DT50MX electrics.....
Discussion in 'UK Motorcycles' started by The Older Gentleman, May 4, 2006.
  1. Number One Son's DT50MX has been flattening its battery. I actually
    tested the charging when I did it up, and it was charging as well as a
    6v system can.
    But it isn't now. Hmf. And when I turned on the headlight, it glowed
    super-bright and then popped the filament.
    Oh-*kay*. So the reg/rec is fecked.
    Locate voltage regulator. No sign of a rectifier. And then I find,
    tucked under the frame tube where I'd missed it, one of those universal
    fuse holders with a red and a white wire going into it. And inside
    is.... nothing! The wires are joined. Well, bodged together.
    Undoing the wires and then tapping them together produces a clicking
    noise. Not from any relay, but from inside the engine. Where the
    alternator is. Whaaaatt?
    Out with the Haynes BOL, and yes, there should be a separate rectifier
    and regulator. And there ain't no rectifier. But the wires going to it
    should be... yes, red and white.
    I'm amazed it charged as long as it did. OK, so a new rectifier and a
    new regulator (they're remarkably cheap for these 6v things) and
    hopefully we have a fix....
    Oh, and a new headlight bulb. In fact, I'll get a couple of spares too.
  2. I'm amazed it worked at all; I guess it's a solid-state regulator
    with some inherent rectification via the transistor(s)?
    That was the problem I had with my Suzuki 100 -- the lighting
    circuit was fed directly with AC from the stator coils. 6V circuit, but
    about 20 VAC with no load; regulation was via the load from the headlight.
    So, whenever the headlight blew, which was not infrequently, the surge in
    voltage would take out the speedo bulb and the tail-light too. :-(
    Dr Ivan D. Reid, May 6, 2006
  3. Who knows? New rectifier is about a tenner: regulator about £30.
    Haven't looked at the speedo or tail lights yet.
    As the bike had been used for riding around private land for a decade, I
    suppose the previous owner wasn't bothered about things like rectifiers
    and regulators, as all the lights had been removed. As you'll know, it's
    flywheel magneto ignition. Er, I think.
    The Older Gentleman, May 6, 2006
