "I'm trying to undo my bike's spark plug, but it
    seems very stiff. Am I doing something wrong?"
    Answer from most posters: "They all do that, sir. Just apply a bit more
    force, carefully. Clean the threads on the plug up before replacing it."
    Answer from B12:
    "First you have to say what sort of spark plug it is. Remember that
    spark plug is not the correct term anyway. The spark plug does not
    generate the spark, because that is handled by radio and gravitational
    waves beamed down from Planet Zarg. Nor is it a plug because (and anyone
    can try this), if you put it in the hole in your bath, the water will
    still leak out.
    Nor is it an electrical plug, because it does not have any wires
    connected to it. I remember some guy in a $tealership trying to sell me
    three NGK B8ES plugs and telling me that, sure, they'd get my computer,
    food mixer and television working. Well, I wasn't paying eight bucks
    apiece for that, so I got in my pick-up and drove 40 miles to the next
    town where I knew I could get some plastic stock and wires, and I made
    my own. You could do the same.
    A spark plug has to be done up tight because if it is left loose and
    just dangling on the end of the wires, then the engine will have no
    compression and it won't run. I thought everyone knew this.
    Get some Berryman's carb cleaner and add a gallon to a piont of petrol.
    It won't actually help the spark plug, but it'll make you feel like
    you've achieved something.
    Next, get a spark plug wrench. Before you do that you'll need to see how
    big the flats are on the spark plug. Some have 16mm flats. Some have
    18mm. Some have really small ones. To do this, you need two stiff
    straight pieces of steel stock. Put them down the spark plug tunnel,
    making sure they're parallel, and measure the gap between the ends.
    Now you know what size plug spanner to use.
    Remember that you have to remove the spark plug cap from the end of the
    plug before you attach the spanner. This is attached to the ignition
    system by a wire. Lots of people call it a spark plug "lead", but
    they're ignorant. It's a wire, like for cutting cheese.
    Push the plug spanner down over the spark plug. Now you have to figure
    out which way to turn it. Try turning it clockwise. People will ask:
    "Which way is clockwise?" Well, it depends on whether you're the clock
    or not. So turn it to the right first. If it's hard to turn, turn it to
    the left. It may turn, but it may also feel stiff and turn reluctantly.
    Get another bottle of Berryman's carb cleaner, and add to a quart of
    vodka. It'll make you feel a lot better.
    Now we're getting somewhere. Continue turning the spanner in the
    wirection you were using before, and if you've done it right, the plug
    (OK, I've proved it isn't a plug, but we'llcall it that for the moment)
    will fall out. Remove the spanner.
    Now we have the problem of how to get the plug out of what may be a long
    tunnel in your bike's engine. I'll cover that next week."
    #46
  7. The Older Gentleman
    oldgeezer Guest
    The Older Gentleman schreef:
    I recently heard that Hoyt fell of a twig.
    Cannot say I miss his postings.
    But I sure would miss B-12 if he fell off his bike (twig is not what
    I'd like to fall off for a biker).
    Apart from the fact that in between all lines B-12 writes
    there many times is a valid remark, he makes this
    group fun to read.
    If we all reacted like TOG: 'Buy the fucking manual'
    this group would be a dull read, even if TOG is correct.
    Rob.
    oldgeezer, Nov 11, 2006
    #47
  8. The Older Gentleman
    oldgeezer Guest
    B-12 schreef:
    You lost points in my 'like_to_read_table' FB.
    Rob.
    #48
  9. Oh, I miss some of his ravings because they were so *funny* as he tried
    to twist and turn and do anything rather than admit he was wrong. The
    time when he refused to believe that a Honda 250 Rebel had vertically
    split crankcases, for example. He even cited "experts" he knew who said
    it was rubbish. In desperation, I suggested he just looked at one....
    Oh yes.
    Oh yes.
    Oh yes.
    #49
  10. The Older Gentleman
    B-12 Guest
    Well, like I said before, I pretty much ignore all the usual suspects
    in this group, but occasionally TOG starts jumping up and down and
    squeaking, "Pay attention to me!
    I'm important here, too!" Then I have to notice him a little bit, until
    the next tantrum.
    B-12, Nov 11, 2006
    #50
  11. The Older Gentleman
    B-12 Guest
    Oh. It has a previously concealed sense of humour.
    It's not a savage with dry stick, after all...
    B-12, Nov 11, 2006
    #51
  12. <G>
    You really have no idea, sometimes.
    I mean, you're the man who maintains that the purpose of this is to
    permit the Blessed with Insight (you) to impart their wisdom to those
    not so similarly blessed....
    Which is, of course, another Wrong.
    #52
  13. The Older Gentleman
    John Johnson Guest
    [snip]
    ROFL!
    Later,
    John
    John Johnson, Nov 11, 2006
    #53
  14. Heh. Seriously, though, any more thoughts? Because I can't think of one
    before the LE Velo, and there *must* have been one. Mustn't there?
    Didn't someone make a water-cooled Vee twin between the wars?
    chateau.murray, Nov 13, 2006
    #54
  15. The Older Gentleman
    Bob Scott Guest
    writes
    You'd think so. Mind you, I'm toiling to think of any between the LE &
    the CX but there must be some I'm overlooking.
    If they were obviously neither wildly memorable nor particularly
    successful. There, that should guarantee some-one reminding me of a
    staggeringly successful & hugely memorable example in the next hour or
    two.
    Bob Scott, Nov 13, 2006
    #55
  16. The Older Gentleman
    John Johnson Guest
    I've got a reference to a Williamson flat twin, from before the 1st
    world war. The engine was originally produced by William Douglas for a
    cyclecar. If a "Liquid-cooled side-valve four-valve flat twin" from 1913
    counts, there you go. Reference from "The Ultimate History of Fast
    Motorcycles, Roland Brown. Paragon Publishing, 2005.
    If you want V-twins, I'm not so sure. AJS had a supercharged V4 with
    water cooling in 1939. Did they make twins as well? I also see
    references to "large water-cooled twins" by DKW from about the same
    time, but I believe that they were 2-strokes.
    Later,
    John
    John Johnson, Nov 13, 2006
    #56
  17. Yay! You star. Knew there had to be something, even if I've never heard
    of the Williamson!
    They were. Supercharged, as well, some of them.
    There's one in the Sammy Miller Museum in southern England, along with a
    sign saying that on full chat, it could be heard eight miles away.
    The Older Gentleman, Nov 13, 2006
    #57
  18. The Older Gentleman
    John Johnson Guest
    <stunned> I taught ToG something?...Hey, does that mean that I'm getting
    old?!?
    As for the Williamson, it's notable that the cylinders were oriented
    longitudinally, not transversely. It was also made on your side of the
    pond, and the book has pictures of the thing, so maybe it's in a museum
    or something.
    Later,
    John
    #58
  19. The Older Gentleman
    oldgeezer Guest
    Did you read
    http://www.motorcycle-uk.com/lmm/updates/birthofmotorcycling.html
    I suppose the water cooled twins they talk about are all trikes. Not
    sure about
    that.
    Rob.
    oldgeezer, Nov 13, 2006
    #59
  20. The Older Gentleman
    oldgeezer Guest
    While we are at it, does anybody know about the first five cylinder?
    I recall a bike (five cilinders in a star, like the airplane
    engines in the 1st world war), with no gear box, air cooled (I better
    say that the cylinders had cooling fins so I think it was
    air cooled). It also had a leather drive belt with short wooden
    V-shaped blocks rivited (sewn?) onto the leather so it was like
    the later V-belt, and a lever that pressed a roller on the
    flat outside of the belt, which made it work like a coupling.
    The rear pully was a big one, almost the size of the wheel.
    That all was bolted onto an (in my memory) almost standard
    bycicle frame.
    If you think of an aircraft engine, the propellor was on
    the left hand side, but replaced by a small drive pulley.
    It was owned my someone my father knew, but I don't know
    if he was a friend of my father or a customer that wanted
    something be repaired. I only saw it once.
    Could also be that the owner was a former pilot with
    left over spare parts who decided to create his own
    bike. I haven't got the faintest idea.
    Glued to that memory is the year 1917, but I could be
    totally wrong.
    Rob.
    oldgeezer, Nov 14, 2006
    #60
