Dropped my bike!
Discussion in 'UK Motorcycles' started by Nick, Mar 18, 2005.
  1. Nick
    DR Guest
    Bloody hell. The B12 shows up at 215kg dry, that makes it a lardy old
    bus. Would have thought an ER-5 much lighter than a (nearly) litrebike.
    DR, Mar 19, 2005
    #61
  2. Nick
    DR says...
    Where do you think the 'Heavy' In Kawasaki Heavy Industries comes from?
    Kawasaki have never really been known for making lightweight bikes
    compared to the opposition.
    Lozzo, Mar 19, 2005
    #62
  3. Nick
    JackH Guest
    KR1-S?
    JackH, Mar 19, 2005
    #63
  4. Nick
    JackH says...
    Heavier than the RGV. Kawasaki did make them incredibly light though,
    but at the expense of relibility. Have you ever felt the weight of one
    of the KIPS valves, they weigh next to **** all, but the tops can easily
    shear off when fitting or removing the linkages that screw onto them. I
    hated the KR engine, it was horribly made and everything was designed to
    last 10 minutes.
    Lozzo, Mar 19, 2005
    #64
  5. Nick
    JackH Guest
    I never had the pleasure of anything, KR1-S wise - their reputation
    proceeded themselves well in advance, thank feck.
    The RGV isn't *that* much better in respect of reliability, really.
    S'wot I liked about the TZR250 so much - apart from the fact it was the
    natural progression from the 125s I had, it had none of this 'Nikasil'
    bollox etc.
    Might not have been cutting edge for its time, but I'd still like one now.
    JackH, Mar 19, 2005
    #65
  6. Nick
    Monz Guest
    Made me titter... My little brothers recollection of his first off at
    Cadwell went somthing like that.
    sky - track - sky - grass - tyres - St Johns
    Monz, Mar 19, 2005
    #66
  7. Nick
    John Littler Guest
    Fair go guv ! The KR1 came out well before the RGV, and the KR1S was
    only a mildly modded KR1 (17" rims both ends, suspension and some engine
    work), there was a bit of technology improvement in the intervening 5
    years; that's like comparing the first release R1 with the current model
    Gix-thou
    JL
    John Littler, Mar 19, 2005
    #67
  8. Nick
    That's me fucked.
    sweller, Mar 19, 2005
    #68
  9. Nick
    I see them lying on their side leaking the precious juice. Makes me get
    a wriggle on.
    #69
  10. Nick
    Nick Guest
    I use the left foot on road, right foot on brake idea, my instructors
    also said it was fine. But it doesn't really matter what you use.
    However, the DSA's Official "Motorcycle Riding: The Essential Skills"
    says:
    Stopping
    The following sequence will apply to most motorcycles
    .. Close the throttle
    .. Apply both brakes smoothly until the machine stops
    .. Just before the motorcycle stops pull in the clutch lever to
    avoid stalling the engine
    .. As the machine stops put your left foot on the group to support
    the weight
    When the machine has stopped
    .. Keep the front brake applied
    .. Release the rear brake and support the motorcycle with your
    right foot
    With the clutch lever still pulled in
    .. Use your left foot to move the gear selector to neutral
    .. Release the clutch lever
    .. Place both feet on the ground
    That's the official DSA advice. However, one needs to take into
    account that the DSA also say that Counter Steering is not possible
    and, as such, it has stopped Riding Schools from explaining it to
    newbies. Make of it what you will.
    When stopping I normally put my left foot on the ground and right foot
    on the brake, but if I feel someone is going to run over my left foot
    I do it the other way around and if I'm going to be ages at a traffic
    light, I put both feet on the road with it in neutral. My instructors
    said that it doesn't matter which method one uses, but the DSA frown
    if you haven't got a brake on while stationary.
    Nick, Mar 19, 2005
    #70
  11. Nick
    Nick Guest
    I've been riding without L-Plates for nearly two weeks now, officer!
    After my little droppign incident yesterday I will certainly treat the
    front brakes with more respect at slow speeds.
    Nick, Mar 19, 2005
    #71
  12. Nick
    Catman Guest
    Clucking hell
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (Badly bent) 155 TS
    www.cuore-sportivo.co.uk
    Catman, Mar 19, 2005
    #72
  13. You should have stood aside and let a passing truck finish the job ;-))
    The Older Gentleman, Mar 19, 2005
    #73
  14. Nick
    'Snot working though, is it?
    Stick your dashdashspace<return> above your signature and it will,
    however.
    Pip, Mar 19, 2005
    #74
  15. The purchase of shares in a building company?
    #75
  16. Same as a 1970s RD, then.
    #76
  17. Nick
    (The Older Gentleman) struggled
    to ejaculate:
    No, nonono.
    A building firm run and staffed by people who quite happily go both
    ways innit.
    They'll fall foul of HSE, wearing comfy shoes rather than safety
    boots, mind.
    Pip, Mar 19, 2005
    #77
  18. Nick
    That's the feller.
    I mean, even with a fucked back I managed to pick the Bandit12 up a
    few times - on gravel, on grass, in the back of a fucking 7 1/2 tonner
    when it made a break for freedom. The only time I couldn't do it
    without assistance was the infamous incident of the left-off oil
    filler plug, when I dumped the bike in the middle of a busy junction
    and only managed comedy Keystone Cops-esque whirling movements with my
    legs due to standing in a spreading pool of warm oil.
    It is a handy technique to master, though - and something all of us
    are familiar with. I understand the backing-up to the bike thing is
    very good, as it uses the thigh muscles and not the back - and it
    closely resembles the technique I use to get a car rolling when the
    surface isn't good.
    However, for a normally-built male, picking a flattened bike up
    shouldn't be impossible (certain BlingMobiles excepted, obv.) just by
    getting feet under it, grabbing a good handful of lower bar or under
    tank and under frame around the seat area - and lifting it up. FFS.
    Confidence/determination/blind panic, all fuelled by a good shot of
    adrenaline really helps, mind.
    Commiserations Nick - but that's the first one over with.
    Pip, Mar 19, 2005
    #78
  19. Nick
    John Littler says...
    Yeah, but the gixer was good when it came out and the K5 is a definite
    improvement over the K1. With the transition from KR1 to KR1-S Kawasaki
    managed to make an already unreliable bike a little quicker but just as
    unreliable and no lighter.
    Lozzo, Mar 19, 2005
    #79
  20. Nick
    The Older Gentleman says...
    In hindsight, you're probably right. That bike was the final straw that
    broke the back of a 6 year salvageable relationship, with a girl I
    really and truly loved.
    Lozzo, Mar 19, 2005
    #80
