Ducati 620 monster help
Discussion in 'Australian Motorcycles' started by Jason Burton-Woods, Jul 18, 2004.
  1. Gday again,
    I'm about to look at a Monster 620 that was built 12/2001, could this mean
    it has the 02 specs (I think in 02 the monster took on Fuel injection).
    Reason I ask is i've seen a few Jap bikes that have had this trait of taking
    the next years specs during the last month of the prior year - so I'm now
    not 100% sure if it is the 01 model.
    I have a couple of low res pictures already, would there be any obvious
    differences to be able to spot that its a 01 or 02 model. (no - cant make
    out the CP info either!)
    I cant make out if the front suspension has adjustability - I know that was
    new for 02... they both seemed to have 320's and dual pot brembos..
    I know - all I need to do is go look at it, but I cant get there for
    another week, the person selling is no use since they're selling it on the
    owners behalf - they really have no idea.
    Any thoughts???
    Thanks
    JasonBW - Wollongong
  2. Jason Burton-Woods
    Biggus Guest
    yes, save your money... get a real bike.
    Biggus, Jul 18, 2004
  3. Jason Burton-Woods
    SmeeR1100s Guest
    if it is a 620 its definitely an efi model.
    the 600 were carbed.
    and ignore biggus and hatz as they are one and the same and very multi
    personalitied
    SmeeR1100s, Jul 18, 2004
  4. Jason Burton-Woods
    Biggus Guest
    You are cruel.. but ask Roop or Slej, them knows the trooth...
  5. Thanks for the heads up :)
    I appreciate that, good stuff, so to clarify, did EFI only come out in 02
    JasonBW
  6. Jason Burton-Woods
    John Guest
    Good bike Jason, steer clear of the VFR800 - they really are a shit
    bike....despite what some people say~
    John
    John, Jul 18, 2004
  7. Jason Burton-Woods
    Uncle Bully Guest
    02
    Not sure about years, but the 600 was carby then the 620 came out with efi,
    so it's one or the other, not both.
    Uncle Bully, Jul 18, 2004
  8. Excellent, thanks !
    Is there anything obvious from the outside to look for to see if it is the
    EFI version, I cant make out the writing under the seat, there seems to be
    a gold throttle rocker, previous to this it didnt seem so noticable, also
    the seemingly older models had what looks like a vacuum disc placed
    vertically in the same area, would that be a sign of a non EFI bike?
    JasonBW
  9. Jason Burton-Woods
    conehead Guest
    If you look for EFI but see carbies, it's a carby model. Conversely.......
    If it's a 620, it's EFI. If it's a 600, it's not a 620.
    conehead, Jul 18, 2004
  10. Jason Burton-Woods
    Johnnie5 Guest
    you arent listening real well are ya ??
    if it is a 620 then it is efi
    the 600 had carbs , 620 went EFI with a power gain
    Johnnie5, Jul 18, 2004
  11. Jason Burton-Woods
    SmeeR1100s Guest
    hehehehe you've read my theory:p
    Yeos slej and rupes have met you and told me they think you are hatz as
    well:)
  12. Jason Burton-Woods
    SmeeR1100s Guest
    lift the tank
    it reveals all.
    the tank is hinged and easy to lift with one bolt removed.
    You will either see throttle bodies and the injectors or you'll see carbs.
    but if it says 620 then rest assured it's efi.
  13. Jason Burton-Woods
    smack Guest
    he's not paying attention, we might have to split his cases
    smack, Jul 18, 2004
  14. Jason Burton-Woods
    Biggus Guest
    Well Iwas going to say get a R1000RS but for that, he should get a
    boatanchor.
  15. Jason Burton-Woods
    SmeeR1100s Guest
    the r1000rs is a boat anchor
    the r1100s on the other hand is a class bike
    (shaddup johno)
  16. waits
    WOOHOO...there's case splittin afoot!!
    fulliautomatix, Jul 18, 2004
  17. not on me sir, I was paying attention, I was sir !! I havent seen the
    bike yet, so Im hoping that the carbys will be obvious.. I guess being a
    totally naked bike they *should* be... until I read that post describing
    the tank being lifted, good stuff.. now I can tell for certain. Thanks
    Smee.
    Thanks all.
    JasonBW
  18. Jason Burton-Woods
    X-No-archive: yes
    But first he should drain the dry clutch!
    Clem
    Knobdoodle, Jul 19, 2004
  19. Jason Burton-Woods
    X-No-archive: yes
    Yep... the carbies will be obvious (when Smack shoves them up your arse for
    not listening about the EFI!!)
    Clem
    Jason Burton-Woods wrote in message
  20. You had to remember that didnt you !!!
    JasonBW
    Jason Burton-Woods, Jul 19, 2004
