Earles Fork Handling
Discussion in 'Classic Motorbikes' started by sweller, Nov 18, 2007.
  1. sweller
    I have a 1971 MZ ES Trophy. Marvellously styled earles fork'd 250 two
    stroke [1].
    It handles very nicely; certainly a lot better than the C15 and
    Superdream I had.
    However, If I put a heavy load (say two Moto Guzzi barrels and heads) on
    the rear rack the handlebars shake to the point of losing control if I
    take my hands off the bars.
    I'd like to sort it out before I load it up like the little red donkey it
    is and take it to Elmerland in January.
    What could be the cause?
    [1] For those who haven't seen it:
    http://www.sweller.dynalias.org/mzes250/
  2. sweller
    deadmail Guest
    Dunno. I've got a steering damper you're welcome to. Bought it for the
    sidecar but it seems unnecessary after I've set it up.
    deadmail, Nov 18, 2007
  3. sweller
    It'll cruise at 60 quite happily but it's a nigh-on 40 year old two
    stroke. I used to use it regularly as a commuter on a similar journey.
    Not every day, 2 or so times a week but that was on B roads.
    Dual carriageway constant thrashing wouldn't be good but I think economy
    would be the killer. It runs at 33:1 two stroke mix and about 40ish to
    the gallon.
    Possibly not at all.
  4. sweller
    What type of steering damper?
    Hydraulic would be impossible (or at least very difficult) to fit. The
    MZ dampers are friction type. I have one for the later TS but it's
    missing an important bit.
  5. sweller
    No, yes, maybe.
    I've checked the obvious but in reality I think it's the weight lifting
    the front up enough to cause the shimmy. I'll see if I can get an OE
    damper.
  6. sweller
    deadmail Guest
    Kawasaki design.
    It's a hydraulic one; fits to the fork and then a frame tube or similar.
  7. sweller
  8. By the time you've fully loaded it for the Winter Madness, you might
    find it doesn't bother at all. My TS250, with full loading of rear box,
    throwevers and tank bag would handle fine, but I usually made sure the
    heavy stuff was within the wheelbase.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Nov 18, 2007
  9. sweller
    veeeal Guest
    Is that a partially worn Michelin M38 I see before me? IMO that's
    likely to be a contributory factor. I don't know why, maybe some
    mismatch with the profile/tread/wear pattern and ES250 geometry, mine
    does the same but strangely not on knobblies. You could try varying
    the pressures, setting the shocks on hard or something, I'd be
    interested to know if you cure it.
    veeeal, Nov 18, 2007
  10. sweller
    deadmail Guest
  11. WTF are you smoking?
    Austin Shackles, Nov 18, 2007
  12. sweller
    I think the cutest part is the D-lock on the front wheel. I mean,
    wildly optimistic or what?
    I certainly looks like they have...
    _______
    ..'_/_|_\_'. Ace (bdotrogers a.t compaqnet.fr)
    Ace, Nov 18, 2007
  13. sweller
    Stops the little bastards from a few doors up wheeling it off down the
    road. Which they did once. It is now, thanks to darsy, lashed to the
    front of the house.
    Not so oddly biker types turn their noses up at it. Girls, however,
    specifically Brighton type girls seem to like it and will initiate
    conversations about it. I've even scored on the basis of that bike so I
    reckon it's a winner.
  14. sweller
    Brighton, Hove: it's a nold two-stroke.
    platypus, Nov 18, 2007
  15. sweller
    Usual suspects have already been mentioned. However, ISTR Earles-forked
    BMWs had two pivot points for the front swinging fork, one for solo and one
    for sidecar hauling. I can't see clearly in the picture, but this might be
    something worth checking.
    Magnificent.
  16. sweller
    Pete M Guest
    Accompanied by the sound of a chisel on slate
    If you're ever in the Czech Republic, there's a brilliant little bike museum
    near Celákovice that is literally full of ancient, weird and wonderful old
    MZs and stuff.
    http://a84.ac-images.myspacecdn.com/images01/106/l_0ac489bc62908e8d74dc868656875f6b.jpg
    http://a324.ac-images.myspacecdn.com/images01/104/l_64e235c7c2f3f530970833affdbb570b.jpg
    http://a434.ac-images.myspacecdn.com/images01/108/l_60e33ae797f99efc80e8d6e6dd896269.jpg
    The last one is a '71 MZ something or other..
    Pete M - OMF#9
    "Save your breath for cooling your porridge!
    W&P Range Rover V8 Turbo
    Scorpio Ultima 24v
    Tatra 805
    Pete M, Nov 18, 2007
  17. nono, that's "smoking out".
    Austin Shackles, Nov 19, 2007
  18. sweller
    you sick fucker.
    darsy, Nov 19, 2007
  19. sweller
    Rich B Guest
    Sucking his keyboard for inspiration, Austin Shackles typed:
    Brighton? That's smoking gadgees, innit?
    Rich B, Nov 19, 2007
  20. sweller
    Paul Friday Guest
    Lots of weight, far back. The bike is oscillating about the steering
    head.
    Get the weight forward - tape some cardboard or foam to the tank and
    carry the barrels in a rucksack worn back to front (and don't fall off).
    Paul Friday, Nov 20, 2007
