Ducati & WSB
Discussion in 'UK Motorcycles' started by Andy Bonwick, Nov 8, 2007.
  1. Andy Bonwick
    Here's one for the race enthusiasts to ponder:
    If the Desmosedici is so good then why don't Ducati make enough to be
    able to use it in WSB and stop crying about being at a disadvantage
    and needing 1200cc to be competitive against the Japanese
    manufacturers 4 cylinder offerings?
    It's supposed to be loosely based on the 2006 MGP bike so it should
    have the handling to be able to do the business and the engine should
    good enough to make it competitive against a GSXR1000 (or whatever Jap
    bike you choose) so I'm struggling to see why they insist on being
    able to bend the rules to suit themselves.
  2. Andy Bonwick
    antonye Guest
    It's not the fact that they aren't competitive, because
    they are, it's the *cost* involved in making them competitive
    which is where Ducati have an issue. It takes a whole load
    of money to tune the 999 to the power level of a Jap-4. I
    can't remember the figure toted but it was something like
    3x the cost of the bike itself.
    The spirit of SBK is to keep them close to production
    bikes. Even when Max Biaggi's GSXR was running a single
    exhaust system, they still had to keep the other exhaust
    as a dummy because you cannot change the silouette of
    the bike according to the rules.
    Besides, Ducati want to retire the 999 now and move
    with the times. Going to 1198cc for the R version, and
    hence the one that gets raced in SBK, will allow them
    to put less money into tuning the bikes and keeping
    them at a level which is still competitive with Jap-4s
    now and in the future. It also means they could possibly
    field more than one team, which would be better for
    the spectators.
    If they did run the 'sedici, there would be no market for
    the 1098. It's not all about winning races, it's also about
    selling bikes.
    antonye, Nov 8, 2007
  3. Andy Bonwick
    GungaDan Guest
    This is the argument I've heard, but if it's impossible to make to
    make a V-twin configuration competitive at a reasonable cost then
    maybe they should make a 4 cylinder road bike - and develop that
    instead. I don't see why the championship rules should be rewritten
    just because Ducati are running a bike with two few cylinders.
    And anyway, is there going to be a rule which prevents them spending
    the same amount of money as they have been doing - and dominating with
    the new bike?
    Actually, thinking about it, they may be forced to run air restrictors
    but ICBW.
    GungaDan, Nov 8, 2007
  4. Andy Bonwick
    Ducati V4. Where have I heard that before!
    Hog, Nov 9, 2007
  5. Andy Bonwick
    GungaDan Guest
    Well yes, they have something of a track record, I believe. But
    seriously, I don't understand why they don't produce a 4-cyl bike in a
    properly affordable kind of way. Obviously the Desmosedici doesn't
    count as properly affordable.
    Manufacturing costs might make it a non-viable proposition, I suppose.
    GungaDan, Nov 9, 2007
  6. Andy Bonwick
    antonye Guest
    It's tied in with homogolation of the engine. The 1098 range
    has a lot of refinements that have filtered through from SBK
    which enables them to get more power from the engine. To do
    the same tuning to the "basic" 999 engine within the rules
    costs them a lot of money, but by building this into the
    standard 1098 engine, they have a better platform to start
    with. You wouldn't believe how restrictive the SBK rules
    are; for example, things like valve sizes, lift, duration,
    angle, etc, are all part of the rules, so if you wanted to
    change these you'd have to homogolate the changes into the
    new bikes.
    But as I keep saying, a lot of it is also driven by the
    marketing department as they need to ditch the 999 asap.
    There isn't, but you have to remember that the 999 is now
    5 years old and has therefore had 5 years worth of race
    development done to it. It has reached the point where
    the team have done all they can with the engine as it is.
    Yes, they must run 50mm air restrictors. They also have to
    run 6kg heavier than four cylinders (168kg to 162Kg). These
    rules are subject to change during the championship should
    any machine be seen to have an advantage.
    Don't forget the history: when SBK first started it was
    750cc fours vs 1000cc twins, and the racing was close.
    The twins edged ahead and the fours were no longer
    competitive. Honda even created a twin to beat Ducati at
    their own game, which they did by one point! The Japanese
    manufacturers lobbied for the change to allow 1000cc fours
    to compete against the twins and this was granted in 2003
    and it took two years for them to surpass the Ducatis
    again. Luckily, in 2006, Bayliss came back and kicked arse
    to ride the nuts off the 999 and give it a win that it
    really shouldn't have got as the fours were now way ahead.
    The pendulum swings both ways, and this time it's heading
    back in both Ducati and KTM's favour with twin cyl engines.
    antonye, Nov 9, 2007
  7. Andy Bonwick
    Eiron Guest
    Eiron, Nov 9, 2007
  8. Andy Bonwick
    Henry Guest
    I'm still a bit befuddled as to why Honda built a perfectly good WSB v-
    twin, won WSB, then ditched it.
    <presses button>
    after all, how much power can one use ?
    Henry, Nov 9, 2007
  9. Andy Bonwick
    antonye Guest
    Because it was about winning the championship rather than
    winning sales.
  10. Andy Bonwick
    GungaDan Guest
    Yeah, I suppose running two fantastically expensive race outfits is
    what they're trying to avoid.
    Anyways, I was actually referring to the inherently higher production/
    manufacturing costs of a V4 road bike compared to an inline 4 - what
    with all the cam shafts and timing gubbins. Maybe they couldn't shift
    them at a price people would be prepared to pay and that's why they
    stick to a V2.
  11. Andy Bonwick
    antonye Guest
    No, it's because they have no technical knowledge about
    building in-line engines, so they never will. This is
    a direct quote to me from Livio Lodi who is the curator
    at the factory museum.
    The V4 project the tackled by bolting two V-twins together,
    then guessed the rest!
  12. Andy Bonwick
    GungaDan Guest
    Eh? I'm not saying they should build an inline 4, I'm saying that
    maybe the cost of developing and manufacturing a mainstream (Ducati)
    V4 road bike would be prohibitively expensive and wouldn't find a
    market. Which is a shame.
  13. This just has the ring of truth.
    Plus, of course, there's the marketing angle. Ducati is utterly
    associated with vees.
    I find it interesting, though, that BMW has managed to diversify
    successfully into inline fours, triples, singles and parallel twins....
    The Older Gentleman, Nov 9, 2007
  14. Andy Bonwick
    Eiron Guest
    So what about the 16v inline 4 that Ducati made in 1965?
    There are photographs in 'Ducati Motorcycles' by Alan Cathcart.
    Eiron, Nov 9, 2007
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Eiron
    It was supposed to be a V twin, but the engine guy was a bit pissed that
    afternoon.
    They don't like to talk about it.
    Honda GL1000K2 (Fallen apart) Suzuki TS250 "The Africa Single"
    Norton 850 Commando Kawasaki GTR1400
    Wicked Uncle Nigel, Nov 9, 2007
  16. They tried it 40 years ago and haven't tried it since? Sort of backs up
    what I said.
  17. Andy Bonwick
    Xavier Guest
    I don't completely agree. The 1200/2cyl rule has beeb copied from the
    AMA SBK, and it's not intended for Ducati only. Buell, KTM and BMW are
    likeky to run their own 1200/2cyl bikes. And afaik, Buell is far from
    ridiculous in AMA SBK.
    Xavier, Nov 12, 2007
