Doubleplusgood - first impressions
Discussion in 'Australian Motorcycles' started by Minx, Feb 15, 2007.
  1. Minx
    bikerbetty Guest
    Gee, I just checked my social calendar, and guess what?
    So - I finish at 4 in Civic. Let's plot something for Wednesday!!!
    betty
    bikerbetty, Feb 18, 2007
  2. Minx
    Minx Guest
    4:30 at corner of Eucumbene Dr and Cotter Rd?
    Minx, Feb 18, 2007
  3. Minx
    bikerbetty Guest
    I'll be there!!!!
    betty
    bikerbetty, Feb 19, 2007
  4. Watch out for lightning strike!
    Cheers
    Andrew
    (Make a lightning rod by gluing a blunt ferrous rod to the top of the
    motorcycle helmet, attaching a 4 metre length of copper strap to the rod
    with copper wire, and attaching a suitable boat anchor to the free end
    of the strap to make sure it stays earthed - any Windows 98 computer
    would do.)
    Andrew McKenna, Feb 19, 2007
  5. A _blunt_ rod? Have you been taking physics lessons from Hamish again?
    big
    Iain Chalmers, Feb 19, 2007
  6. " Calculations of the relative strengths of the electric fields
    above similarly exposed sharp and blunt rods show that although the
    fields, prior to any emissions, are much stronger at the tip of a sharp
    rod, they decrease more rapidly with distance. As a result, at a few
    centimeters above the tip of a 20-mm-diameter blunt rod, the strength of
    the field is greater than that over an otherwise similar, sharper rod at
    the same height. Since the field strength at the tip of a sharpened rod
    tends to be limited by the easy formation of ions in the surrounding
    air, the field strengths over blunt rods can be much stronger than those
    at distances greater than 1 cm over sharper ones.
    The results of this study suggest that moderately blunt metal rods
    (with tip height–to–tip radius of curvature ratios of about 680:1) are
    better lightning strike receptors than are sharper rods or very blunt
    ones. "
    C. B. Moore, William Rison, James Mathis, and Graydon Aulich, "Lightning
    Rod Improvement Studies". Journal of Applied Meteorology: Vol. 39, No.
    5, pp. 593–609. Langmuir Laboratory for Atmospheric Research, New Mexico
    Institute of Mining and Technology, Socorro, New Mexico. April 10, 1999.
    Extracted from that authoritative source Wikipedia:
    http://en.wikipedia.org/wiki/Lightning_rod
  7. OK, I'm wrong (again)...
    (at least I'm not alone, it does say "It is commonly believed,
    erroneously, that a rod ending in a sharp point at the peak is the
    best"... )
    big
  8. Minx
    bikerbetty Guest
    Oh poop, there aren't going to be MORE bloody storms, are there? It's just
    not right in Canberra! Steamy afternoons, celestial pyrotechnics, RAIN?!?!!
    I've never seen anything like it!
    Minx, let's confirm closer to the time, and hope the weather holds!!!
    betty
  9. I'm not so sure... If it's against the rules, nobody sent me _that_ memo
    either...
    big
  10. Minx
    Just refuse to admit that you did it (even when presented with irrefutable
    proof).
    That's the aus.moto way.
    Knobdoodle, Feb 19, 2007
  11. It would but you can pick up steel bar offcuts at any building site for
    nix. Dunno where you'd find a copper rod for nix. Might be able to find
    aluminium rod instead of steel, though. Don't ask me why I'm worrying
    about the practicalities of this imaginary piece of kit, but for some
    reason I am.
    Southwark Premium, thanks.
  12. Minx
    ck Guest
    I think it is the Windows 98 anchor that keeps you hoping...
    ck, Feb 19, 2007
  13. Minx
    Goaty Guest
    Stuff your waki ...
    Check
    http://www.erico.com/products/s3000_1.asp
    to see the 3000 series active lighting protection designed and
    manufactured in Tassy. Note the shape, and read the comments! They
    actually detect pre-strike and then generate ozone to attract the strike
    and ground it safely.
    Cheers
    Goaty
    _--_|\ John Lamp - in beautiful downtown Highton
    / \ IRC: DoD#:1906 Ulysses#:10185 Vulcan Nomad
    \_.--._/ http://www.gorider.cjb.net/ Phone: 0409 512 254
    v mailto: Fax: 03 5227 2151
    Hear no Evo, See no Evo, Fear no Evo
    Goaty, Feb 20, 2007
  14. Minx
    bikerbetty Guest
    Well..... bloody weather....
    Minx and I forgot to pack our lightning rods, and had to abandon our
    ride this arv. Bugger. This silly tropical weather has GOT to stop!!!
    More of it expected this week, so we're rescheduling for next week and
    hoping for some seasonally- and geographically-appropriate sunshine.
    betty
    bikerbetty, Feb 21, 2007
  15. If you wait for the weather, you'll no do much riding.
    Cheers
    PeterC [aka MildThing]
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Feb 21, 2007
  16. Minx
    bikerbetty Guest
    A bit of rain doesn't really bother me - got caught in a lovely storm on the
    weekend - and besides, it's not usually an issue in Canberra (although I
    have a few fair-weather rider friends who won't go anywhere if there's so
    much as a puff of cloud on the horizon....) But this was serious storm
    stuff. Dunno what's happened to the Canb weather of late - I've had to start
    putting wet weather gear in the tank bag every day, just in case!!!
    betty
  17. Minx
    God doesn't like it when you start fooling around with nature and pretending
    you can alter time!
    Knobdoodle, Feb 21, 2007
