DT175 question
Discussion in 'Classic Motorbikes' started by Dr Ivan D. Reid, Jul 2, 2005.
  1. Is the right-side mirror mount right- or left-hand thread?
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
  2. Erm.... dunno!
    Yamaha used left-hand threads on left-hand mirrors. They might use them
    for right-hand as well.
    The Older Gentleman, Jul 2, 2005
  3. So you said the other night. Did you notice that you then screwed
    in a right-hand-thread mirror on the left, and failed to screw in another
    right-hand-thread mirror on the right?
    <g,d&r>
  4. Ermm... well, it was late, and I wasn't thinking straight. And my supper
    was getting cold ;-))
  5. Dr Ivan D. Reid
    Dr Ivan D. Reid says...
    Left is a right hand thread, right is a left hand thread. 1100 Virago
    mirrors are identical to the old RD ones, so will look period for a DT.
    Lozzo, Jul 2, 2005
  6. Ta, Lozz. I'm rather lost without mirrors (esp. with my broken
    neck and limited head-check movement). TOG found a left one to fit but I
    found it fraught on the M25 without a right as well.
    BTW, the ride home was the first time I wore that Arai since you
    sold it to me. (Hangs head in shame.)
  7. Sure it's not RHT for the RH and LHT for the LH? With the mirrors out in
    the breeze, the wind against the mirror heads will keep the stalks tight
    that way.
    Grimly Curmudgeon, Jul 2, 2005
  8. Dr Ivan D. Reid
    Grimly Curmudgeon says...
    Nope, deffo the other way. It's so the mirror unwinds rather than
    ripping the threads out when you drop the bike.
    Lozzo, Jul 3, 2005
  9. These cunning Japs, they think of everything. Come to think of it,
    you're right - on the few bikes I've had with a LH threaded mirror, it's
    been the 'wrong' one for me - ie, the wind unscrews the bloody thing.
    Grimly Curmudgeon, Jul 3, 2005
  10. Yep; as I said, TOG screwed a right-hand-thread mirror into the
    LH mount, and if I follow the thread on the RH side it's definitely LH.
    Guess I should be finding out where the closest Yamahahaha dealer is,
    but I'd better bleed Black Kat's brakes first.
    Dr Ivan D. Reid, Jul 3, 2005
  11. Dr Ivan D. Reid
    Salad Dodger Guest
    Sod Yamaha dealers, get a pattern one.
    Salad Dodger, Jul 3, 2005
  12. OK, where's my nearest Patton dealer?
    Off to Halfords to look at power bleeders (sod it[1]!)...
    [1] Where the f*ck *is* that air hiding? I've even cracked open the
    banjo bolt at the master cylinder in case it was there. Good thing I've
    still got an unopened 1l bottle of fluid.
