Driveways - CAUTION! May contain motorcycle related content
Discussion in 'UK Motorcycles' started by Gyp, May 23, 2011.
  1. steve robinson escribió:
    It's actually more often than not, a thin layer of a very weak mortar mix.
    Usually can be scraped off easily. Especially when wet.
    Paul Carmichael, May 23, 2011
  2. Gyp
    I think you might be confusing 'screed' with self-levelling mix.
    Krusty, May 23, 2011
  3. No its not , its usally about 60mm thick , you thinking of self
    levelling compound
    steve robinson, May 23, 2011
  4. Gyp
    where's Petrolcan when you need him? He's bound to have been "doing a
    job round the corner and has some tarmac left over, so he does".
    darsy, May 23, 2011
  5. Gyp
    Thomas Guest
    A typical thread on UKRM.
    Thomas, May 23, 2011
  6. Depend dunnit. If you want to look like an utter **** with too much money
    and no fucking sense then you put down decking. If you want to show how
    much sheer class you have at a sensible cost and thus impress burds of all
    sorts then you use secondhand brick.
    Either way it is not the finish what counts but the bits of minced and
    scraped motorway underneath it what makes the job a good un regardless of
    what you put on the top.
    I have a 2 foot (at it's shallowest) layer of rammed hard core capped with
    preloved brick for the important bits where I park my toolbox and stuff
    and the rest is just the hard core rammed a bit more and dressed with dirt
    and brick dust. Excellent drainage, even for spilt motor oil, firm
    surface that will, in places, take a side stand an huge amounts of
    maintenance spraying it with weedkiller 3 times a year. and I have a
    couple of small colonies of daffs that meander slowly around it as well.
    steve auvache, May 23, 2011
  7. Gyp
    Thomas Guest
    Don't the bricks get slick when wet?
  8. Gyp
    Jim Guest
    Last month I almost bought a Yaris off a chap who had just about finished
    building a new house: his version of temporary drive surfacing was
    apparently made of ground up incinerator ash. It certainly had all sorts
    of odd junk floating around on top of it although he claimed he'd never
    got a puncture.
    Jim, May 23, 2011
  9. We don't do wet here in Sunny Essex but on the rare occasions we get a
    small shower or two in the spring then not that I had noticed. The real
    trick seems to be to keep nature from reasserting itself between the
    cracks, moss in the damp dark places especially.
  10. Gyp
    Andy B Guest
    Block paving but don't have it coated with the shite that's meant to
    keep the weeds off because it makes it slippery and you're bike will end
    up resting against your garage door if you leave it out in the rain.
    Andy B, May 23, 2011
  11. Gyp
    Hog. Guest
    I'd go with block paving every time. Perhaps set on a bed of resin fixed
    sand (given the slope). It's easy to maintain and repair localised
    spills/cracks/subsidence ( and without it looking like a patchwork quilt)
    Hog., May 23, 2011
  12. Krusty escribió:
    Normally referred to as screed though. Bloody experts.
  13. Latex
  14. Good quality concrete, not that shit that some cowboy put down on yours.
    Coincidentally, my neighbour was pointing out the area of concrete in
    his yard that was mixed with inferior aggregate - the surface is all
    breaking up after the last round of winter temps, while other, older
    areas are fine.
    Grimly Curmudgeon, May 23, 2011
  15. But that's not important, right now.
  16. Gyp
    Gyp Guest
    To be fair, it has lasted 45 years
    Gyp, May 23, 2011
  17. Gyp
    SteveH Guest
    Driveway paint?
    Restored our oil stained tarmac to a very good standard last year.
    Needs re-doing after a few maintenance disasters, though.
    SteveH, May 23, 2011
  18. Gyp
    Gyp Guest
    No
    Gyp, May 23, 2011
  19. Gyp
    Ivan D. Reid Guest
    \LaTeX, pshirley?
    Ivan D. Reid, May 23, 2011
  20. Gyp
    petrolcan Guest
    petrolcan, May 23, 2011
