Ducati belts and shim check
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 2, 2009.
  1. Done for £169. Who said Dukes were expensive to fettle? Mind you, it
    didn't need any shims changing and IIRC the closing ones are about a
    tenner each....
    Bike got a general health thumbs-up as well.
  2. The Older Gentleman
    Nige Guest
    Steve Dale, my tame spanner monkey has a 8SS that he's doing up, really nice
    it is. I can't remember the exact model number. To nice for me to wreck over
    winter, but it could be a nice addition to the conservatory :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Suzuki GSX-R600 Racebike
    Nige, Jun 2, 2009
  3. The Older Gentleman
    Andrew998 Guest
    Where was that then? Mine's due a bit of tlc!
    Andrew998, Jun 2, 2009
  4. The Older Gentleman
    DozynSLeepy Guest
    I'll answer that next week when I get the bill. It's going to be at
    least £300 to replace the scored clutch plates and housing before I even
    go anywhere near replacing belts and checking valve clearances.
    When the previous owner says they're getting rid of it because "the
    clutch is a bit much for me - this can be resolved by changing the slave
    cylinder according to Anthony Espindola". It really means they've fucked
    the clutch, and changing gear is a combination of luck, blipping the
    throttle, luck and kicking the shit out of the gear lever.
    DozynSLeepy, Jun 3, 2009
  5. Pro-Twins, Godstone, Surrey.
    The Older Gentleman, Jun 3, 2009
  6. The Older Gentleman
    Andrew998 Guest
    Ah, my servicer of choice anyway! I just wish they'd do loaners because
    they're such a pain to get to.
    Andrew998, Jun 3, 2009
  7. The Older Gentleman
    Careless bunch of cunts, I look away for a moment and what have you gone and
    done!
    That was a new stack of plates and springs, the basket was fine, it was
    checked, and Ducati John went over the bike with a fine comb before
    collection. New head and wheel bearings too. I can't remember if the
    slightly dodgy front discs were replaced or whether that was a £ too far for
    me.
    All that said the standard clutch basket isn't great and there are good
    aftermarket ones available with titanium insert faces where the plates
    engage.
    Anyway, I think Donald has already discovered the more pleasing differences
    between 996 and CBR600 engines
    Hog, Jun 3, 2009
  8. The Older Gentleman
    TOG@Toil Guest
    Ain't that the truth. I had to trundle the bike down on the trailer,
    because obviously the engine has to be stone cold for the shim check,
    and I left the trailer with them, went on to work, and put the bike
    back on the trailer when it was done and trundled it home again. Not
    such an arse-ache as it sounds, actually, but that's one of the
    advantages of having a decent trailer.
    TOG@Toil, Jun 3, 2009
  9. The Older Gentleman
    DozynSleepy Guest
    The specialist, Eddie of ERS Racing in Dunfermline sounded quiet
    disappointed that someone had managed to **** a nearly new set of
    plates, probably by riding the clutch.
    You definitely replaced the brake disks.
    I was looking for a different experience from the Honda and boy have I
    got it.
    Honda CBR600RR engine start:
    Press starter button. A slight noise comes from the starter and the
    engine fires turbine smooth into life.
    Ducati ST4s engine start:
    Press the starter button.
    This releases the chains holding Dr Frankencati. A sound of heavy chain
    being dragged emanates from the engine area, somewhat like a tin of
    nails being shaken. You can hear Dr Frankencati manically shouting "Live
    my beauty, live" as he pulls the levers that slowly breathe life into
    his creation, wheezing and pulsing the monster is finally alive.
    DozynSleepy, Jun 3, 2009
  10. The Older Gentleman
    Nige Guest
    Thats the truth alright :)
    Nige, Jun 3, 2009
  11. The Older Gentleman
    Sounds to me like the big ends are on the way out ;o)
    D if you start it with the clutch held in all is queit!
    Hog, Jun 3, 2009
  12. The Older Gentleman
    I don't think C is cack handed, sounds like something has been amiss.
    Hog, Jun 3, 2009
  13. The Older Gentleman
    Suzuki RGV250 engine start:
    First, remove the tank...
    ogden, Jun 3, 2009
  14. The Older Gentleman
    antonye Guest
    Ouch! Clutch dragging maybe? Did you have the span adjuster
    wound all the way in, as this might have been enough to do it?
    If you want a clutch, I have a second-hand one with plates out
    of my 748 (replaced with an STM Evo slipper) that I will part
    with for some beer tokens.
    antonye, Jun 3, 2009
  15. The Older Gentleman
    DozynSLeepy Guest
    I only picked up the bike on Saturday, so it was caused by the previous
    owner. Although I would have appreciated full disclosure of the state of
    the clutch before I'd flown 400 miles to pick it up. Took it to a
    specialist straight away who examined it and showed me the scoring on
    the plates and the basket.
    Damn, he's already ordered the parts. Although I think for purposes of
    guaranteeing work it's probably better for me to stick with genuine
    Ducati this time round.
    He did make a slight adjustment to the span adjuster when he put the
    clutch plates back in, which has been a significant improvement in that
    I can now go up and down the gears first time.
  16. The Older Gentleman
    antonye Guest
    Ah, I see.
    Cool. Make sure that the chain is adjusted correctly as well,
    as this really does make a difference in getting the gear
    change right.
    If you suffer from the heavy clutch then fit an aftermarket
    slave cylinder to help reduce the amount of force needed
    to engage it. Kiran bought one for his 1098 and it fitted
    quite easily and he said it helped.
  17. The Older Gentleman
    DozynSleepy Guest
    snip
    Bad form to reply to your own posts, but it's been brought to my
    attention that my opinion of the the previous owners description of the
    clutch may have been a bit harsh.
    Just to clarify, I *was* shocked with the difficulty in changing gear
    and I was glad that most of my journey home was motorway. I'm pretty
    sure the previous owner genuinely thought it wasn't that bad, which I
    guess goes to show how gradual changes can become familiar.
    DozynSleepy, Jun 4, 2009
  18. The Older Gentleman
    TOG@Toil Guest
    This reads like one of those The Doctor vs. The Prophet threads.
    TOG@Toil, Jun 4, 2009
  19. The Older Gentleman
    says...
    "The jangle of the light chain which restrains the Keys of Power breaks
    the stillness of the misty early morn, the harsh clack of the
    appropriately named kill switch is followed by a moment of silence as
    the energising button is depressed - this signals the first stirrings of
    the monster, the unholy creation of Doctor Frankencati. The
    incomparably chilling sound of heavy chains being dragged across a
    subterranean floor of broken stone emanates from deep within as the
    monster takes its first breath.
    The manic cries of Doctor Frankencati: "Live, my eldritch beauty,
    live!" break into the unwilling conciousness of the villagers as they
    tremble on their mattresses of damp and mouldering straw, clawing their
    rags over their terrified heads. The Doctor, pushed over the edge of
    madness by the exhilaration of forbidden creation, relapses into
    incomprehensibility as he wheezes and drags the actuating levers that
    breathe fresh life into the monster.
    Shuddering and pulsing, the monster is dragged once more from the sleep
    of death, back into life."
    Like that, you mean?
    (Apologies to Donald for ripping off his text)
    Pip, Jun 8, 2009
  20. The Older Gentleman
    DozynSleepy Guest
    Superb.
    DozynSleepy, Jun 23, 2009
