dynojet or not
Discussion in 'UK Motorcycles' started by RJAG, Feb 26, 2005.
  1. RJAG
    RJAG Guest
    opinions welcome. been recommended not after talking to a few friends I've
    been warned to stay away.
    wots your opinion on your dynojet kit , how hard was it to setup correctly
    and has anyone fitted it to a Y2K R1 (been told I need a power commander
    too, but I thought they were only for fuel injected bikes).
    Robin
    RJAG, Feb 26, 2005
  2. RJAG
    I've just had a dynojet removed from my 7R, and it (along with the
    setup) has made the power curve smoother than a baby's bum. And more
    linear than Mr Linear of Lineartown, Nebraska. (for Blaney)
    ogden, Feb 26, 2005
  3. RJAG
    Dynamic Guest
    I've been reading reviews for the FZR, and people say that the dynojet kits
    give you more power top end, but you loose the more road usable power lower
    down. On a bike like an R1, I'm guessing you can't keep it pinned on the
    road, so unless it's mainly for track use, it would most likely just make
    your bike less user friendly.
    May be different on the R1 mind?
    Dynamic, Feb 26, 2005
  4. RJAG
    ogden says...
    That can't be taken as a condemnation of the Dynojet kit. It may well
    have been fitted to correct the fuelling on your bike when it was fitted
    with a non-standard exhaust. The Dynojet kit on my bike has filled the
    hole in the power at 5K revs and it carburates beautifully throughout
    the whole rev range.
    Lozzo, Feb 26, 2005
  5. RJAG
    SP Guest
    I had a stage 1 dynojet kit put on the GPX600R, I was asked whether I
    wanted it for mid-range power or top-end power [1] on set-up, I chose
    the mid-range power and it performed very well. I haven't had it done
    to another bike that I've owned, but that's because the guy I went to
    stopped doing it, and I've not had any recommendations for anyone with
    a clue about setting up bikes with dynojet kits.
    So, in essence I would be prepared to have a dynojet kit fitted to the
    CBR, but only on recommendation from someone who's had it done and is
    satisfied with the end result.
    [1] I was told that if I chose the top-end set-up then the mid-range
    power would be compromised, and it was down to personal choice.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Feb 26, 2005
  6. RJAG
    http://www.pre.org/image003.gif
    The Red lines are with the kit, the green ones are with stock parts
    put back on.
    ogden, Feb 26, 2005
  7. RJAG
    Kiran Guest
    Ok, just to clarify, the "duff power" curve is with the full race system and
    the dynojet kit set up for that race system, or with a dynojet kit with a
    stock exhaust system?
    Kiran, Feb 26, 2005
  8. RJAG
    Ginge Guest
    Just because a dynojet kit is fitted doesn't mean the carbs are set up
    properly. Looking at your power curve it seems the bottom end fueling
    was mostly what was screwed up, which is as much down to float height as
    anything.
    The 5K flat spot would have been due to needle height..
    Someone with a bit of nouse (and an air/fuel meter stuck in the exhaust)
    could probably have got the dynojetted setup just as smooth, given a bit
    of dyno time..
    Ginge, Feb 26, 2005
  9. RJAG
    WavyDavy Guest
    Having a bike put on a dyno and the fuelling sorted is worth it on *every*
    bike as long as the dyno operator knows what they are doing.
    A dynojet kit can make this process easier.
    Fitting a dynojet kit without access to a rolling road dyno and someone who
    knows what they are doing is probably not worth doing as its a lottery as to
    whether it'll be better or worse when the 'kit' is fitted.
    My own opinion is to have it done and find the time and money to get the
    bike to a dyno and, maybe, change the gearing.
    After having the R6 dynojetted it was worse.
    Having the fuelling sorted by Sam Ermolenko (twice world speedway champion,
    now a dyno-fella in Derbys) at Sam's Dyno it was loads better.
    Letting him drop the gearbox sprocket one tooth after that made it
    accellerate harder & faster than my 955i from 70 in top (as I found out to
    my horror shortly afterwards[1]).......
    [1] It didn't before[2]
    [2] Not just it didn't accellerate harder. It didn't accellerate at all
    when you opened the throttle. Now it'll go for the redline in top. Well I
    think it will. It'll indicate 180mph (wrong, I know, by at least7%) and
    still be accellerating when I bottle out.....
    WavyDavy, Feb 26, 2005
  10. RJAG
    Ginge Guest
    Ahh you've used him... and he's good, yes?
    Might throw the ZRX at him once I get a Quill T3, K&N, etc..
    Ginge, Feb 26, 2005
  11. RJAG
    WavyDavy Guest
    Good, yes. Worrying that he didn't realise that th R6 had the speedo driven
    by the gearbox sprocket and so was now een more wildly optomistic. But
    adamn nice chap and got the fuelling sorted lovely-like (hardly any change
    in peak power (up by 0.1bhp) but soooomuch better you wouldn't believe it)
    If you've got the cash why not throw him the bike and see what he can
    do/recommend. If it's owt like the R6 it may be better without the K&N....
    PS. Yes, he will be getting a visit from the NS once it is run in (and
    hopefully before the BOSM)
  12. RJAG
    Ginge Guest
    Sounds like what RMD in Heanor did for my old R6.. No flat spot at all,
    popped the front wheel up off the power way too easily.
    Having read up on ZRXes the K&N is a good idea over the cheap stock Kwak
    paper filter... there are alternatives, but not many unless you ****
    about with the airbox any more than removing the restrictive plastic
    snorkel.. I don't want to go too extreme.
    Mmmm. Petroley.
    Ginge, Feb 26, 2005
  13. RJAG
    The duff one is with the dynojet kit set up for K&Ns and the race
    system - I've got the dyno charts from when it was all done and
    it looks much better than it was when I had it tested in November.
    The good curve is stock carb parts, K&Ns and OE exhaust as set up
    by PDQ.
    ogden, Feb 26, 2005
  14. RJAG
    ogden says...
    Someone either chose the wrong combination of tuning parts/jets or
    didn't spend the necessary time needed to set the fuelling up on a dyno
    once they'd fitted them. Your experience of Dynojet kits is not the
    norm.
    You can't just lob a race exhaust system and K+N air filter on the bike
    and think that fitting a Dynojet kit straight from the box will sort the
    fuelling all through the rev range. They need careful setting up on a
    dyno, which yours obviously hadn't had.
    Lozzo, Feb 26, 2005
  15. RJAG
    simonk Guest
    simonk, Feb 27, 2005
  16. RJAG
    Not far off (111.9)
    ogden, Feb 27, 2005
  17. RJAG
    Kiran Guest
    Damn. You see, it's that 0.1 that makes *all* the difference.
    Kiran, Feb 27, 2005
  18. RJAG
    DR Guest
    Namedropper.
    DR, Feb 27, 2005
  19. RJAG
    simonk Guest
    Oh no, that's you and porl now - a split is developing in the hitherto
    unshakeable unity in shamurai bike choice - what /am/ I going to do?
  20. RJAG
    simonk says...
    Do what you normally do, and buy something totally unsuitable.
    Lozzo, Feb 27, 2005
