Drying out saddle sponge
Discussion in 'UK Motorcycles' started by T i m, Sep 13, 2008.
  1. T i m
    T i m Guest
    I'm slowly getting this old GPz550 sorted and whist settling the
    Uni-trak re final torque yesterday I noticed water coming out from
    somewhere and it turned out to be the saddle.
    I think it happened whist standing uncovered for the last couple of
    years at the POs place and got in via what looks like wear holes in
    the middle of the pillion position (it's been covered since at mine).
    Now luckily the seat pan is plastic so it's not going to rot much
    other than the staples but I wondered if there was a known trick for
    drying such things without upholstering it, or will it just dry out on
    it's own given time?
    T i m, Sep 13, 2008
  2. Stick it in the airing cupboard.
    The Older Gentleman, Sep 13, 2008
  3. T i m
    Saddle? SADDLE? It's a bike, not a fucking horse.
    Yes - eventually.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Sep 13, 2008
  4. T i m
    T i m Guest
    Ah, ok, will do ta.
    T i m, Sep 13, 2008
  5. T i m
    Gavsta Guest
    That got a smile :)
    Gavin.
    http://www.stoof.co.uk
    For the road: GSXR600 K1
    For the track: GSXR400 GK76A
    For the rest: Citroen Belingo
    Gavsta, Sep 13, 2008
  6. T i m
    Gavsta Guest
    Fill it full of Tampons.
    Gavin.
  7. T i m
    T i m Guest
    Ok, another thing to try then Steve. I would have thought that if it
    was going to just run out it might have done so by now but maybe on
    it's end it will be a bit more likely to do so?
    I am pretty sure the water mainly got in via these strange wear marks
    on the pillion position (they look as if they have been chewed through
    from underneath by a mouse or summat)? Realistically I was wondering
    if they were from some throw-overs or a courier type use double
    top-box in it's past.
    T i m, Sep 13, 2008
  8. T i m
    T i m Guest
    Hmmm, it just might work. ;-)
    Funny you should say that though. A mate gave our daughter a punch bag
    (for her Taekwondo) and it was packed full of (new) disposable
    nappies!
    T i m, Sep 13, 2008
  9. T i m
    T i m Guest
    Ok ta. I think I'll just try to persuade as much of the water out as I
    can first (by squeezing it from one end like a toothpaste tube), stand
    it on it's end when the sun is shining and leave it in the airing
    cupboard the other times (filled with tampons). ;-)
    T i m, Sep 13, 2008
  10. T i m
    Beav Guest
    Even a corpse dries out of its own accord eventually, but I reckon that
    chucking the saddle in the airing cupboard (God how I miss mine) will see it
    bone dry within a matter of days.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 13, 2008
  11. T i m
    Beav Guest
    YOU A-fucking gain!
    Bollocks to this, it looks like I'm going to have to read every bastard post
    in a thread before chipping in.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 13, 2008
  12. T i m
    des Guest
    des, Sep 13, 2008
  13. T i m
    T i m Guest
    You know it makes sense ... ;-)
    T i m, Sep 13, 2008
  14. T i m
    T i m Guest
    Hehe Des, it amazes me how people can find nit-picking more
    interesting / productive than just answering the spirit of the
    question (unless they don't have an answer of course)?
    But then it is UKRM so perfectly predictable. ;-)
    T i m, Sep 13, 2008
  15. T i m
    des Guest
    I've done a fair amount of splitting hairs in my time, dude, so I shan't
    answer that one ... :p
    D.
    des, Sep 13, 2008
  16. T i m
    T i m Guest
    Ok, well I am putting a combination of the replies into practice and
    see what happens.
    Today I popped the r/h/s footpeg carrier back on, re-fitted the rear
    master cylinder and bled the brake. Still feels a bit spongy (does
    come up firmish at the end of the stroke) but I guess it might improve
    once the new pads have settled in and or been bled again?
    T i m, Sep 13, 2008
  17. T i m
    Beav Guest
    Sometimes it's an idea to raise the caliper above the reservoir (with
    something in the caliper to stop the pistons ejaculating all the fluid, of
    course), which means removing it and getting a helper.
    Also you could try cable tying the brake lever back as far as it'll go after
    a few pumps, then leaving it overnight.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 13, 2008
  18. T i m
    T i m Guest
    Ok, that's easy enough to do, especially now I know it all comes off
    etc.
    Ok, I'll try that if the fist step fails.
    FWIW, when I stripped and cleaned the rear master cylinder I couldn't
    seem to get the input pipe out. The internal ping_fuckit was partly
    rusted away and stuck in the groove. Even once I'd got it out I still
    couldn't remove the plastic_elbow_tube_on_plastic_disk_thing from the
    master cylinder body (it went round but wouldn't pull out). I read
    somewhere there were two holes in there and if the smaller was blocked
    it would be difficult to bleed. In a shit_or_bust action I managed to
    pull the plastic fitting out without breaking it [1] and was able to
    properly clean a check the said two holes (and the small one was very
    small and it was full of crap in there, in spite of several blast
    through's with brake cleaner and the air line).
    When I re-assembled it all today I filled the reservoir and loosened
    the bleed nipple and noticed the fluid running away and bubbles coming
    up into the reservoir. A few cycles of pumping the pedal and topping
    up the reservoir saw fluid coming out of the bleed nipple fairly
    constantly. I then did the traditional bleed process ... slight
    pressure on pedal, loosen nipple, pedal moves to near end, lock
    nipple, release pedal, repeat ... and I then seemed to get a
    reasonable action. However, it's still more movement than I'm used to
    with rod operated drum rears but would probably be more efficient for
    similar pedal pressures?
    T i m
    [1] The reason I couldn't get the fitting out easily was because of
    corrosion under the sealing grommet had 'expanded' the grommet and
    held it too tightly.
    p.s. I've just stripped, cleaned, lubed and re-assembled one of the
    anti-dive units (I wanted to change the fork oil anyway). I wanted to
    give them a try as-is before (probably) blanking them off (with bypass
    groove).
    T i m, Sep 14, 2008
  19. T i m
    T i m Guest
    Bit of 1/4" plate mole-gripped to the swinging arm, acting as pseudo
    disk and supporting the caliper as high as possible. Left hand on
    bleed nipple, right hand on foot brake pedal a few pumps later have a
    much quicker acting brake (less travel).
    Cheers Beav ;-)
    p.s. The water is still slowly dripping out of the saddle, currently
    standing on it's end in the garden sun.
    T i m, Sep 14, 2008
  20. T i m
    Beav Guest
    Your idea of slight pressure on the pedal needs looking at. Pump the pedal
    until it's hard (f'narr) and THEN hold it down and loosen the nipple.
    Tighten the nipple before the pedal reaches the end of it's stroke and
    repeat as necessary.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 14, 2008
