dual plugging
Discussion in 'Motorbike Technical Discussion' started by Rob Kleinschmidt, Jun 5, 2008.
  1. Once again considering dual plugging my '88
    BMW airhead. Supposedly, this strengthens
    the low end and allows better running on regular
    or 89 octane fuel. Also supposed to allow a
    bump in compression.
    Job would require a new coil setup and a
    small diameter plug hole tapped into each
    cylinder.
    Any thoughts on this mod ? Good idea ?
    Not so good ? Downside ?
  2. All reports I've read say it's a mod well worth doing, especially when
    you consider the antique combustion chambers and gas flow that the
    standard single plug has to cope with.
    The Older Gentleman, Jun 5, 2008
  3. Rob Kleinschmidt
    Combustion chamber shape isn't actually that bad, the trouble is that
    BMW increased the capacity by increasing the bore, so the flame front
    has to travel considerably further on bigger engines, with all the
    assorted ill effects of that.
    It's a worthwhile modification, but I'd be tempted to go the whole hog
    and also use an ignition system that was designed for dual plugged
    heads. A German company called Q-Tech does make complete systems for
    this using R1100 coils - I've used their parts before and they "just
    work". Only problem is that I don't know if the guy speaks any
    English...
    Timo Geusch, Jun 5, 2008
  4. Rob Kleinschmidt
    TOG@Toil Guest
    Try:
    "Vas ist der price of der duppel schparken-lichten zystem, mein herr?"
    TOG@Toil, Jun 5, 2008
  5. Rob Kleinschmidt
    ian field Guest
    The cheap dodge is go to the breakers yard and get the twin lead coils off a
    Jap-4.
    ian field, Jun 5, 2008
  6. The trick seems to be matching resistance on the
    dual plug coil to resistance the single plug one.
