Hello, In my venture to ready my '69 CL350 (two cylinder) for spring, I've decided to replace the two stock coils. Problem is, I've done a lot of searching but can't seem to find the answer to a fairly simple question. I've been looking at 5 ohm coils to replace the stock ones (which are also 5 ohms.) Specifically I'm looking here: [URL]http://www.dynaonline.com/english/coils.htm[/URL]. The CL350 is a two cylinder with two coils, each with one output that goes to its own cylinder. I'm wondering if the DC7-1 will work with my setup - as it's only one coil, but with two outputs? In other words, can a single coil with two outputs replace two separate coils? Thanks, Dave
