Drying out saddle sponge
Discussion in 'UK Motorcycles' started by T i m, Sep 13, 2008.
  1. T i m
    Heh - nice.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Sep 17, 2008
    #41
  2. T i m
    T i m Guest
    Thanks. I was happy to get given 'a chain', I'm even happier if it's
    a good one.
    Because I'm wired that way Lozzo. If for example I find the reason was
    poor engineering I would consider checking 'now' other components that
    I am aware he may also have touched, like the front sprocket (I can
    see / check the rear easily). I appreciate this may not be of interest
    to anyone other than me though (or my family maybe). ;-)
    I think you misread my main thing somewhere fella. My issue wasn't
    with the slightly stiff links (as you say, it had been left in the
    open for some time so to be expected, even on a O-Ring jobby) but the
    very slack one or two?
    If I was simply replacing my own worn out chain I would. Remember this
    is also a mini project [1] and I'm doing any of the bits I feel I need
    to ensure are known / safe before I 1) take it on the road myself and
    2) stick it through an MOT. I also know that once it's on the road,
    assuming it works properly AND I like riding it [2] it won't be so
    easy to start working on it again (or nothing major anyway).
    [1] Something I'm doing in-between loads of other and often more
    important things.
    [2] I was looking at the ease of raising the handlebar position (GT550
    bars / front end?) and doing away with the fairing. This fairing is
    quite damaged and I fancied a naked bike for generally running about /
    the summer.
    T i m, Sep 17, 2008
    #42
  3. T i m
    Same reasons. Rust and then wear set in and eat away at the hardening
    on the rollers and pins. Then you get sloppy links
    T I M , man you need to lighten up a bit and stop taking everything so
    bloody seriously.
    Lozzo, Sep 18, 2008
    #43
  4. T i m
    T i m Guest
    I can understand how that could happen Lozzo but I don't think it is
    the cause in this case (and why I'm intrigued to look closer). If this
    was a new O-Ring chain ~150 miles and 3 years ago I (personally) would
    be surprised if just one or possibly two links would rust away when
    the other 102 seem to be perfectly ok, all be it with some surface
    rusting?
    Can't help it mate, always been the same, however it's not
    *everything*. ;-)
    T i m, Sep 18, 2008
    #44
  5. Let 'is tyres down.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Sep 18, 2008
    #45
  6. <faints>
    You mean... you wouldn't buy a tool that you might not want to use more
    than once in a blue moon?
    Why, the mere possession of a tool (fnarr) is enough in itself.
    GS850x2 XS650 SE6a
    - House
    #46
  7. T i m
    **** that, I get a warm and fuzzy feeling when I lift my 3" square
    drive impact wrench into place using an overhead crane and smash 5"
    6tpi nuts into submission without resorting to an induction heater.
    I hate working stupidly long hours for 12 days out of 14 but you do
    get a sense of inner well being when you can walk away from a foad
    turbine knowing that you've kicked it's arse.
    Turn your lights on and say thankyou...
    Andy Bonwick, Sep 18, 2008
    #47
  8. T i m
    T i m Guest
    I agree, sometimes.
    Like this cheap 14 / 17 mm hex tool I just bought. I've used it on the
    fork top caps and I don't expect to use it again till I change the
    fork oil again, but, I bet I do use it for something else in-between.
    It could be as a 14 / 17mm hex spanner or as a drift, a spacer or
    wedge or a press tool.
    I have one of those Gunson pressure brake bleeding things and haven't
    used it for anything after it's first try.
    T i m, Sep 18, 2008
    #48
  9. T i m
    Absolutely. I've got a warm fuzzy feeling after buying a new circular
    saw & router today. They're currently taking pride of place on the
    coffee table just so I can drool at their magnificance.
    Krusty
    Krusty, Sep 18, 2008
    #49
  10. T i m
    Post a link to it because I need one as soon as possible.
    I'm stopping at a hotel full of pensioners and throwing Stella down my
    neck to dull the pain so you need to cut me a bit of slack..
    #50
  11. T i m
    T i m Guest
    Put the new chain on today and had a chance to look closer at the old
    (new) one.
    The one loose link appears to be missing it's O-rings (the two on same
    pin), and it's not the (spring) joining link? The rest of the chain
    was quite useable and had it not been for the 'odd' link I would have
    left it on.
    I took the opportunity to check the front sprocket (thinking it may
    not have been changed or fitted backwards etc) and it seems it was ok.
    It gave me the chance to strip, clean, lube and adjust all the gear
    linkage though. I also found out what was under the plastic cover on
    the top of the crankcase (the starter motor).
    Between some other jobs I pumped up the front suspension, re-fitted
    the chain guard, rear mudguard middle section, lubed all the locks,
    stripped, freed and lubed the n/s foot pegs. Tomorrow I hope to get
    the exhausts back on and she should be close to MOT time. ;-)
    I'm gonna see if I can find another rearmost mudguard section as the
    current one is broken where the o/s rear indicator mounts (obviously
    been down on the o/s) and some twat has cut it short, probably when
    they trimmed the rear number plate down to the letters. Gotta sort it
    or where am I gonna stick my MZ mud flap! ;-)
    T i m, Sep 18, 2008
    #51
  12. T i m
    T i m Guest
    My new 50l compressor has been in the kitchen for a couple of weeks
    now. It's too pretty to take down the workshop and it's got wheels so
    she can still (fairly easily) move it to get to the freezer. ;-)
    T i m, Sep 18, 2008
    #52
  13. T i m
    Talking of which, Machine Mart have a got a sale on DeWalt Feral
    Apostrophe Strippers this week.
    Krusty
    #53
  14. T i m
    My throat's well & truly full of Tempranillo, so I feel your pain.
    Slack cut as requested.
    Krusty
    #54
  15. **** yes. The job satisfaction when the bastard actually works - on
    smaller scale machinery, but the same, nonetheless.
    Eyethengew. At least, your counterpart.
    GS850x2 XS650 SE6a
    - House
    Grimly Curmudgeon, Sep 19, 2008
    #55
  16. You have to gradually introduce it to the workshop and let the paint
    chip here and there, just so it's not too traumatic.
    Before you know it, you'll be wondering where you left it, and there it
    will be, covered in dust and birdshite in the corner, just waiting to be
    plugged in again and sing... sing... sing...
    GS850x2 XS650 SE6a
    - House
    #56
  17. T i m
    T i m Guest
    Noooooooooooooooooooooooooooooo! :-(
    True ..
    <sigh> Or not, as I haven't quite gotroundto powering the workshop
    properly and this new presser is a 3KW jobby.
    Anyway, with it in the kitchen and me in the workshop (and a long hose
    in-between).
    1) It's very quiet
    2) It takes up less space
    3) I don't have to sort the workshop power out properly
    4) She hoovers it down now and again
    5) I'm more likely to be able to get to it to check the oil level and
    drain the water off!
    And as long as I can get to the fridge for me beers and hand cleaner /
    sink I'm happy. ;-)
    T i m, Sep 19, 2008
    #57
  18. T i m
    Eddie Guest
    If that's the only problem, and the rest of the chain's in good
    condition, you can chop out the dodgy link and reuse the chain with a
    new riveted link.
    I wouldn't ever bother with a spring link these days, when it's so easy
    to use a proper riveted link.
    Eddie, Sep 19, 2008
    #58
  19. T i m
    T i m Guest
    Yeah, and I probably would have done so if I hadn't been *given* a
    nice new chain Eddie. ;-)
    I think there are spring links and spring links. On my little CB Two
    Fifty I think I remember the side plate on the supplied spring link
    being a loose fit. I used the spring link on this GPz550 chain because
    I lost the rivet one (now found again, fell out of packet in the
    garden). I'll swap it over at the bike shop on the way back from the
    MOT and use their nice riveting tool. ;-)
    FWIW I had to 'press' the side plate on this spring link on very hard
    with a G-clamp and small socket and I can't see it coming off even
    without the clip. I fitted the clip of course and backed the side pate
    up against it with my splitter too as it suggested.
    Back out to fit the exhaust in the sunshine now. ;-)
    T i m, Sep 19, 2008
    #59
  20. T i m
    Eddie Guest
    I realise that; what I meant was "keep it until you need it, *then*
    reuse it with a new riveted link", but I thought that was too obvious to
    be worth stating.
    I've got my own riveting tool (actually, a half-share in one), but I've
    done it before without the tool, and it's not difficult. I'd rather do
    that than trust a spring link.
    In theory, there /shouldn't/ be much sideways force on the plates
    anyway, but...
    Ah, that's the way to do it. But some of us have to work for a living.
    Eddie, Sep 19, 2008
    #60
