Ducati 600ss brake bleed getting nowhere
Discussion in 'UK Motorcycles' started by mentalguy2004, May 11, 2006.
  1. Hi,
    I own a Ducati 600 supersports (money-pit), and have replaced the front
    brake caliper as the old one had 3 out of 4 pistons seized. It's a hydraulic
    system, master cylinder on the handlebars down to a 4-piston caliper (2
    opposite 2) on the wheel. I've checked, double-checked that everything has
    gone back OK, and I have spent nearly a day trying to bleed the air out
    since the system was sealed, but am still left with no resistance in the
    brake lever. I'm using a hose on the bleed valve, I am keeping the res
    topped up with fluid (new DOT4), I drained the system before starting, and
    am using a jam jar to catch the fluid and keeping the other end of the hose
    immersed in this fluid.
    I have tried leaving a rubber band holding the lever in while I do other
    stuff, there are absolutely no leaks, and I am positive that no air is
    entering. The fluid is returning to the reservoir, as it squirts out if I
    try pumpimg the lever with the cover off, but I am getting pretty much
    nowhere with the bleeding.
    I started out getting some big bubbles, but all I get now is either good
    fluid, or tiny bubbles like a fizzy drink out of the bleed valve. Am I
    missing something, or should I just carry on and the air will eventually
    escape? I've got a jam jar with about 3 quarters of a litre of new fluid
    that's come out of the system via the bleed valve and hose, but still no
    resistance on the lever.
    Any help much appreciated before I have to re-mortgage the house for more
    parts from Italy..... Thanks!
  2. mentalguy2004
    Buy a Mityvac and grease the nipple threads before bleeding.
    Pip, May 11, 2006
  3. mentalguy2004
    mb Guest
    mentalguy2004 wrote:
    If desparation sets in, you could try it the other way round and use a
    big syringe to pump brake fluid in from the caliper end.
    Grease the nipple threads, to stop air being drawn in around them.
    mb, May 11, 2006
  4. mentalguy2004
    Eiron Guest
    Air being drawn in - that could be the problem.
    Is the OP closing the bleed nipple before releasing the brake lever?
    Eiron, May 11, 2006
  5. Look for high spots in the system where air may collect.
    You might want the caliper loose instead of mounted.
    The master cylinder should be the highest point in the
    system with a straight shot from the caliper up to it.
    Teflon tape or grease around the nipple might a help. Moving
    things around a little might also help dislodge any residual
    bubbles.
    When I replaced a caliper, I used a syringe to draw out
    fluid. After it sat overnight, the last of the sponginess
    had gone away.
    Rob Kleinschmidt, May 11, 2006
  6. mentalguy2004
    antonye Guest
    Don't forget to close the bleed nipple before releasing the lever.
    Check that all the unions are tight otherwise air might be getting
    in - you did replace all the copper washers when you rebuilt it?
    To be honest I always had problems bleeding brakes until
    I followed the exact instructions in the Haynes book and
    it worked a treat.
    If all else fails I have a good master cylinder for it as I swapped
    mine for a twin disk system so fitted a 916 m/c and then swapped
    it again for a Brembo radial...
    antonye, May 11, 2006
    more
    | it worked a treat.
    Yes, I've been closing the nipple, and I replaced the washers and made a
    mark on the banjo bolt head so the hole inside the bolt lined up the same as
    the old one. I have the Haynes manual and was following it word for word.. I
    am pretty convinced it must be the MC. There isn't anything else between the
    lever and the pads, and certainly no leaks from the hoses.
    I'd be interested to know how much you want for the MC; I have emailed a few
    breakers to see if they have one. I just spent 150 on the caliper, I really
    can't stretch to a new one from Italy, my wife will kill me LOL.
  8. |
    | more
    || it worked a treat.
    as
    I
    the
    few
    really
    Just out of interest, has anyone ever rebuilt/overhauled a Duke caliper or
    Master Cylinder? And if so, where did you get the seals, etc. because Ducati
    don't recommend repair and don't stock the parts.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, antonye
    Not strictly necessary. Hit them with a blowlamp to get them red hot,
    then let them cool.
    They're now annealed and nice and soft.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
    Wicked Uncle Nigel, May 11, 2006
  10. mentalguy2004
    Brian Guest
    I did but it was a long time ago on my Darmah....the master cyl had some
    pitting so i just gave it to the local 'Brake & Clutch' utfit who sent
    it away to be re-sleeved with a stainless liner.....it came back ready
    to bolt on. I re-kitted the calipers myself with genuine parts. But this
    was 15 years ago.......
    Go and see your local 'brake & Clutch' shop, they have lists of
    suppliers for all sorts.
    Brian, May 11, 2006
  11. mentalguy2004
    Bugger. Beat me to it.
    There's a footnote, though - don't hang the washer from the pointy end
    of a longnosed plier, 'cos when it turns red and soft, it also turns
    bloody oval. See that T-shirt - that's mine, that is.
    Pip, May 11, 2006
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    <G>
    YTC
  13. mentalguy2004
    Polarhound Guest
    Teflon tape works well on the bleeders as well.
    Polarhound, May 11, 2006
  14. mentalguy2004
    Adrian Guest
    mentalguy2004 () gurgled happily, sounding much like they
    were saying :
    Ummm...
    You don't normally need to worry about the exact line-up of the banjo bolt
    to union. The union has a nice big groove within it to let the
    fluid/oil/whatever run around freely.
    Perhaps, since the bolt's been "lined up" it's not actually quite as tight
    as it could be, and there's a bit of air sneaking in that way?
    <disclaimer - not a bloody clue with banjoes on bike brakes, but I've got
    'em on oil coolers and on car brakes, and nobody's ever suggested
    alignment's even vaguely important>
    Adrian, May 11, 2006
  15. mentalguy2004
    Brian Guest
    If you are not too sure what you are doing, it doesn't hurt to put
    things back on the exact same way you took them off. It may not be
    necessary in this instance, but it's a good practice to get into the
    habit of.
    Brian, May 11, 2006
  16. Could be an air bubble trapped in the line that floats up quicker than
    you can pump it down, but doesn't have a straight shot back to the MC.
    I have heard of hanging the calipers higher than the MC so that bubbles
    float up to them. An other possibility would be to remove the caliper
    from the disc and put something thinner than the disc between the pads.
    Pump the pistons out to fill the cylinders, then push the pads back in
    to force fluid back up to the MC.
    Bruce Richmond
    Bruce Richmond, May 12, 2006
  17. 2 suggestions:
    Make sure the two little holes at the bottom of the master cylinder are
    clear, poke a needle in or something.
    Wgen there's significant air in the system, as when you replace a
    component, the idea is to get the air to rise up into the master
    cylinder. Position the handlebars so the master cylinder is at the
    highest point. With the bleeder on the caliper CLOSED, squeeze the brake
    lever gently, you should see bubbles rise out the recently cleared holes,
    a bit every squeeze. Tap the lines every now and then to make the bubbles
    rise and make yourself feel better.
    George R. Young, May 12, 2006
  18. Bike on the center stand, turn the wheel side to side a few times too.
    Wheel pointed left ought to put the MC at it's highest point. Also
    helps
    to loosen the bar clamp slightly and rotate the MC and lever.
    Rob Kleinschmidt, May 12, 2006
  19. mentalguy2004
    That's a good 'un. Happens a lot.
    I'd be tapping the calipers, too. And the unions, joints etc. all the
    way up. I'd be tying the lever back to the bar and leaving it
    overnight, too - surprising how often that sorts these nasty bleeders
    out.
    Pip, May 12, 2006
  20. Modern Brembo multi-potters: no, they don't and you can't. We've done
    this before.
    ISTR Bonwick reckoning that you could take the seals to a seal shop and
    have them match them, but I also STR someone else (maybe again Bonwick)
    saying that if you told them they were brakes, they wouldn't. Product
    liability, lawyers, etc etc.
    The Older Gentleman, May 12, 2006
