Ducati wheel - sorted :-)
Discussion in 'UK Motorcycles' started by YTC#1, Jun 30, 2008.
  1. YTC#1
    YTC#1 Guest
    Finally found someone who could/would do the work. Most people ran a mile
    when the found out the damage, not being a simple buckle meant
    "specialist" equipment.
    Som top marks go to
    ST Motorcycles of Grantham Lincs.
    http://www.freewebs.com/stmotorcycles/
    72.80ukp , inc return postage.
    Got the discs back on, hopefully the tyre will be done tomorrow (helpful
    neighbour sorting as I am up and out early all week).
    Richard can have his paddock stand back soon :)
    YTC#1, Jun 30, 2008
  2. With great care, I hope, as it's possible to get them slightly 'out'.
    The Older Gentleman, Jun 30, 2008
  3. YTC#1
    suer Guest
    Really nice guy and does an excellent job too. We took a buckled
    wheelrim up to him a couple of years ago for a while-u-wait repair (took
    the dogs for a long walk for couple of hours, then came back and picked
    it up). Works from a little workshop next to his house in a small
    village. Had a long chat about bikes and a long chat about dogs before
    we left!
    suer, Jul 1, 2008
  4. YTC#1
    YTC#1 Guest
    Now you say :)
    I'll have to check them now....
    Can you explain what you mean by "out" ? And how not to be "out" ? Please
    YTC#1, Jul 1, 2008
  5. Ideally, you need to mark the position of the disc relative to the
    mounting bolts, and put it back in *exasctly* the same position it was
    in before.
    I know, I know, in theory it should make bugger all difference. In
    practice, after a wheel straightening, it can be fractionally out and
    it'll feel like it's warped.
    The Older Gentleman, Jul 1, 2008
  6. YTC#1
    antonye Guest
    Mark it once you've mounted the disk and then make sure you
    tighten the bolts in a crosswards pattern, hand tight then
    torque them up.
    Using a front paddock stand, spin the wheel then apply slight
    pressure to the brake and you might feel them catch if they
    are not mounted right.
    If that's the case, remove and rotate by one mounting bolt
    and then repeat.
    Worst case is six positions (bolt holes) per disk and two
    disks, so you have to do it twelve times.
    Highly unlikely that it'll be out though if you torque them
    down right, ime.
    antonye, Jul 1, 2008
  7. YTC#1
    YTC#1 Guest
    I noted the "unscrew in a criss cross pattern", but failed to mark disc
    Bugger bugger bugger bugger bugger bugger bugger bugger.....
    Oh well, I'll let you know, it was dropped off tonight to have the tyre
    put back on and balanced.
    Fingers crossed.
    Now, just need to work out the permutation of rotating both discs until
    back in right spot...
    YTC#1, Jul 1, 2008
  8. YTC#1
    YTC#1 Guest
    Done that bit right :)
    Looks like Richard will have to wait for it back then :)
    Ta
    YTC#1, Jul 1, 2008
  9. Chances are it'll be OK. I know it can happen, because it happened to
    mine.
    The Older Gentleman, Jul 2, 2008
  10. YTC#1
    RichardA Guest
    No probs, keep it as long as you need it.
    Richard
    XJ900S
    BOTAFOT #138, YTC#18, OMF#12
    Email-remove insult to reply
    RichardA, Jul 2, 2008
  11. YTC#1
    YTC#1 Guest
    Well, its on, I did as AntE said and span and felt , all seemed ok. Need
    to get it to the MOT station next.
    If it needs messing with, I'll do it after that.
    YTC#1, Jul 2, 2008
