Ear Plugs
Discussion in 'Australian Motorcycles' started by Matt, Oct 7, 2003.
  1. Matt
    Matt Guest
    My problem is not so much a whistle as a low down throbbing wind noise. I
    think it is turbulence due to the screen on the ZZR250 being designed for
    short-arsed people, so when I am on it my head is in the boundary of the
    flow off the screen and the main airflow.
    Yeah, I know I think about it too much. Probably cause I'm on freeways too
    much :(
    Matt, Oct 8, 2003
  2. Matt
    Matt Guest
    Nice in theory, but the money fairy hasn't been visiting of late.
    Matt, Oct 8, 2003
  3. Matt
    Nev.. Guest
    Try stuffing a hanky or a rag into the gaps in the foam under your ear near
    the chin straps.
    Nev..
    '03 ZX12R (almost)
    Nev.., Oct 8, 2003
  4. Matt
    sharkey Guest
    I hate that little prick. Keeps leaving teeth in my wallet.
    -----sharks
    sharkey, Oct 8, 2003
  5. Matt
    Frosty Guest
    I had some custom plugs made by these guys...
    http://www.hearingtech.com.au/enhanced.htm
    Foam plugs made my ears itch on a long ride but these are great. I've worn
    them several days in a row on a long ride with no problems
    They have an agent in Sydney
    Ride safe,
    Frosty, Oct 8, 2003
  6. sure how many do you need/want
    __
    Cheers
    The Happy Drunk
    K100RT
    The Happy Drunk, Oct 8, 2003
  7. well I will just put them back in the despenser and see if they notice
    __
    Cheers
    The Happy Drunk
    K100RT
  8. Matt
    Matt Guest
    Do you mind if I ask what they cost? From their website it would seem to be
    the way to go. Thanks. And thanks to everyone else that replied.
    Matt, Oct 8, 2003
  9. Matt
    MikeH Guest
    How do you know someone else has not "borrowed" them before you and put 'em
    back............... they'd be super squidgy.
    MikeH, Oct 8, 2003
  10. Matt
    MikeH Guest
    I agree totally. I noticed if I close the gap down between jacket collar and
    lower edge of helmet, it cuts noise down hugely. I will try some sort of
    scarf rig (or balaclava with wooly ear covers) one day to make it more
    permanent. Much better than ear plugs cause it's stopping wind turbulence
    between whole side of head and helmet. With ear plugs inserted, you still
    pick up wind turbulence on your neck just below your ear and on your face
    just in front of the ear giving a drummy sort of sounds. Easily shown by
    brushing finger tip over the skin around the ear and you can hear it more in
    some places than others.
    I reckon its an area totally unexplored by bike accessory mobs.
    MikeH, Oct 8, 2003
  11. Matt
    MikeH Guest
    Don't forget the coathanger wire in the ear before the silicone goes off.
    Then you've got handles.
    MikeH, Oct 8, 2003
  12. I think you just answered your own question :)
    __
    Cheers
    The Happy Drunk
    K100RT
  13. Matt
    Matt Guest
    I agree with what you are saying about the turbulence still being there when
    using ear plugs, however I have found that my neck warmer, when tucked into
    the helmet, doesn't do much to reduce the turbulence. The other problem is
    ease of use. Its a hassle to use ear plugs AND somethink else stuffed into
    the helmet, and in summer there is also the wind issue.
    I tried a balaclava, but found that they are hard to place evenly under the
    helmet and often end up blocking my side view. One thing I have noticed is
    that when I hunch up my shoulders the flow over my neck region is
    significantly reduced/smoothed and most of the wind noise is prevented.
    Makes it kinda hard to ride though :)
    Matt, Oct 8, 2003
  14. I have a set of custom ear plugs I got from an ear doctor, they are
    fairly stiff and the helmet deforms my ear slightly causing them to be
    uncomfortable to use, so I use the silicone putty type of ear protection
    and put up with limited use out of each one. I have a narrow ear
    openings so the round foam type hurt my ears after a few minutes, so I
    cannot use them for riding.
    Mark
    Mark Hutchison, Oct 9, 2003
  15. Matt
    Middy Guest
    Cheaper still ... do what I did. Every time I dug my ears I would save the
    wax. After 6 months I had enough to make my own earplugs.
    Middy
    Middy, Oct 9, 2003
  16. Matt
    vinyl Guest
    Works best mixed with navel-lint and bum-fluff
    vinyl, Oct 9, 2003
  17. Matt
    Frosty Guest
    Hi Matt, sorry for the very late reply. It's been ages since I've been in
    here.
    The plugs were about $200. Pretty reasonable considering how they go about
    it.
    They take a mould of your ear and send it away to have the plugs made.
    Ride safe,
    Frosty, Oct 29, 2003
