DR650 turn signals
Discussion in 'Motorbike Technical Discussion' started by Mike Corey, Jul 24, 2008.
  1. Mike Corey
    Mike Corey Guest
    I would like to be able to have the turn signals on my DR650 on all the
    time to aid in being a bit more visible by motorists. Of course, I would
    want them to flash for turning. Wouldn't this be as simple as changing
    the normally open flasher relay to a normally closed relay? Or is it a
    bit more difficult then that? I've heard Harley Davidson makes a kit to
    do this to their bikes. Is such a kit available for my Suzuki?
    "War is an ugly thing, but not the ugliest of things; the decayed and
    degraded state of moral and patriotic feeling which thinks nothing is
    worth a war, is worse." --- John Stuart Mill:
  2. Mike Corey
    Kevin Guest
    (Mike Corey) wrote in @storefull-3111.bay.webtv.net:
    if your turns are amber it will be illegel to do. only red is allowed to
    the rear. This is in the US. KB
    Kevin, Jul 24, 2008
  3. You might convert from an 1156 to an 1157 bulb and socket.
    http://www.google.com/search?hl=en&q=1156+1157+signal+conversion&btnG=Google+Search
    Another way this is sometimes done is to put separate
    red or yellow LED(s) into the turn signal housing and
    leave the signal circuit stock.
    Rob Kleinschmidt, Jul 24, 2008
