Doom 3, part 2.
Discussion in 'UK Motorcycles' started by Pip, Aug 31, 2004.
  1. Pip
    Loz H Guest
    Not even that much, if you spend wisely. For my system (and it is quite
    quick, keeping up with similar systems at a lot more of the price) I chose
    an ASRock K7S8X 3.0 motherboard (around £25 at most computer fairs or scan
    computers in Bolton. So far, amazingly stable and has more than enough
    features for me), AMD XP2500 retail (at the time £65. bit cheaper nowadays I
    believe). Luckily I bought the RAM at a low-point in its pricing (£30-odd
    for 512Mb PC3200) and a 120GB HDD for £60.
    Being perma-skint for most of my life I took a lot of time deciding what to
    get with my money when I came to upgrade, and I honestly feel I couldn`t
    have done better for the price. Also, as Ginge seems to do, I went for the
    "less than bleeding edge" components. A lot more bang per buck, as they say.
    The only way I could improve my system in a noticable way now would be to go
    down the Athlon 64 path, and that is far to expensive for the small gains I
    would probably see at the moment. Maybe next year, when the pricing has
    settled somewhat.
    Bear in mind the AMD Barton 2500+ is quite a clockable chip. Mine runs at
    3200+ speeds with standard voltage. Set the board at 200Mhz FSB and away I
    went. YMMV, of course, but 2800+ ( as it seems Ginge has his at) appears to
    be attainable for all of them from what I`ve read.
    Is the card actually fried, or just the fan? Replacement fans are available
    at any Maplins electronics store (Thermaltake G4-VGA copper). £12 I think
    mine cost when the fan died on my Ti4200. I since repaired my old fan
    (clogged up with shite) and it`s working quite happily again, although I`m
    sticking with the Thermaltake as it allows me to overclock the card that bit
    more.
    If my old fan is any use, email an address and I`ll pop it in the post.
    Loz H, Sep 2, 2004
    #41
  2. Pip
    "Loz H" <> struggled to ejaculate:
    Yer a gent, guv'nor. I'll give you a shout if required.
    Pip, Sep 2, 2004
    #42
  3. Pip
    Ben Blaney Guest
    *I* don't want it, but Pip might.
    Ben Blaney, Sep 2, 2004
    #43
  4. Pip
    Ben Blaney Guest
    I'll let you know when the place is empty and you can collect it.
    #44
  5. Pip
    Ben Blaney Guest
    Not anytime soon.
    #45
  6. Pip
    Ginge Guest
    I figured that, and know both of you would see it here. Naturally Pip
    gets to rape and pillage until he's sorted.
    If at the end ot the excersise there's a faster chip than a Celeron 466
    left over (my board will take both slot and socketed chips) it'd be very
    useful to me... if not, no worries.
    Ginge, Sep 2, 2004
    #46
  7. Pip
    Game on. I'll cascade to Ginge.
    Pip, Sep 2, 2004
    #47
  8. Pip
    Zymurgy Guest
    Pip wrote
    Heh heh. So it was terminal after that clean out then ;-)
    P.
    Zymurgy, Sep 2, 2004
    #48
  9. Pip
    (Zymurgy) struggled to ejaculate:
    Well, it lives atm. Actually, it looks much like an atm.
    The smallest HDD was dead. The graphics cars cooling fan fluffed up,
    overheated and died, frying the GPU. The power supply was as fluffy as
    ****, and vacuuming the fluff away caused a couple of resistors to
    spend their brief moment of freedom in the cleaner tube on their way
    to the bag. The CDR appears to be dead too, Dave.
    Now running on empty, a borrowed PSU and graphics card. Life Jim, but
    not as we knew it. Ho hum.
    Pip, Sep 2, 2004
    #49
  10. Pip wrote:
    So are you like picking up email, or not? Didn't realised you'd fried
    yer machine :(
    Doesnotcompute, Sep 2, 2004
    #50
  11. Pip
    As of this morning, yes. I'll reply shortly.
    Pip, Sep 2, 2004
    #51
  12. I remember being absolutely terrified by playing the AliensTC wad on
    Doom1. I doubt my heart would cope with Doom 3.
    William Grainger, Sep 2, 2004
    #52
  13. It was somewhere around Barstow, on the edge of the desert, when the
    You know how much humour is based on the misfortunes of others?
    I found that funny as ****. Having much the same chain of disaster
    happen to me a couple of years ago, it's a relief to see it happen to
    someone else.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Sep 2, 2004
    #53
  14. Pip
    Schadenfreude, innit. Delight in the misfortunes of others. You
    might as well, 'cos they'll sure as **** point and laugh at you when
    you fall on your snout.
    I be pleased, Lord Curmudgeon, to be of some small amusement. What
    got me was the way that it held on, by a cobweb as it were. Any of
    the items above should have been sufficient to screw it pretty deeply,
    but it took the graphics card to beep its last before all the rest of
    it gave up the ghost.
    Pip, Sep 2, 2004
    #54
  15. Pip
    DR Guest
    A mate lent me his freshly purchased copy to see if it's worth me buying
    it. Current PC spec is Athlon XP1800 (actual cpu speed just over 1500
    MHz), 1 Gig RAM, ATI Radeon 9200SE 128MB graphics card.
    I have a lot of money to spend if I want to play Doom 3.
    DR, Sep 2, 2004
    #55
  16. Pip
    <re-strikes D3 from Xmas list>
    Pip, Sep 2, 2004
    #56
  17. Pip
    Zymurgy Guest
    Pip wrote
    Well, let me know what's duff. I have many PC's I can cannibalise to the cause.
    Cheers,
    Paul.
    Zymurgy, Sep 3, 2004
    #57
  18. Pip
    That's most decent of you Mr. Z, but it is still running, at least for
    the forseeable, TYVM. A new mobo, CPU, RAM, and CDRom lurk in the
    future - I'm currently rattling the online parts suppliers bargain
    bins for last year's models ;-)
    Pip, Sep 3, 2004
    #58
